thetoyotadude Posted July 7, 2009 Share Posted July 7, 2009 How do I find out if my rigs fridge is eligible for the Recall? 92 Itasca Spirit Thanks Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted July 7, 2009 Share Posted July 7, 2009 I have never heard of any recalls for any of the refrigerators. Why do you ask? Quote Link to comment Share on other sites More sharing options...
thetoyotadude Posted July 7, 2009 Author Share Posted July 7, 2009 3 words... Mother in law ha ha, and she bickered to my wife about it, I thought I'd make sure Quote Link to comment Share on other sites More sharing options...
Bodybagger Posted July 8, 2009 Share Posted July 8, 2009 The fridges in these things predate the recall unless they were replaced with new 2 door models ones for some reason. If it's not a 2 door, it's not in the recall. If unsure, look for the SN on the unit. Full text: -------------------------------------------------------------------------------- Report Date : July 8, 2009 at 04:15 AM NHTSA CAMPAIGN ID Number: 06E076000 Equipment Brand Name / Part No. or Model No.: Production Dates: DOMETIC / NDR1062 APR 01, 1997 - MAY 31, 2003 DOMETIC / RM2652 APR 01, 1997 - MAY 31, 2003 DOMETIC / RM2662 APR 01, 1997 - MAY 31, 2003 DOMETIC / RM2663 APR 01, 1997 - MAY 31, 2003 DOMETIC / RM2852 APR 01, 1997 - MAY 31, 2003 DOMETIC / RM2862 APR 01, 1997 - MAY 31, 2003 DOMETIC / RM3662 APR 01, 1997 - MAY 31, 2003 DOMETIC / RM3663 APR 01, 1997 - MAY 31, 2003 DOMETIC / RM3862 APR 01, 1997 - MAY 31, 2003 DOMETIC / RM3863 APR 01, 1997 - MAY 31, 2003 Manufacturer: DOMETIC CORPORATION Mfr's Report Date: AUG 28, 2006 NHTSA CAMPAIGN ID Number: 06E076000 N/A NHTSA Action Number: N/A Component: EQUIPMENT:RECREATIONAL VEHICLE Potential Number of Units Affected: 926877 Summary: CERTAIN DOMETIC TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN APRIL 1997 AND MAY 2003: SERIAL NOS. 713XXXXX THROUGH 752XXXXX; 801XXXXX THROUGH 852XXXXX; 901XXXXX THROUGH 952XXXXX; 001XXXXX THROUGH 052XXXXX; 101XXXXX THROUGH 152XXXXX; 201XXXXX THROUGH 252XXXXX; 301XXXXX THROUGH 319XXXXX, INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS AFTERMARKET EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT. Consequence: THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE. Remedy: THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN BETWEEN APRIL AND JUNE 2007. OWNERS MAY CONTACT DOMETIC AT 888-446-5157. Notes: CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV. Quote Link to comment Share on other sites More sharing options...
estelle Posted July 23, 2009 Share Posted July 23, 2009 I am told by old experienced RV'r friends of mine that fridges in RV's rarely last more than 10 years..And that would be under perfect level conditions and with regular use. Hope that gives you something to go by...I am having to replace mine and when I do will keep it plugged in and going most of the time on low. If there is a strong ammonia smell when running... it is gonzo... Quote Link to comment Share on other sites More sharing options...
Tony D. Posted September 18, 2009 Share Posted September 18, 2009 On 7/23/2009 at 2:20 AM, estelle said: I am told by old experienced RV'r friends of mine that fridges in RV's rarely last more than 10 years..And that would be under perfect level conditions and with regular use. Hope that gives you something to go by... I am having to replace mine and when I do will keep it plugged in and going most of the time on low. If there is a strong ammonia smell when running... it is gonzo... Mine is now about 23 years old. It seems to be going strong. Quote Link to comment Share on other sites More sharing options...
picklebill Posted December 6, 2009 Share Posted December 6, 2009 We have a 1982 rig with the original fridge and it still works fine. In our previous rig, the fridge was 30 years old when we sold it, and was still working fine. The important thing is to never run them if they are not level. We have always turned them off when we are not using the rig and that doesn't seem to hurt them. Bill Quote Link to comment Share on other sites More sharing options...
