gringostar Posted March 4, 2016 Share Posted March 4, 2016 Hello all, I just bought a 1986 Mini-Cruiser and the water heater is shot. It leaks like a sieve and is rotted out. I found several on Ebay and price looks right. Qustion is, will they fit and are they the right size? What's the best one and or should I buy from a reputable dealer and spend the extra money? On ebay they are $234 with free shipping. Here is the link. Pic is below. http://www.ebay.com/itm/Suburban-SW6P-6-Gallon-LP-Gas-RV-Hot-Water-Heater-Pilot-Light-Motorhome-Camper-/141914357539?hash=item210ac13f23:g:Zt0AAOSwG-1W0LpA&vxp=mtr Thanks! Quote Link to comment Share on other sites More sharing options...
gringostar Posted March 4, 2016 Author Share Posted March 4, 2016 Hi Guys. I want to get the suburban but will it work for my rig? As you can see in the pictures, my water heater connects with 12 phillips screws from the outside. The Suburban model doesn't have any of that mounting??? Quote Link to comment Share on other sites More sharing options...
linda s Posted March 4, 2016 Share Posted March 4, 2016 Here's the installation file http://www.dyersonline.com/downloadfile/download/aitfile/aitfile_id/1979/ If you want to retro fit it so the installation looks the same you need one of these http://www.dyersonline.com/suburban-radius-corner-door-install-kit-for-v-model-to-sw6-water-heater.html?utm_medium=shoppingengine&utm_source=googlebase&gclid=CICA67aTqMsCFYZefgodpf0PBg or you can buy a flush mount door kit http://www.dyersonline.com/suburban-polar-white-sw-series-flush-mount-4-6-gallon-door.html Things change. You just need to adjust for it but it will work. I would retrofit. Might find the parts cheaper on ebay too Linda S Quote Link to comment Share on other sites More sharing options...
gringostar Posted March 5, 2016 Author Share Posted March 5, 2016 18 hours ago, linda s said: Here's the installation file http://www.dyersonline.com/downloadfile/download/aitfile/aitfile_id/1979/ If you want to retro fit it so the installation looks the same you need one of these http://www.dyersonline.com/suburban-radius-corner-door-install-kit-for-v-model-to-sw6-water-heater.html?utm_medium=shoppingengine&utm_source=googlebase&gclid=CICA67aTqMsCFYZefgodpf0PBg or you can buy a flush mount door kit http://www.dyersonline.com/suburban-polar-white-sw-series-flush-mount-4-6-gallon-door.html Things change. You just need to adjust for it but it will work. I would retrofit. Might find the parts cheaper on ebay too Linda S If I buy the retro fit kit do I have to buy the door too? My door fixes to the flange and its' from a different company. Quote Link to comment Share on other sites More sharing options...
linda s Posted March 5, 2016 Share Posted March 5, 2016 Says in the retro fit description it's for people who want to use their original door. It is the same company just many years apart and new name. I had to buy a new door at one point and the Suburban door fit with some minor adjustments. Lots of big RV places in southern Cal. Maybe you should go look at some parts and get an idea of how they go together first. Linda S Quote Link to comment Share on other sites More sharing options...
jmowrey Posted March 5, 2016 Share Posted March 5, 2016 We put a Suburban water heater in our Dolphin and it's been working just fine. If you are up for the wiring project I highly recommend you get the kind with the electronic ignition and the remote switch for inside the cab. It's such a pleasure to be able to just flip a switch inside and the water heater lights itself. Likewise, once the water is hot you can turn it off without going outside. Plus, no pilot light using up your propane when the water heater isn't actually heating water. We find that once the water is hot it will stay that way for a good part of the day in case you need a little hot water for washing hands or whatever. Then we turn it back on after dinner to bring the water up to full heat again for washing dishes. Also, be prepared in cooler weather for the water heater to overflow a bit out the overflow valve when you are heating up the water from a cold start. Expansion causes it to do this. It's normal. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted March 20, 2016 Share Posted March 20, 2016 it is all about measurements - of the "hole" where you want it to go. I might be inclined to search places like PPL Motorhomes and Dyer as well as local dealers - places where you have might good options to return a misfit. If you buy it on ebay I would message the store and make sure the return policy very clear. Quote Link to comment Share on other sites More sharing options...
kayakthecoast Posted April 9, 2016 Share Posted April 9, 2016 I have the auto start model I purchased on eBay. Been sitting on my shelf all winter, now that weather is good I'll be installing! I too will need a retro fit door. Quote Link to comment Share on other sites More sharing options...
