jimBOW Posted December 2, 2016 Share Posted December 2, 2016 Hi New to this forum and new to Toyota MH - recently purchased a 1987 Odyssey with a 22RE engine with 80K - we knew it needed some work on the interior (done) and in the engine (in process) - My mechanic gave me a list of things it needed and some of it I can do myself - other stuff will need mechanic - so my question is regarding shocks - it needs new shocks all around and I know little to nothing about shocks for a small MH - this rig came with a detachable carrier in the rear and I would like to carry a small motor bike on that for longer trips (225lbs) Would purchasing Air Shocks help with that additional weight in the back? Also have read about it being a wise investment to add an tranny cooler (auto) and does anyone have suggestions on what type I should get and guesstimate cost? tx jimBOW Quote Link to comment Share on other sites More sharing options...
linda s Posted December 2, 2016 Share Posted December 2, 2016 Our trucks take a stronger shock and most also have air suspension bags in the back. Here are some examples of the shocks and the air suspension. I'm very surprised yours doesn't already have the air bags. Don't think I've ever seen an Odyssey without them except for the much older ones. Air shocks are not recommended. They put too much stress on the shock mounts http://www.shockwarehouse.com/index.cfm?mode=results&selected_model=4485&selected_year=1987 Airlift is the air bag system. Bilsteins are the most recommended shock but I also like the KYB. You can just take down the model numbers from here and then shop around. Might find lower prices elsewhere. Funny I thought by 87 the cab and chassis had a stock trannie cooler too. Linda S Yup came standard with a trannie oil cooler. Weird that someone took yours off. http://www.toyotapartsdeal.com/oem/toyota~cooler~assy~oil~32910-35020.html?Make=Toyota&Model=Pickup&Year=1987&Submodel=&Filter=(d=USA;1=22REC;3=T1;7=RCB;9=HVY;10=WT;12=EFI;13=IV)&Location=oil-cooler-tube-atm,,32910 Quote Link to comment Share on other sites More sharing options...
hunkaman Posted December 2, 2016 Share Posted December 2, 2016 linda s , went to the shock link you provided . i was wondering in your opinion, are the bilsteins ( set of four ) over the monroe's worth the nearly 3 times $$ amount ? thanks for your reply. joe from dover Quote Link to comment Share on other sites More sharing options...
linda s Posted December 2, 2016 Share Posted December 2, 2016 My son-in-law put Monroe's on my Explorer a while back and they are terrible shocks. My fault, he knows I'm cheap so he got the cheapest ones and I didn't specify. Not cheap when you have to replace them after 2 years cause they are shot. Like I said, shop around with the model numbers. There are slightly cheaper ones to be found. I also have KYB's on my Sunrader. Way past replacement time now but they lasted over 10 years in the time I had it. They might have been much older. So if you want to go cheap go KYB Linda S Quote Link to comment Share on other sites More sharing options...
hunkaman Posted December 2, 2016 Share Posted December 2, 2016 i'll check out the KYB'S thanks Quote Link to comment Share on other sites More sharing options...
jjrbus Posted December 2, 2016 Share Posted December 2, 2016 (edited) 2 hours ago, hunkaman said: linda s , went to the shock link you provided . i was wondering in your opinion, are the bilsteins ( set of four ) over the monroe's worth the nearly 3 times $$ amount ? thanks for your reply. joe from dover If you plan on keeping your rig forever and doing some off roading with it the Bilsteins have a limited lifetime warrenty and are worth it. The KYB's have a 50,000 to 60,000 mile life expectancy and are a good choice for most. I bought the KYB's and am happy with them. I did not look at Monroe so have no idea. HTH Jim Edited December 2, 2016 by jjrbus Quote Link to comment Share on other sites More sharing options...
hunkaman Posted December 3, 2016 Share Posted December 3, 2016 THANKS FOR THE INPUT--DOUBT IF I WILL BE OFF ROADING, AND ALSO DOUBT I WILL PUT OVER 50,000 MILES ON MY RIG. SO THAT BEING SAID , THE KYB'S SHOULD BE OK WITH ME, UNLESS THEY ARE REALLY CLOSE IN PRICE TO THE BILSTEINS, THEN I MAY SPEND THE DIFF AND GO WITH BILSTEINS. HAVE NOT PRICED KYB'S YET. JOE FROM DOVER Quote Link to comment Share on other sites More sharing options...
linda s Posted December 3, 2016 Share Posted December 3, 2016 34 minutes ago, hunkaman said: THANKS FOR THE INPUT--DOUBT IF I WILL BE OFF ROADING, AND ALSO DOUBT I WILL PUT OVER 50,000 MILES ON MY RIG. SO THAT BEING SAID , THE KYB'S SHOULD BE OK WITH ME, UNLESS THEY ARE REALLY CLOSE IN PRICE TO THE BILSTEINS, THEN I MAY SPEND THE DIFF AND GO WITH BILSTEINS. HAVE NOT PRICED KYB'S YET. JOE FROM DOVER The prices for the KYB's are on that same link I posted. Very important to get the motorhome ones. Not the same as regular truck ones. Price for KYB's is 142 compared to the Bilstein 307. Less than half price and that's for all 4 shocks Quote Link to comment Share on other sites More sharing options...
hunkaman Posted December 3, 2016 Share Posted December 3, 2016 thanks linda s , i apparently missed the kyb price info when i looked at the link. also thanks for the heads up between regular truck and mh shocks. joe from dover Quote Link to comment Share on other sites More sharing options...
RVdaytrader Posted December 3, 2016 Share Posted December 3, 2016 This place has the Bilsteins for $65.00 each, free shipping http://www.ajusa.com/Bilstein-24-184830-B6-4600-Shock-Absorber-ab0478.html Quote Link to comment Share on other sites More sharing options...
linda s Posted December 3, 2016 Share Posted December 3, 2016 Super deal thanks for finding that. I haven't heard of that place before. Now that we can shop the world online we kind of have retailers at our mercy. Linda S Quote Link to comment Share on other sites More sharing options...
Derek up North Posted December 3, 2016 Share Posted December 3, 2016 FWIW, I bought from AJUSA probably 15 years ago with no problems. No idea if they've changed since, but at least they've been around for a while. Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted December 3, 2016 Share Posted December 3, 2016 I ran both air bags and Gabriel air shocks on the rear of our Gulfstream. Someone had told me that air shocks were a bad choice as they could break off the shock mounts. That never happened. Maybe if I had just ran the shocks and no bags it would have been a problem. Anyhow I ended up with a very stable, absolutely no side to side rocking when going down the road or in corners. I installed the airbags myself. They were the type where the axle mount fastened under the axle U-Bolts. Had to cut the U-Bolts off with a sawzall. Once cut through they popped like a gun going off. The whole project is not easy and somewhat dangerous. Not suggested for those who do not have the proper equipment to support the truck. Note: The air bag kit I went with did not come with new U-Bolts. Quote Link to comment Share on other sites More sharing options...