Maineah Posted December 6, 2009 Share Posted December 6, 2009 There really is not too much that can go wrong other then rust and running them when they are not level. Mine is 23 years old and will freeze stuff in the lower part if the weather is in the 40s. Yeah I have to clean the gas tip once in awhile but that's about it. I had a full size gas fridge in an apartment I rented years ago that the owner said was 45 years old. Quote Link to comment Share on other sites More sharing options...
Rocinante Sunrader 88 Posted December 5, 2010 Share Posted December 5, 2010 I have a perfectly functional 36 year old Dometic fridge in a 1974 Hunter Compact II that my new Sunrader is replacing. Hard to light, but then it works just fine. Quote Link to comment Share on other sites More sharing options...
stamar Posted October 18, 2012 Share Posted October 18, 2012 I went to check out the harbor freight generator. Its a small engine hooked to a car alternator. Definitely. I mean a chinese alternator no doubt. Larger than I thought it would be. I have seen the same one sold as 1100 watts from other sources Looks good and putting a cooler over it for weather protection is boss. I'm just afraid all the winos will. Open it looking for beer Quote Link to comment Share on other sites More sharing options...
Donnie Posted May 20, 2014 Share Posted May 20, 2014 My Dometic in my 1973 Travco works fine and has never had to be serviced ??????? . When playing festivals every weekend I let it run on gas full time...........never ran it on 110??????????..I bought it in '90, so it is at least 24 years old.........large unit single door. This truck is now for sale on the Travco site, if anyone is interested NORCOLD has a LIST of recalls......I just picked up a used one for one of my Chinooks & sure enough, when I checked the model & serial # it was on the recall list ...<<fire hazard on gas DO NOT USE.>>>>....I called the Norcold #....gave them the model & serial number.. They were most helpful. Verified that the recall fix was done in 2006 by 4 seasons.....I called corporate first, & they gave me another # that handles only RECALLS..Donnie Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted May 21, 2014 Share Posted May 21, 2014 What "festivals" and what are you "playing"? Quote Link to comment Share on other sites More sharing options...
zero Posted May 21, 2014 Share Posted May 21, 2014 On 7/23/2009 at 2:20 AM, estelle said: I am told by old experienced RV'r friends of mine that fridges in RV's rarely last more than 10 years..And that would be under perfect level conditions and with regular use. Hope that gives you something to go by...I am having to replace mine and when I do will keep it plugged in and going most of the time on low. If there is a strong ammonia smell when running... it is gonzo... 10 years of actual age or 10 years of continuous use? Either way - that figure does not reflect what I've experienced with them. I still have a used Japanese three-way I got in 1979 and it still works fine. Came out of a big truck camper and is now used in a summer camp - every summer. The OEM Dometic in my 1973 Jayco still works well. I bought a 1977 and 1978 Toyota Chinooks in the past few years. Both still have the original Dometic 3-ways and both were pretty easy to clean up and get going. Burners needed cleaning and electric switches bad. Just minor issues. I just bought a rotted out 1980 Coachmen truck camper that I'm stripping for parts. The big original Dometic 3-way is the only thing in it that works. I suspect many 3-ways get condemned for minor issues. Quote Link to comment Share on other sites More sharing options...
Donnie Posted May 21, 2014 Share Posted May 21, 2014 Hello JD, maybe you have a tip for me.. I would love to keep the 3 way Dometic in my 78, but I've tried all the tricks that were suggested on you tube & by friends...super leveled the unit, took it out inverted, tapped on the lines, looked all over for ammonia residue, cleaned out the gas orfices, has a nice flame, flue is clean.. I just bought a used Norcold to replace it.but would love to keep the original...The Norcold is a 323, the cheapest one that they make & I don't really like it... got any ideas?............ thanks for reading , Donnie Quote Link to comment Share on other sites More sharing options...
