Odyssey 4x4 Posted August 17 Share Posted August 17 For the life of me I cannot remember how the original propane tank and regulator layout was done on my Odyssey. I have my propane tank refurbished and a new regulator, but as you can see, there is no room to connect my propane line to the regulator in my propane compartment. Is it safe to add a soft line between the propane tank and the regulator so that I can mount the regulator in a different location where it will fit? Quote Link to comment Share on other sites More sharing options...
linda s Posted August 17 Share Posted August 17 Yes. Just find one with the right connectors. propane tank to regulator hose - Google Search That regulator looks huge. Measure it and I will measure mine tomorrow. Just curious. Also the connector from the tank to the regulator looks longer than it needs to be. Linda S Quote Link to comment Share on other sites More sharing options...
5Toyota Posted August 17 Share Posted August 17 maybe that at one time had an old single stage regulator . those can not be installed. now they do not meet safety standreds. but they where much smaller . my old 78 had one the local rv shop told me i needed to get rid of it what he has is the same as i have had . Quote Link to comment Share on other sites More sharing options...
fred heath Posted August 17 Share Posted August 17 (edited) This is the regulator you want. It’s compact in size and should fit your tank compartment. I’m using this exact setup now. It can be bought on Amazon or even Lowe’s for about $40. https://www.charbroil.com/universal-dual-stage-propane-regulator-9059398?gclid=EAIaIQobChMIv93h2pzjgAMVq0p_AB3eaw5PEAQYAiABEgIbr_D_BwE Edited August 17 by fred heath Quote Link to comment Share on other sites More sharing options...
AtlantaCamper Posted August 17 Share Posted August 17 20 hours ago, Odyssey 4x4 said: Is it safe to add a soft line between the propane tank and the regulator so that I can mount the regulator in a different location The soft hoses are rated at either high pressure or low pressure based on what I've seen at Propane Warehouse. It's possible some metal flex line is rated for high pressure. Just make sure the hose you get is rated for full ~350 psi if you go that route. This would allow you to mount the regulator somewhere else like outside that compartment. It would make it easier to move that tank with just a flex line to the POL fitting. You could even get a hand tightening POL (with the o-ring instead of hard copper end) and you wouldn't even need tools to get the hose off the tank when it's refill time. I'm assuming you have to remove the tank from the vehicle to refill. Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted August 17 Author Share Posted August 17 The tank is a permanent install tank so I'd need a permanent install solution. The regulator I have in the first post is JR Products 07-30375 and measures in at 8" inches. I just picked up the Charbroil regulator mentioned in this post and while it is shorter at 7.25", it's still too tight to work in the current configuration. If I were to either tighten or loosen the main valve a bit, I may be able to sneak the attachment line on in the current configuration. Otherwise, I need to do a a soft line mount and put the regulator elsewhere in the box. Here is the Charbroil regulator in place... and here are the two regulators... Quote Link to comment Share on other sites More sharing options...
AtlantaCamper Posted August 18 Share Posted August 18 (edited) I didn't realize that was a permanent install tank, my mistake. I don't suppose you could insert a NPT male to female 45 degree fitting like this between the POL and regulator input? It might angle the regulator into the upper right corner and give you the room to attach a low pressure soft line to the output of the regulator. (edit: this may be a bad suggestion as the regulators are designed to be vertical or horizontal. Angled might be a poor choice). I am replacing my original soft low pressure line from the output of the regulator to a hardline under the rig that feeds the rest of the system. I was told that a softline in this place is what acts as a shock absorber so that the movement of the tank when the rig hits bumps doesn't get transferred to the rest of the piping due to the softline. Edited August 18 by AtlantaCamper Quote Link to comment Share on other sites More sharing options...
fred heath Posted August 18 Share Posted August 18 Charbroil is most compact 2 stage regulator out there. What’s on the other side of the box where the regulator is hitting against? Can you dimple that area out or even cutout a small section to accommodate the elbow and gas line? Just brainstorming. Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted August 18 Author Share Posted August 18 (edited) Unfortunately the box doesn’t have room on the other side in that location. It’s looking like i’ll need to do a soft line and mount the regulator elsewhere in the box. I do see single stage regulators that will fit without issue. Is a 2-stage regulator absolutely crucial? Edited August 18 by Odyssey 4x4 Quote Link to comment Share on other sites More sharing options...
extech Posted August 18 Share Posted August 18 how about moving the back of the tank to the right, and front to the left Quote Link to comment Share on other sites More sharing options...
linda s Posted August 18 Share Posted August 18 Yes 2 stage is required. Come out of tank high pressure. Single stage it stays high pressure, aka barbeque. 2 stage it comes out low pressure which is what your appliances in an RV need. How on earth is that tank filled? Don't see a proper fill place Linda S Quote Link to comment Share on other sites More sharing options...
