shibs Posted October 10, 2015 Share Posted October 10, 2015 The eagle has landed, I drove home the Sunrader today, it started after a few cranks after sitting for many months. I see the radiator petcock on the pass side bottom towards the firewall of the radiator (next to the atf line) Is there a trick to open it? Is it made of plastic? should I try turning it with a plier lined with tape, very slowly? I can't seem to open it. Quote Link to comment Share on other sites More sharing options...
Bob C Posted October 10, 2015 Share Posted October 10, 2015 I had to use a pliers to open mine when I bought the RV. when you close it, it has to be snug, not tight. After you refill with antifreeze, drive for a while and check it for leaks. It is just a plastic plug so don't overdo it. Quote Link to comment Share on other sites More sharing options...
shibs Posted October 10, 2015 Author Share Posted October 10, 2015 decided not to do this today, I have the worst luck with these, next week I will try to open it with a slip plier very slowly Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 11, 2015 Share Posted October 11, 2015 Spray a little WD40 on it and let it sit overnight. Quote Link to comment Share on other sites More sharing options...
Bob C Posted October 13, 2015 Share Posted October 13, 2015 You might try warming it up gently with a heat gun (not a propane torch) Just heat up the lower end of the radiator and maybe it will come loose. Quote Link to comment Share on other sites More sharing options...
WME Posted October 14, 2015 Share Posted October 14, 2015 Make sure that you turn it the right way. Quote Link to comment Share on other sites More sharing options...
shibs Posted October 14, 2015 Author Share Posted October 14, 2015 I looked at it and then I stared at it for few minutes and it reminded me how a 10 min project turned out to be a 5 hour deal and mucho mulas few times before. So I decided that pulling out the bottom rad hose will be MUCH safer option, :-) I have the worst luck with these stuff. Quote Link to comment Share on other sites More sharing options...
Bob C Posted October 14, 2015 Share Posted October 14, 2015 Now would be a good time to change all of the hoses if you have not done that lately. Quote Link to comment Share on other sites More sharing options...
shibs Posted October 14, 2015 Author Share Posted October 14, 2015 Yes Sir, new hoses and hose clamps, inspected vac hoses too. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted October 14, 2015 Share Posted October 14, 2015 I can relate! Forcing 25 year old plastic, what could go wrong? I hope you are not doing this where the neighbor lady's dog's booties will get wet! Jim Quote Link to comment Share on other sites More sharing options...
shibs Posted October 14, 2015 Author Share Posted October 14, 2015 lol, unfortunate it is going to flow right into the side walk, I might have to pay for the dogs booties to be dry cleaned here is a view of the side walk from my step looking over my driveway. Quote Link to comment Share on other sites More sharing options...
Donnie Posted October 14, 2015 Share Posted October 14, 2015 Please use something to absorb the coolant from the street.. Engine coolant is DEADLY TO ALL PETS, and their death is not instant. They suffer terribly before they die................ donnie Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 15, 2015 Share Posted October 15, 2015 The picture looks like a slide in camper. Definitely not fiberglass. Is that your sunrader? Quote Link to comment Share on other sites More sharing options...
5Toyota Posted October 15, 2015 Share Posted October 15, 2015 I use catch pans to get as much as i can . very toxic stuff. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted October 15, 2015 Share Posted October 15, 2015 mine turns in the normal direction (leftie loosie, righty tighty) They are available for a reasonable sum at most auto part stores (there is a rubber seal that goes bad). I would not spray any solvents on it - plastic does not like solvents. You should be able to open it with hand pressure only. Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 15, 2015 Share Posted October 15, 2015 mine turns in the normal direction (leftie loosie, righty tighty) They are available for a reasonable sum at most auto part stores (there is a rubber seal that goes bad). I would not spray any solvents on it - plastic does not like solvents. You should be able to open it with hand pressure only. Wd40 is a multi-use lubricant. It will not hurt plastic automotive parts. It's safe to use on most any surface (except some polycarbonates). It does a great job removing brake dust from alloy wheels. Quote Link to comment Share on other sites More sharing options...
shibs Posted October 15, 2015 Author Share Posted October 15, 2015 doggie botties + dry cleaning bill = joke Glycol is not good any living breathing things. Nope, that is my 4wheel camper This is my sunrader :-) Quote Link to comment Share on other sites More sharing options...
