DanDanLongDan Posted May 30, 2017 Share Posted May 30, 2017 Wasn't a fan of the looks of the storage box that came with the motorhome. I'm going to rip it out and likely redo it with a much cleaner look to it. Probably raise it up to the bend so when the lid opens it doesn't hit the back. Took the lid off today and will remove the rest tomorrow or the next. I think I may move the spare wheel inside the box or see if it can go back underneath. I'm thinking it may not fit underneath as the black tank has been upgraded to a larger size. Quote Link to comment Share on other sites More sharing options...
DanDanLongDan Posted June 1, 2017 Author Share Posted June 1, 2017 A whole bunch of Robertsons and some type of adhesive. Nothing a cordless driver and a BFH can't fix. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 1, 2017 Share Posted June 1, 2017 Be very careful with those angle brackets your tail lights go into. Not replaceable Linda S Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 1, 2017 Share Posted June 1, 2017 I actually liked that storage box. Seems well made especially if it could support the heavy spare tire. Just me I guess. Quote Link to comment Share on other sites More sharing options...
DanDanLongDan Posted June 1, 2017 Author Share Posted June 1, 2017 It wasn't well made. Random checkerplate, random old garage door, random threshold/transition strips. Looked like Sanford and Son. It wasn't wife approved. The new one will be much cleaner looking. Stay tuned. Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted June 1, 2017 Share Posted June 1, 2017 Look forward to it! Quote Link to comment Share on other sites More sharing options...
donttreadonme Posted June 2, 2017 Share Posted June 2, 2017 Tear off was the right thing to do. Onward and upward! Was the bumper extended with 3 inch channel? The previous owner of my rig extended the supports for the rear bumper with 2 pieces of wood bolted to the frame and then bolted the bumper to the ends of the wood. It was extended about the same amount that yours was. He installed an aluminum box on the platform and added boards to the ends. The tail lights are visible (from some angles) I plan to rework the wooden frame extensions with metal and add a bike rack. Quote Link to comment Share on other sites More sharing options...
DanDanLongDan Posted June 2, 2017 Author Share Posted June 2, 2017 I'll show pics later. There is a hitch added as well as some stabilizers. I'm not sure if it was carried all the way back. The weld need some more work. I'm just removing what isn't needed and I'll clean up the rest before I start with the storage box. Quote Link to comment Share on other sites More sharing options...
86rader Posted June 2, 2017 Share Posted June 2, 2017 I would like to do something similar to my Sunrader, but it will be removable. I want to make it a little taller than that was and slightly deeper. I would like to have a dry place to keep a few bikes. My plan is to make it out of thin plywood with a fiberglass coating. Should be strong enough, weatherproof and hopefully look like it belongs there. Quote Link to comment Share on other sites More sharing options...
donttreadonme Posted June 2, 2017 Share Posted June 2, 2017 This is how my bumper storage is done. That really is wood holding the whole platform up. Quote Link to comment Share on other sites More sharing options...
DanDanLongDan Posted June 3, 2017 Author Share Posted June 3, 2017 Spent a little bit of time with a grinding disc and a Crud Thug. Cleaned up nice once I removed the white house paint underneath the black top coat. Sprayed on some POR15 and looks great. Ready to make the storage box. Just have to decide if I go with box with lid that runs up to where the angle changes. That might be too high for some to reach in without a stool. The other choice would be a boxed in top but with doors opening rearward. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 3, 2017 Share Posted June 3, 2017 Wow is that power leveling jacks I see. Linda S Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 3, 2017 Share Posted June 3, 2017 I see no power leveling jacks. I see the old wiring that used to go to the rear lights. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 3, 2017 Share Posted June 3, 2017 Oh yeah, silly me Linda S Quote Link to comment Share on other sites More sharing options...
WME Posted June 3, 2017 Share Posted June 3, 2017 If its height to be to the angle then I think that doors would be the better idea. Other wise its going to be like a chest freezer with all the good stuff on the bottom . Quote Link to comment Share on other sites More sharing options...
hunkaman Posted June 3, 2017 Share Posted June 3, 2017 here is my two cents-- how about double doors hinged to open up (top door) and down (bottom door) possibly utilizing small gas struts to hold top door in "open" position. would provide very easy access to contents of box. with your taillight wiring so close, you could incorporate lighting inside box as a convenience at night just another thought. joe from dover. Quote Link to comment Share on other sites More sharing options...
bubblecuffer Posted September 21 Share Posted September 21 Dan, I have a 1992 Toyota class c that looks just like the one in these photos. I have not been able to actually determine what model it is. The folks who are the official dealer for Winnebago parts, I can't remember their names right now, told me when I gave them the VIN that it was a " one off" meaning it was some kind of special order perhaps. Anyway I found that most of the warrior parts that I've purchased fit pretty well but I sure would like to know if one that looks like ours do, with identical graphics and color are actually some kind of particular model. Any info you could provide would be greatly appreciated. Thanks very much, Mark Quote Link to comment Share on other sites More sharing options...
linda s Posted September 21 Share Posted September 21 Helps to pay attention to the date things were posted. These are from 5 years ago and Dan hasn't visited us since then. As for the model of your Winnebago, if it looks like this it's a "Toye". Printed right on the side of it. The Toye's were a lower priced model with supposedly cheaper upholstery and finishes. I really don't think they looked that much different than the other models. Welcome to the group Linda S Quote Link to comment Share on other sites More sharing options...
psxpak Posted September 22 Share Posted September 22 it is old lol, but dude, that box he had was pretty sweet. i woulda refteshed that thing. i need somehhing for sure, i just cut my bumper off today and sandblasted, skim coated with filler, primed and painted. extending out for maybe an aluminum box seing as i gotta weld back in the bumper. i took a week vacation since rains voming hete in the PNW, trying to get her wrapped up. although i find with all of the classic cars ive restored you're never TRULY done. Quote Link to comment Share on other sites More sharing options...
