Muffler needs to be replaced. Cut it off today. Hope I didn’t mess up. Should I try to remove the weld and reuse the pipes?
Edited by hamkid
depends on what tools you have. i would use a cut off tool to remove the weld, then slit the muffler tube to get it off the tube you want to save
Just cut the weld off. You want to end up with the same length to that turn in the pipe. Motorhome exhaust pipes were often custom made to fit the required space and to stay away from holding tanks. There are lots of extensions you can use to make it match. Muffler itself can go forward or back a little so you only use 1 extension.
exhaust pipe extension - Google Search
Got it all off! Used cutting tool, hammer and chisel. Any suggestions for type of muffler? My nephew loves helping out!
Edited by hamkid
i have a 30 inch glass pack. not loud and free flowing
What brand? Any thoughts on Magna Flow products?
I use a muffler that was for a Ford F250 pickup with a 460 cid and a single exhaust. On my little 4 banger no major back pressure and no noise. I use stock Toyota exhaust in to the muffler and I think it was 2.5" out all the way the behind the rear axle.
Looking to buy this muffler. Do I buy the 2.5 and 2.75 diameter clamps?
Edited by hamkid
no. the outlet is 2.25 od . thats the size for it.
  does your truck pipe fit into or over the inlet. that determines the inlet side clamp
First pic is inlet, second pic is outlet. The thing I’m confused about is the inlet size of the muffler which has 2.625 inch inside diameter. Would the 2.5 inch clamp be too small?
Edited by hamkid
you need a muffler with 2in id inlet and outlet
It has to be 2 inches exactly, the muffler I posted won’t work?
yea. the muffler needs to fit your pipes
Yes 2" ID, not to sure about the clamps you posted.
I went to a muffler shop. They have both stretcher and shrinker hydraulic powered. So the muffler fit perfectly.
P.S. the stock is 2.5" inlet and outlet
  • 4 weeks later...