DirtyPatches Posted October 24, 2016 Share Posted October 24, 2016 Found a nice big crack in my tank. Need to replace it, anyone know the model number for the Atwood with electric switch? In a 1990 Sea Breeze. I hear patching won't work... for long anyways:( Quote Link to comment Share on other sites More sharing options...
linda s Posted October 24, 2016 Share Posted October 24, 2016 Atwood is the only company that I know of that supplies replacement tanks. Take yours out first and compare http://www.adventurerv.net/atwood-replacement-inner-tank-91641-p-27665.html?gclid=CNSx5O7R9M8CFUtNfgodbioMTQ&utm_campaign=partsfeed_ppc&utm_medium=cpc&utm_source=Froogle Saves you about 100 bucks if it will work. Maybe more on EBay Linda S Quote Link to comment Share on other sites More sharing options...
DirtyPatches Posted October 27, 2016 Share Posted October 27, 2016 On 10/24/2016 at 5:56 PM, linda s said: Atwood is the only company that I know of that supplies replacement tanks. Take yours out first and compare http://www.adventurerv.net/atwood-replacement-inner-tank-91641-p-27665.html?gclid=CNSx5O7R9M8CFUtNfgodbioMTQ&utm_campaign=partsfeed_ppc&utm_medium=cpc&utm_source=Froogle Saves you about 100 bucks if it will work. Maybe more on EBay Linda S Thanks Linda! Better deal than the one I was looking at. Rv shop quoted me at 800$! What robbery, heard it's about a few hour job probably one for them. For now I am bypassing the tank with a plastic nipple and two 90's so we can have water still. Quote Link to comment Share on other sites More sharing options...
Maineah Posted October 29, 2016 Share Posted October 29, 2016 I like the pilot light on my heater when I get up in the morning the water is just as hot if not hotter with just the little flame from the pilot no waiting for hot water. You can replace just the tank but your will need a tool or make one to drive on the ring that holds the tank to the backing plate. The price difference really is not that great between a tank and the unit, check before buying. Quote Link to comment Share on other sites More sharing options...
DirtyPatches Posted November 21, 2016 Share Posted November 21, 2016 On 10/29/2016 at 3:59 PM, Maineah said: I like the pilot light on my heater when I get up in the morning the water is just as hot if not hotter with just the little flame from the pilot no waiting for hot water. You can replace just the tank but your will need a tool or make one to drive on the ring that holds the tank to the backing plate. The price difference really is not that great between a tank and the unit, check before buying. Good advice! Looking at new models (found my model number inside the outer door). Found one for $318 on ebay, going for $425 plus on some sites! Would love to do a tankless conversion but just cant justify the price. Some cheaper models out there that say they are for RV's/ boats (around $200), but not sure how to go about doing the conversion. Anyone know of someone doing a cheaper model tankless swap in a toyota rv? Probably going to play it safe and buy the replacement. Fairly easy to swap I'm assuming? Experience with that anyone? Quote Link to comment Share on other sites More sharing options...
linda s Posted November 21, 2016 Share Posted November 21, 2016 Maybe this one is still available. probably not but worth a try https://clovis.craigslist.org/rvs/5837155140.html Linda S Quote Link to comment Share on other sites More sharing options...
