WME Posted February 7, 2022 Posted February 7, 2022 A 205 section tire is usually measured on a 6" rim. They will safely fit on a 5-7" rim. If you have the skills or the pocket book a wider axle and the rear swaybar are the way to go. You need to weigh your rig, the General Graber has less weight carry capacity than the 185 tire most Toy homes use Quote
Tris Mahaffay Posted February 7, 2022 Posted February 7, 2022 Again ! thanks!  yes...we will weigh it and go from there on the tires, we thought about move up to 15" rims as well.  Love the idea of putting a newer wider rear axle in. That's in our expertise for sure. We have a 1985 Yota Crawler as well. Marlin gear boxes etc. We love this little RV, need a place to stay for overnighters. Might even add a rear locker. Quote
linda s Posted February 7, 2022 Posted February 7, 2022 According to Tire Rack that specific tire is measured on a 7 inch rim and the range is 6 to 7.5. Her 5.5 rim is not even an option. Besides there are no double lugs where the outside rim attaches to the inside. It's welded together. Found the pinion info Pinion on the 78 or in your case 77 is a much coarser notch but your differential will fit into the newer axle. You just swap them out Toyota Motorhome Axle Facts! - Page 6 - Engines - Transmissions - Drive Train - Suspension - Chassis - Steering - Exhaust - Tires - Etc. - Toyota Motorhome Discussion Board Other option is to find an adapter but the only ones I can find online for truck that old are for Land Cruisers. Might have to be custom made Linda S Quote
WME Posted February 7, 2022 Posted February 7, 2022 The 6" was refering to the 205 Rosava C you recommended. Its weight carry is 2149 lbs dual and 2271 lbs single. The Grabber is rated at 1521 lbs. Thus the comment about getting the RV weighed Quote
Tris Mahaffay Posted February 8, 2022 Posted February 8, 2022 (edited) I just thought something.....so if I get two new rims for the back say...6" -7" wide they will bolt right in right?  You folks are awesome!!  Thank you so much....i'll follow up for sure on our quest. Edited February 8, 2022 by Tris Mahaffay Quote
Lucas602 Posted May 31, 2022 Posted May 31, 2022 Hi. The first link, axle faq, is broken. Does anyone have a new link for this info? Thanks! Quote
linda s Posted May 31, 2022 Posted May 31, 2022 Your right. Guess your just going to have to ask. Big difference in good or bad is appearance. Good axle has protruding hub instead of flat. Linda S Quote
fred heath Posted May 31, 2022 Posted May 31, 2022 3 hours ago, Lucas602 said: Hi. The first link, axle faq, is broken. Does anyone have a new link for this info? Thanks! Sorry, I thought you knew how to tell the good axle from bad. 5 lug nuts on the rear drum is bad. 6 lug nuts with protruding hub is good. Quote
linda s Posted May 31, 2022 Posted May 31, 2022 Tried to get it from another group but didn't work. Axle facts is on this site in files section https://groups.io/g/toyota-campers/messages Linda S Quote
Lucas602 Posted May 31, 2022 Posted May 31, 2022 2 hours ago, linda s said: Tried to get it from another group but didn't work. Axle facts is on this site in files section https://groups.io/g/toyota-campers/messages Linda S Thanks!  Specifically looking for info on weights and suggestions. Would love to do single rear wheel. I am pretty light. Quote
linda s Posted May 31, 2022 Posted May 31, 2022 The axle you have is fine with single wheels. The issue with the recall was the fake dually wheels put on by the RV manufacturers. They put stress on the bearings causing them to eventually fail. 1 ton trucks don't have different axles. They have staggered shocks and heavier leaf springs. Many members here have put on Old Man Emu 4x4 springs with good results. CS 010r is the spring. For stability your also going to need a stabilizer bar in the rear. Single wheels also gives you the ability for larger wheels but I wouldn't go larger than 15 inch. The bigger the wheel aka tire diameter the harder it is to get it moving from a standstill. Power is one thing you can't change If you want a wider stance which would also help with stability a T100 axle is 67 inches. When you figure the extra width of the duallies a single wheel will come out about the same amount. Yours is early model so measure to be sure. If you decide to get a full float there are a couple in the LA area available. For that because yours is also an early model you will need new shock mounts welded on and a few more alterations done. Actually you would need that for the T100 too. Your early frame is narrower. Don't think you need a pinion adapter for the driveshaft to diff but not sure. If you decide to keep your existing axle have a full service done. New bearings and complete inspection for wear Linda S Quote
Lucas602 Posted June 2, 2022 Posted June 2, 2022 On 5/31/2022 at 1:06 PM, linda s said: The axle you have is fine with single wheels. The issue with the recall was the fake dually wheels put on by the RV manufacturers. They put stress on the bearings causing them to eventually fail. 1 ton trucks don't have different axles. They have staggered shocks and heavier leaf springs. Many members here have put on Old Man Emu 4x4 springs with good results. CS 010r is the spring. For stability your also going to need a stabilizer bar in the rear. Single wheels also gives you the ability for larger wheels but I wouldn't go larger than 15 inch. The bigger the wheel aka tire diameter the harder it is to get it moving from a standstill. Power is one thing you can't change If you want a wider stance which would also help with stability a T100 axle is 67 inches. When you figure the extra width of the duallies a single wheel will come out about the same amount. Yours is early model so measure to be sure. If you decide to get a full float there are a couple in the LA area available. For that because yours is also an early model you will need new shock mounts welded on and a few more alterations done. Actually you would need that for the T100 too. Your early frame is narrower. Don't think you need a pinion adapter for the driveshaft to diff but not sure. If you decide to keep your existing axle have a full service done. New bearings and complete inspection for wear Linda S Thanks! I get that. It seems like I would like the T100 to get the proper width  I did find myself a donor here. Where would I source a stabilizer for the rear? I plan to take the front spindles, all tires and wheels, brakes etc. curious how switching the spindles works. Assuming I run my original control arms, sway bar etc and the ball joints will fit  weding no problem. I have a welder here. I am a mechanic.  here is my donor   Quote
