  • Hello Guest
  • Most Recent Three Posts
    • Very cool project, and I’ll be following for sure!
      Curious how you’ll run the (heavy gauge) power wires up to the new unit from your battery bank in a way that maintains the aesthetic of your very nice, custom rig.
    • Yup, had I known that basically all of the air moves out of the back of the unit I would not have used it in my build. I suppose it should have been obvious because of the direction that the fan motor spins and it then had to force air basically backwards and all the way through the plastic plenum to get out of the front of the unit. I even tried closing all vents except the front to get as much forward air flow as possible, unfortunately this restricts too much air flow and causes the coil to freeze over. I considered installing a 12V fan in the rear of the RV to blow more cool air forward, I think that would help a bit.
      I will definitely do a decibel meter test before removing the dometic, as well as a cooling test and of course power draw comparison.
      I set the 12V unit on the bench yesterday and did a quick bench test and was surprised with the airflow. It felt like plenty of cool air movement.
      My ultimate goal is to end up with 900 watts of solar on the roof (currently at 500) and be able to run the AC unit basically all day to keep the edge off in the camper, and of course a cool nights sleep.
    • I've read the thread (and sent Extech and Thewanderlustking messages about this job) and have a couple questions.  I have an 82 chassis.  I bought an 84+ chassis which has the big brake 6 lug front end.  It looks like you simply pull the entire 6 lug hub from the donor - leaving upper and lower ball joints on the donor.  Then install it directly onto your own Sunrader and the upper and lower ball joints simply fit. And all you have left is the brake caliper lines. Is this correct?
      Another question is I noted the 6 lug donor's front sway bar is thicker/stronger.  Has anyone also swapped this part over? The sway bar mounts to the lower suspension arm on each side, but I don't know if these suspension arms can be swapped...
      For clarity, I bought the entire chassis, so I have ALL the parts from the donor vehicle as of yesterday.  Thanks in advance.
      Edited by IdahoDoug
  1. Toyota Motorhomes
    1. General Discussion
      The place to discuss your Toyota Motorhome if the topic does not fit the categories below
      53.8k
      posts
    2. 30.2k
      posts
    3. Coach ApplianceTech Issues
      Got technical questions and or answers that do not fit in anywhere else? Like my coach lights will not work or my black water tank needs a new valve or how do I install a new water heater, how do I light my stove or what's wrong with my refrigerator?
      9.7k
      posts
    4. Electrical
      Electrically related problems, fixes and projects.
      12.4k
      posts
    5. Improvement and Do-It-Yourself Projects you have done to Share!
      Got an improvement project for your RV you would like to share, maybe even the step-by-step details? Then post it here for all to enjoy.
      Don't start new question topics here. This is for sharing projects in progress or completed.
      8.3k
      posts
    6. Whoops, Mishaps and Murphy's Law
      Have you had a misadventure or Murphy made an appearance or you did something really stupid and want to share it for learning purposes and maybe a good laugh? Then post it here!
      661
      posts
    7. Fuel Tanks
      Fuel tanks
      1.9k
      posts
    8. Communications and Electronics
      Cell phones - CB Radio - FRS/GMRS Radio - Ham Radio - Wireless Internet Access - Television - GPS - Backup Cameras
      680
      posts
    9. Reviews - New Products - Campgrounds - Links of Interest
      Share your review of products, campgrounds, service centers, and links of interest.
      850
      posts
    10. Pet Zone
      Our little buddies!
      274
      posts
    11. Rallies & Toy Ins
      Doing, Going or Been! Share the information here!
      1.1k
      posts
    12. RV CHOW
      Food, drinks, recipes and stuff
      347
      posts
    13. Miscellaneous & Non-related
      Share anything non-toyotahome related (AND NON POLITICAL). Let your imagination run wild!
      1.3k
      posts
    14. Trip Reports
      Gone or going on a great trip that you would like to share with everyone? Let's hear about it!
      1.6k
      posts
    15. News - Forum Help & Discussion
      The latest in what's happening around here. Need help with the forum? Need help uploading images or changing an avatar? Have suggestions or feedback to offer?
      637
      posts
  • Forum Statistics
    13.3k
    Total Topics
    124k
    Total Posts
  • Gallery Statistics
    3k
    Images
    12.9k
    Comments
    364