WME Posted August 18 Share Posted August 18 That looks like one of the use horizontal and fill vertical models. You have to remove it to fill. So you have to remove the regulator to fill, so you need a flex hose on the output of thee regulator os you can move the regulator to get the tank out. A 90 deg fitting on the regulator output is not a problem. Quote Link to comment Share on other sites More sharing options...
fred heath Posted August 18 Share Posted August 18 You might be able to make this work. The price is right. https://www.homedepot.com/p/Flame-King-2-Stage-Propane-Gas-RV-Regulator-with-Rain-Cover-G2R150B/314273436 Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted August 18 Author Share Posted August 18 8 hours ago, WME said: That looks like one of the use horizontal and fill vertical models. You have to remove it to fill. So you have to remove the regulator to fill, so you need a flex hose on the output of thee regulator os you can move the regulator to get the tank out. A 90 deg fitting on the regulator output is not a problem. I swear this tank was hard mounted into the box with bolts front and rear, but I cannot 100% remember. If you folks are confident that this is a remove to fill tank (PITA since it's a pretty big and heavy tank), then that changes my regulator mounting choice. I'd have to go soft mount with a remotely mounted regulator. If only I had photos of the original install! It was too long ago and I just can't remember. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 18 Share Posted August 18 I searched this site for comments from other Odyssey owners and removing and filling the tank was an issue for quite a few. Yes you must remove it and fill it upright. Did you watch that old guy who worked on it fill it? The second pol valve with the plastic spin handle is the way to go since it's going to have to be removed often. Linda S Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted August 18 Author Share Posted August 18 Okay well that simplifies things! I'm glad I asked here before I did a permanent hard mount install! I'll update when install is complete, thanks folks. Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted August 20 Author Share Posted August 20 Here's an update on the finished product. I ended up doing a soft hose as mentioned... I used this hose from amazon to go from the tank to the regulator... I hooked everything up out of the vehicle and opened the tank valve, then checked for leaks at every joint. I then remotely mounted my dual stage regulator in the upper right corner out of the way so that the tank can still be removed to be filled, and also with the vent facing down. We drilled a pass through for the hose into the cabin, and double wrapped the propane line with a hose and shrink-wrap where it goes through the pass through to prevent rubbing. We slid the tank into place, secured it down with the studs I installed (you'll need a 1/2" wrench to remove the nuts when you go to fill the tank, I'll leave one in the compartment), and finally installed the new 14x14 door I ordered. I still need to clean the excess butyl off you see in the photo. We also caulked the entire interior side of the access door for any water that gets into the propane compartment. And the most exciting part, I fired up all the LP appliances in the RV for the very first time, and everything worked wonderfully! I'm glad to see my new water heater fire up and know I got all the wiring right on the first try for the remote panel. It was also fun to see the stove and oven fire up for the first time. Quote Link to comment Share on other sites More sharing options...
fred heath Posted August 20 Share Posted August 20 28 minutes ago, Odyssey 4x4 said: Here's an update on the finished product. I ended up doing a soft hose as mentioned... I used this hose from amazon to go from the tank to the regulator... I hooked everything up out of the vehicle and opened the tank valve, then checked for leaks at every joint. I then remotely mounted my dual stage regulator in the upper right corner out of the way so that the tank can still be removed to be filled, and also with the vent facing down. We drilled a pass through for the hose into the cabin, and double wrapped the propane line with a hose and shrink-wrap where it goes through the pass through to prevent rubbing. We slid the tank into place, secured it down with the studs I installed (you'll need a 1/2" wrench to remove the nuts when you go to fill the tank, I'll leave one in the compartment), and finally installed the new 14x14 door I ordered. I still need to clean the excess butyl off you see in the photo. We also caulked the entire interior side of the access door for any water that gets into the propane compartment. And the most exciting part, I fired up all the LP appliances in the RV for the very first time, and everything worked wonderfully! I'm glad to see my new water heater fire up and know I got all the wiring right on the first try for the remote panel. It was also fun to see the stove and oven fire up for the first time. NICE WORK…….. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 20 Share Posted August 20 Looks beautiful. Linda S Quote Link to comment Share on other sites More sharing options...
AtlantaCamper Posted August 21 Share Posted August 21 What a great result! It's always rewarding to see the quality collaborative DIY projects documented by this group. Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted August 21 Author Share Posted August 21 44 minutes ago, AtlantaCamper said: What a great result! It's always rewarding to see the quality collaborative DIY projects documented by this group. Agreed! I’ve loved this website since day one of my Toyota camper days. Such a friendly helpful community. Quote Link to comment Share on other sites More sharing options...
Flyinby Posted August 21 Share Posted August 21 Looks really great, but I'm curious about the lock on the door. My understanding was it was a DOT regulation that the propane access door can't be locked for safety reasons. (in event of an accident, propane can be shut off without delay). Not a criticism, your work looks great. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 21 Share Posted August 21 Good catch. Yes, Odyssey 4x4 he is correct. No locks allowed on propane access doors. Linda S Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted August 21 Author Share Posted August 21 36 minutes ago, linda s said: Good catch. Yes, Odyssey 4x4 he is correct. No locks allowed on propane access doors. Linda S I thought this might be the case. I was between no lock for safety reasons, or having a lock to keep it tamper resistant from “curious” folks. I held onto the latch “just in case”. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 21 Share Posted August 21 No worries just don't lock it. If anyone like a professional LP tech asks tell them it gives the impression that it's locked for safety. Linda S Quote Link to comment Share on other sites More sharing options...