linda s Posted June 2, 2022 Posted June 2, 2022 So this donor is in Pismo?. We have another member who needs the transmission or at least the speed sensor off of it. Message me and let me know Linda SÂ Rear stabilizer bar 1979-1983 Toyota Pickup 2wd & 4wd - Addco 334 Rear Sway Bar (3/4 Diameter) [334] | $139.30 | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts Oh and I want the wind guard off the hood. Won't fit yours and looks cool Quote
Lucas602 Posted June 2, 2022 Posted June 2, 2022 9 hours ago, linda s said: So this donor is in Pismo?. We have another member who needs the transmission or at least the speed sensor off of it. Message me and let me know Linda S Rear stabilizer bar 1979-1983 Toyota Pickup 2wd & 4wd - Addco 334 Rear Sway Bar (3/4 Diameter) [334] | $139.30 | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts Oh and I want the wind guard off the hood. Won't fit yours and looks cool Cool. No not pismo but Ill check the transmission and grab the wind guard for you if you want. I have discounted shipping rates with work.   Quote
Lucas602 Posted August 22, 2022 Posted August 22, 2022 Does anyone know the rear axle nut size and thread pitch on the 6 lug dually rear? Thanks. Quote
linda s Posted August 22, 2022 Posted August 22, 2022 Lug nuts are 14 x 1.5. Same as a Tundra Linda S Quote
thewanderlustking Posted August 31, 2022 Posted August 31, 2022 Also a lot of our dually rears have reverse thread on the left side. I believe I found these ones on Rock Auto a little time back. Quote
Rearhatchsunrader Posted February 22, 2023 Posted February 22, 2023 Reviving this old thread with a unique question. I have a 1978 Shorty Sunrader with Foolie rear axle. I have acquired the full-float rear axle needed to make the sunrader safe to drive before i redo it, but here is my question.  Can i mount the full float rear axle to the existing leaf springs so i don’t have to move the perch mounts and only need to move the shock mounts or do i have to use the full float leaf springs? I have the leaf springs, ubolts, and dually wheels, just trying not to create more work than necessary.  Thanks in advance. Quote
extech Posted February 22, 2023 Posted February 22, 2023 i would put the springs on the dually axle and shove the whole thing under there. mount the front of the springs, then lift the axle up tp connect the rear hangers. Quote
Rearhatchsunrader Posted February 22, 2023 Posted February 22, 2023 Thanks for responding but i just want to clarify a little bit. Â What im asking is i have the foolie springs and foolie axle. Can i put the full float axle on the foolie springs and reinstall it? Quote
linda s Posted February 22, 2023 Posted February 22, 2023 There's no such thing as full float springs but they are heavy duty and should have extra leaves. Count them and compare to yours. Also your springs are very old. Ones that came with the full float are probably much newer and possibly in better shape. Things to consider when upgrading. Do you have the wheels you need Linda S Quote
Rearhatchsunrader Posted February 22, 2023 Posted February 22, 2023 13 minutes ago, linda s said: There's no such thing as full float springs but they are heavy duty and should have extra leaves. Count them and compare to yours. Also your springs are very old. Ones that came with the full float are probably much newer and possibly in better shape. Things to consider when upgrading. Do you have the wheels you need Linda S Yes i have the wheels and springs. Im just trying to not have to cut and reweld the spring perches as well Quote
fred heath Posted February 22, 2023 Posted February 22, 2023 (edited) Your 1978 frame rails are narrower than later model Toyota.  The spring perch’s will need adjustment to match your rails.  They also make offset shackles and spring perch’s. I’ve never used them. Custom car makers use them all the time. Weight would be a determining factor with that.  Personally, I’d adjust the spring perch’s.  Measure distance center hole to center hole on your foolie spring perch’s. Compare that measurement to your 6 lug ff spring perch’s. That will tell you how much adjustment you’ll need to make. Edited February 22, 2023 by fred heath Quote
Toycollector47 Posted October 12, 2023 Posted October 12, 2023 Crap, wheel bearing melted down and the race literally welded itself to the spindle! Quote
Scott iv Posted October 12, 2023 Posted October 12, 2023 These motorhomes don't die easy, but now that they're in their 30's and 40's they do get hurt a lot. Quote
linda s Posted October 13, 2023 Posted October 13, 2023 So sorry that happened. Can you get your axle out. That's the biggey. All the other parts are readily available but if the axle is damaged it's going to be a tough find. Linda S Quote
marccram1973 Posted June 17, 2025 Posted June 17, 2025 I have a 85 dolphin i upgraded my rearend out of newer model full float toyota dually My question is do they make adapters so I can run the dually rim on the front and not have to carry 2 spare tires. Quote
extech Posted June 17, 2025 Posted June 17, 2025 the front hubs and brakes from the 1 ton can be used to replace your stock front hubs and brakes. i did this to my 84 dolphin just to have all the wheels the same. the bigger 1ton brakes is a plus Quote
linda s Posted June 17, 2025 Posted June 17, 2025 This place has front brake assembly from a dolphin listed. might be just what you need. kniktw_homepage Linda S Quote
