All Activity
- Yesterday
Isaac77 joined the community
- Last week
Frozensurfer71 joined the community
Margaret M. joined the community
1993 winnebago itasca. Plumbing leaking - Pull Ring Valve - Help needed
Pbarr replied to Pbarr's topic in General Discussion
Thanks Jed. I am super new to the RV world and have not an idea of which one to buy. I dont expect you to give me the right part number but do you know who could? -
Pbarr started following 1993 winnebago itasca. Plumbing leaking - Pull Ring Valve - Help needed
I have a 1993 winnebago itasca and these pull rings are leaking. Well one of them is leaking. I dont really know where line goes that is surrrounded by the black gum like substance they go but I assume I have to cut the wood as they go downward into the wood. Anyway I was hoping someone could point to the replacement part as I know they dont make it anymore for the pull ring valve replacement system as I need to stop the leak as the pull ring is leaking quite a bit. thanks in advance for any help.
Pbarr joined the community
Thank you Fred. Appreciate ypur help very much. Marse
The dinosaur boards come with instructions. It’s pretty much “plug & play”. Your factory board will be enclosed by some type of external case. You must open this up to access the board itself. The dinosaur board arrived as just a printed circuit board. You can install it in the factory case or dinosaur offers new cases designed for their product. You will find a 4 or 5 pin connector. Unplug the old, install the new.
The Dinosaur UBI S ignitor board was recommended by Dinosaur for my Suburban DD 17DSI furnace to replace my 231741 (Part NO.) modual board. Has anyone had this replacement done? Thank you.
Jabba53e joined the community
RTP joined the community
bigstar started following 1985 Toyota dolphin muffler tailpipe
Just bought a 1985 toyota dolphin. The tailpipe that extends from the muffler to the back appears to be missing. The muffler stops between the front and back wheels. I'm trying to figure out where i should hang the new extension pipe when i attach it. Mainly, I'm hoping to find a photo of what it should look like. I've never done this before and want to do it right. Can anybody either show a photo beneath their dolphin or point me to one as I'm not able to find one.
I just want to add that I had this very same problem with replacement tanks 10 years ago! I did get my money back after trying 2 and having same leak. Then I had a mechanic spot weld the leak points on the exterior and that held.
mattrblack50@gmail.com started following Rear camera
Sherribeach joined the community
We used stained Luan to replace wall and ceiling panels. If you are on a budget, take the time to separate the panel from the insulation. Otherwise get some sheet foam and cut to fit. We used a pneumatic stapler to attach panels. Consider upgrading the cab over lighting whilst you have the panels off. On a 1989 Dolphin, at assembly it appears the roof was put on after the walls were finished. We used a quarter-round on the transitions to hide any mis-match. Cabinets come off pretty easily. Be sure to measure/mark/ identify where wiring penetrates panels. Take lots of pics!
Check with Dinosaur Electronics. They make custom boards for many furnace applications. If you know the factory part number, they have an interchange data base. If not, you can search by manufacturers model number. I have an unused Dinosaur UIB-L board kicking around the shop somewhere. If it’s a match it’s yours for postage.
Need recommendations: My furnace starts as it should but shuts off abruptly after 2 seconds of operation. I replaced the time delay sw and the limit sw to no avail. All wiring is correct. Blower performs robustly and burner lights immediately with good blue flame. I suspect the modual board is shutting the gas immediately. Do I need a new Modual board? If so any recommendations on source. My board p/n is 231741. I have a Suburban furnace model DD 17DSI. Thanking you in advance. Marse.
- Earlier
bigstar joined the community
Thanks for sharing, I need to replace the sides and front, inside forward due to unseen water leakage. It's just a matter of finding cardboard to make a template, then thanks to your info finding the correct material. Not looking forward to it, but I know in the end it'll add value to the RV. Mine is an 89 model with a fuel injected six cylinder with 85 thousand original miles.
I'll second, er third the Everstart MAXX at Walmart. Good battery - did well in the last test I looked at 5 years ago, plus great return policies. I literally have 9 of these in various vehicles I have.
Ctgriffi started following Battery Recomendations
The Maxx starting battery in my Warrior was also 11 years old when I finally replaced this year. Not so sure it was even really dead/gone at that point…
XED joined the community
I've always bought the Everstart Maxx both for deep cycle and engine starting batteries. Always lasted a very long time. Last summer I bought a regular Everstart deep cycle because the Maxx was no longer available. I haven't had any problems with it. I think the down grade was warranty related. People use them in boats and drain them completely and a 3 year warranty is too long for something so easy to abuse. They still make the Maxx for car starting batteries. First one in my Sunrader was 11 years old when I finally needed to replace it. Linda S
Worst to best battery technology, FLA $$(flooded lead acid) comes in 3 types... Automotive start, Combo Marine Start-deep cycle, true deep cycle (golf cart) 50% safe max life discharge AGM $$$(adsorbed glass mat) comes in auto start and deep cycle 70-80% max discharge LifePo4 $$$ (Lithium) NOT for starting, great for deep cycle. 100% max discharge Ease of install worst to best. LifePo4. "They" make "plug n play" LFP batteries, 100AH GP size 24. BUT factory converter will only charge to 80%, a deeply discharged places a heavy load on the factory alternator. Proper install $$$ includes a new converter, or solar, and a DC 2 DC charger to protect the alternator. AGM and FLA are equal truly plug n play. Just get the biggest one that will fit in your battery box
I have had a lifelong policy of simply stuffing the largest battery in the battery box that will fit in all my vehicles. Google an automotive battery sizing guide chart and it will also provide the connection locations and type to guide you in your purchase.
ka6uup started following Battery Recomendations
I have a 91 Toyota Itasca rv. Based on comments here I went to Walmart and bought one of their Everstart Maxx batteries. After about 3-4 months 2 cells shorted and I went back to get a replacement. Unfortunately they had discontinued that battery and insisted they would not refund my money but I had to take a substitute battery. I did so and performance has been marginal. We are planning in a trip back east and I would like to pick up a better battery. What are some of the choices?? Thanks, Chuck
Thanks Linda , I will get this and try . Will let you know :):)
Ah, too bad. Yeah outside is tough.