Donnie Posted May 21, 2014 Share Posted May 21, 2014 What "festivals" and what are you "playing"? Hello Zach, I play Bluegrass Guitar & play with a regional band near home, within a couple of hundred miles..I quit the band that I was playing with last 4th of July due to some trivial internal typical band BS & am now homeless, I MEAN bandless :-).....The front man just called me last week & asked if I want to play a few gigs this summer as the hot shot banjo player that was causing the conflict has left...I said I would. I also play some acoustic Blues with a local friend of mine..Coffee house stuff...Not a big deal...just a LOT OF FUN...thanks for asking..Donnie Quote Link to comment Share on other sites More sharing options...
Maineah Posted May 22, 2014 Share Posted May 22, 2014 On 5/20/2014 at 9:35 PM, Donnie said: Hello JD, maybe you have a tip for me.. I would love to keep the 3 way Dometic in my 78, but I've tried all the tricks that were suggested on you tube & by friends...super leveled the unit, took it out inverted, tapped on the lines, looked all over for ammonia residue, cleaned out the gas orifices, has a nice flame, flue is clean.. I just bought a used Norcold to replace it.but would love to keep the original... The Norcold is a 323, the cheapest one that they make & I don't really like it... got any ideas?............ thanks for reading, Donnie Pretty much if the boiler is hot is should work. Beyond that a new cooler unit. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted May 22, 2014 Share Posted May 22, 2014 Nice. I'm a banjo player but definitely not "hot shot". One of the reasons I bought my camper was to use at weekend jams where all the old folks have nice huge campers and I was sleeping in the back of my truck...Now I'm not quite so jealous. The Chinook would be perfect for hitting some of the big festivals with jam scenes, or for if I got solid enough to play solo. Quote Link to comment Share on other sites More sharing options...
Maineah Posted May 23, 2014 Share Posted May 23, 2014 Speaking about fridges I just install a D/C fridge for a friend today. I had all ways wondered about 12 volt compressors well guess what they aren't! Low and behold there is a little inverter inside that runs the compressor found this out when I pulled the wrong cover to land the 12 volt wiring. The compressor is 120 volt A/C I never could understand how they got the power figure so low on 12 volts now it all makes sense it's a very efficient dorm fridge with it's own inverter. Am I convinced? Nope I'll stick with my gas one it's much easier to carry gas than it is to make electricity I know my fridge will run a month or more on a 20 # tank. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted May 23, 2014 Share Posted May 23, 2014 Yep. Running on "high" almost constantly, and using my stovetop and occasional heat from the furnace, and my 20# tank lasts almost a month. And costs only around $7 to fill. Quote Link to comment Share on other sites More sharing options...
kayakthecoast Posted June 13, 2015 Share Posted June 13, 2015 My driveway is on an angle, so I shouldn't even run my dometic 3 way fridge on 110v while it's not level? Or is that ok? Sometimes I hook up the night before and get the fridge cold before travel. Does it need to be level running on electricity too? Quote Link to comment Share on other sites More sharing options...
linda s Posted June 13, 2015 Share Posted June 13, 2015 My driveway is on an angle, so I shouldn't even run my dometic 3 way fridge on 110v while it's not level? Or is that ok? Sometimes I hook up the night before and get the fridge cold before travel. Does it need to be level running on electricity too? Unfortunately yes. The problem with off level is the ammonia in the cooling unit doesn't circulate properly and crystals form and clog the pipes. It doesn't matter what source is heating it. Is the angle side to side or front to back. I can usually get mine level enough with the air bags, adding or removing air and some simple crank up levelers. Lay down some boards on your driveway, buy some of those yellow leveling blocks. If you use the same space all the time for your camper it's worth it to set it up so it's an easy drive on reasonably level space. Linda S Quote Link to comment Share on other sites More sharing options...
