Sossy Posted November 14, 2023 Share Posted November 14, 2023 I'm having a hard time locating a 1 ton Toyota full floater but I found a Chevy 14-bolt full floating axle off of a 1979 K20 and it's geared in either 4.10 or 4.56 (seller unsure). I think this should work out okay for my 1984 Sunrader but I'm a little over my head in this axle stuff. Does anyone see any problems with this idea? Quote Link to comment Share on other sites More sharing options...
extech Posted November 14, 2023 Share Posted November 14, 2023 bolt pattern will be different front to rear. spring perches will need to be moved, u joints not compatible, width? Quote Link to comment Share on other sites More sharing options...
extech Posted November 14, 2023 Share Posted November 14, 2023 bolt pattern will be different front to rear. spring perches will need to be moved, u joints not compatible, width? where are you located? Quote Link to comment Share on other sites More sharing options...
IdahoDoug Posted November 14, 2023 Share Posted November 14, 2023 Agree with Extech and the differential / U joint flange and driveshaft length will be a significant $$ issue. Where are you located? Quote Link to comment Share on other sites More sharing options...
fred heath Posted November 14, 2023 Share Posted November 14, 2023 https://toyotamotorhome.org/forums/index.php?/topic/8365-axle-swap-foolie-to-1-ton-full-float/#elControls_72800_menu I’ve done the swap. Read my link then I’ll try to answer any questions. Quote Link to comment Share on other sites More sharing options...
Sossy Posted November 14, 2023 Author Share Posted November 14, 2023 I'm in the greater Seattle area. The seller says it's 66" face to face. I saw that they sell some adapter plates for the drive line but I didn't consider length. I do hate the fact that id have to carry 2 spares.. Quote Link to comment Share on other sites More sharing options...
Sossy Posted November 14, 2023 Author Share Posted November 14, 2023 That looks really nice Fred I'm gunna have to check out your post when I can get to a computer later Quote Link to comment Share on other sites More sharing options...
fred heath Posted November 14, 2023 Share Posted November 14, 2023 10 minutes ago, Sossy said: I'm in the greater Seattle area. The seller says it's 66" face to face. I saw that they sell some adapter plates for the drive line but I didn't consider length. I do hate the fact that id have to carry 2 spares.. Is that 66” from drum face to drum face or 66” from o/s tire face to o/s tire face. The tire face measurement should be around 74”. If it’s 66” to o/s tire the axle is setup for dual wheels. If your going to single wheels the axle will be too short. Ask the seller for the o/s tire face to o/s tire face measurement. It should be 74-75” for single wheels. When I did my swap there was no driveshaft adapter to fit the spicer 44 u-joint (which is what the 14 bolt used) so I had a new driveshaft fabricated to fit. It cost around $300 in 2015. You will need to carry two spares. The only other caution is record your pinion angle BEFORE removing the foolie axle. You will need this for the new axle. Unless you’re a skilled fabricator, its best to find a shop that does this type of work. Prices will vary but expect to spend $3-4K for a turnkey setup. Cheaper if you can do most of the work yourself. I’ll try to answer your questions to the best of my memory. It’s been 8 years since I’ve done that job. Quote Link to comment Share on other sites More sharing options...
IdahoDoug Posted November 15, 2023 Share Posted November 15, 2023 Fred, I just read your post - super clean and nice swap!!! I used to work for GM Corporate back in the day. So, Sossy - I know of a Toyota 1 ton dually axle here in N. Idaho that I looked at and it's a good one. I think it's around 80k miles and if you have a way to come get it (a Class III hitch and one of those metal platforms would handle it I think) let me know and I'll connect you. Quote Link to comment Share on other sites More sharing options...
Sossy Posted November 15, 2023 Author Share Posted November 15, 2023 Doug, I'd be very interested in that. I have family in Spokane and Bayview that could help me coordinate things as well. Quote Link to comment Share on other sites More sharing options...
IdahoDoug Posted November 15, 2023 Share Posted November 15, 2023 PM me your phone and I will connect you. Quote Link to comment Share on other sites More sharing options...
IdahoDoug Posted November 15, 2023 Share Posted November 15, 2023 Axle guy's phone number in your PM. Good luck! Quote Link to comment Share on other sites More sharing options...