Maineah Posted November 22, 2016 Share Posted November 22, 2016 2 hours ago, DirtyPatches said: Good advice! Looking at new models (found my model number inside the outer door). Found one for $318 on ebay, going for $425 plus on some sites! Would love to do a tankless conversion but just cant justify the price. Some cheaper models out there that say they are for RV's/ boats (around $200), but not sure how to go about doing the conversion. Anyone know of someone doing a cheaper model tankless swap in a toyota rv? Probably going to play it safe and buy the replacement. Fairly easy to swap I'm assuming? Experience with that anyone? My thoughts on tank less heaters, very expensive, needs a vent, needs re-plumbing, new propane lines, and what's the sense of endless hot water when the fresh tank only holds so much water? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 22, 2016 Share Posted November 22, 2016 The cheap ones I've seen people talking about installing are sold as 'portable' and are meant for outdoor use. The last one I bothered to look at the specs called for 36" overhead clearance, yet I saw people talking about installing them inside their cabinet in the place their old water heater was! All I can say is "Good Luck!". " This unit requires a 2 in. clearance from a wall, 1 ft. side to side from anything flammable, 3 ft. from a window as well from an overhang and 18 in. from the ground. " http://www.homedepot.com/p/Eccotemp-1-5-GPM-Portable-Gas-Tankless-Water-Heater-L5/205574393?cm_mmc=Shopping|THD|G|0|G-VF-PLA-D26P-WaterHeaters|&gclid=CjwKEAiAmJvBBRDKpP724LigwngSJAAYRJXBXIAga2AxLZ0u-zRMEnxgxELhW4pTBv5oHmP8wgvTORoCKMDw_wcB&gclsrc=aw.ds Or this FB 'genius' (who obviously doesn't read instructions):- " For OUTDOOR use only. Do NOT use in a building, garage or any other enclosed area." "Do not operate appliance under ANY overhead construction. Keep a minimum clearance of 3 feet (1 m) from the sides, front and back of appliance to ANY construction. " http://www.campchef.com/media/manuals/HWD5_Manual.pdf Quote Link to comment Share on other sites More sharing options...
jjrbus Posted November 22, 2016 Share Posted November 22, 2016 This type of electric heater is used extensively in Asia. Not recommending it, showing an option. Jim Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 22, 2016 Share Posted November 22, 2016 I think North America is the only place 'decadent' enough to keep 40-60 gallon containers of hot water ready at all times. Quote Link to comment Share on other sites More sharing options...
Maineah Posted November 22, 2016 Share Posted November 22, 2016 1 hour ago, jjrbus said: This type of electric heater is used extensively in Asia. Not recommending it, showing an option. Jim Most likely 240 volt. Even if it was 120 the wiring in a Toy home would not be sufficient. Europe and Asia have had tank-less heaters for decades the ones that work the best are propane. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted November 22, 2016 Share Posted November 22, 2016 1 hour ago, Maineah said: Most likely 240 volt. Even if it was 120 the wiring in a Toy home would not be sufficient. Europe and Asia have had tank-less heaters for decades the ones that work the best are propane. 110 volt! Requires #10 wire and 30 amp breaker. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted November 22, 2016 Share Posted November 22, 2016 1 hour ago, Derek up North said: I think North America is the only place 'decadent' enough to keep 40-60 gallon containers of hot water ready at all times. And I might add hot enough to cook with. Some areas require scald proof fixtures so people who are common sense challenged don't cook themselves in the shower. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 22, 2016 Share Posted November 22, 2016 I always turn the thermostat down to 140*F. (Rule of thumb:- This is about the maximum temperature that you can comfortably place your hand on.) Quote Link to comment Share on other sites More sharing options...
Maineah Posted November 23, 2016 Share Posted November 23, 2016 8 hours ago, jjrbus said: 110 volt! Requires #10 wire and 30 amp breaker. Yes and you had better not turn any thing else on when it's running! Your campground neighbors won't like you when you trip the main. Quote Link to comment Share on other sites More sharing options...
DirtyPatches Posted November 25, 2016 Share Posted November 25, 2016 Thanks for the advice everyone! Good point about the tankless, very true probably only take a 10 minute shower to fill the grey. Way too much work as little as we need hot water. Went with a brand new replacement for $318 on eBay. 6 gallon with electric start. Can't wait to rip out the old one! Quote Link to comment Share on other sites More sharing options...
tofuricer Posted September 13, 2017 Share Posted September 13, 2017 In case anyone wants to see what a tankless setup looks like, the previous owner of my RV added this. When I was told it was "professionally installed" I couldn't help but LOL. It is brand new and works if you only want to rinse off your lower body, but it's getting ripped back out. Quote Link to comment Share on other sites More sharing options...
fred heath Posted September 13, 2017 Share Posted September 13, 2017 A little off the topic, but I remember a neighbor of mine when I was a kid converted an old small school bus into a camper. He solved his hot water issues by soldering 5 or 6 old heater cores together, painted flat black and mounted on the roof between 2 sheets of Plexiglas. A 12V demand pump kept the system pressurized. He always had plenty of hot water (on sunny days ?). Quote Link to comment Share on other sites More sharing options...