snail powered Posted June 13, 2015 Share Posted June 13, 2015 They have been making changes to the 12v compressors in the last few years to make them use less power so they can run more efficiently on solar. So the old units are not necessarily the same as those in previous years. I will have to discuss what you said about the converter in them with a local dealer in my neighborhood who sells and services the units that have Danfoss compressors. It will be interesting to see if that is still the case with the newer compressors such as the BD 35 series that is more efficient than previous technology and the newest model the BD micro. Danfoss was recently bought out and is now a company called Secop but for now they are using some crossover names to avoid confusion. The new micro sized compressor is 60 percent the size of the BD 35 and uses less power. They are using it to power travel boxes of 14 to 18 liter capacity. These are not thermoelectric units, they can be used as freezers. They are more energy efficient than previous versions of small portable 12 volt fridges. For now though it only looks as if Webasto is using that micro compressor. Seems like a good choice if you don't need a large fridge, want to be off grid on solar panels and don't have the room for a large battery bank. The Engel company that makes 12v fridges for recreation also has a different style compressor they call a swing motor that is energy efficient. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 13, 2015 Share Posted June 13, 2015 My driveway is on an angle, ... How much of an angle? Use a 4' level and measure how much of an angle you have. Quote Link to comment Share on other sites More sharing options...
zero Posted June 13, 2015 Share Posted June 13, 2015 On 7/23/2009 at 2:20 AM, estelle said: I am told by old experienced RV'r friends of mine that fridges in RV's rarely last more than 10 years..And that would be under perfect level conditions and with regular use. Hope that gives you something to go by...I am having to replace mine and when I do will keep it plugged in and going most of the time on low. If there is a strong ammonia smell when running... it is gonzo... I've got seven three-way refrigerators all working fine. The oldest is a Japanese-made Trav'ler that was made in1969. My newest is a Dometic made in 1986. I have three Dometic RM211s from 1976-78 Toyota Chinooks. Also a bigger Dometic from my 1971 Jayco that works great. I also have a German-made propane RV unit made in 1962. It also works. I have repaired many of these propane units with minor issues. I have never had one that needed an entire cooling unit Quote Link to comment Share on other sites More sharing options...
zero Posted June 13, 2015 Share Posted June 13, 2015 About angles . . we rarely if ever are able to find a flat-level camping spot and I never jack up our camper to make it level. So far, all my propane refrigerators have worked fine on slight inclines. My general rule-of-thumb has been - if the camper is level enough to sit in and sleep in, it's good enough for the refrigerator. I've never had my RVs so level that the bubble-indicators said I was "good to go." I bought my 1971 Jayco back in 1979 and it has a big Dometic three-way in it. I've had it on ground so uneven it would not cool - and I'd have to stick a board under a tire just to get the frig working. Been using that refrigerator for 35 years and haven't ruined it yet. Quote Link to comment Share on other sites More sharing options...
Maineah Posted June 13, 2015 Share Posted June 13, 2015 Even the fridge people say if you are comfortable so is the fridge. Quote Link to comment Share on other sites More sharing options...
snail powered Posted June 13, 2015 Share Posted June 13, 2015 You can measure slope using an app on a smart phone or tablet. Very handy gadgets! Quote Link to comment Share on other sites More sharing options...
kayakthecoast Posted June 14, 2015 Share Posted June 14, 2015 Thanks for the info I'll be prepping my fridge on the street from now on. Or might just throw in a dry bag full of ice before my journey! Quote Link to comment Share on other sites More sharing options...
Vanman Posted June 14, 2015 Share Posted June 14, 2015 Ours works super, once it gets cold, which takes a long while. I just throw some ice trays from our home reefer in there several hours before we go to pre-chill it. Quote Link to comment Share on other sites More sharing options...
