jjrbus Posted August 4, 2015 Share Posted August 4, 2015 I Believe it was Derek that asked about my tranny temp. I just did about 7 miles on a 92 degree day at 55 mph and the gauge read 120 degrees by the time I got home. The sensor is in the external filter past the radiator cooler and the aux cooler on the return to the tranny. Jim Quote Link to comment Share on other sites More sharing options...
linda s Posted August 4, 2015 Share Posted August 4, 2015 So the reading your getting is after it's been cooled. I think most people prefer to get the reading coming out of the tranny Linda S Quote Link to comment Share on other sites More sharing options...
jjrbus Posted August 5, 2015 Author Share Posted August 5, 2015 I have no idea, that is the way it was set up when I bought it. Likely not too hard to move some hoses around and run fluid in opposite direction. Jim Quote Link to comment Share on other sites More sharing options...
linda s Posted August 5, 2015 Share Posted August 5, 2015 I don't know for sure. I don't have a temp gauge on mine. Thought someone else would step in a correct me by now Linda S Quote Link to comment Share on other sites More sharing options...
Vanman Posted August 5, 2015 Share Posted August 5, 2015 I would put a sensor coming out of the tranny and put in a switch so I could tell both temps.I think someone here has done this and posted their temps??? , a while ago. Quote Link to comment Share on other sites More sharing options...
zero Posted August 5, 2015 Share Posted August 5, 2015 Transmission temp sensors are usually installed to monitor how hot the trans is getting and not how cool the cooler makes the oil after it leaves the trans. A normal working trans runs at the same temp as the engine coolant except when being worked extra hard like climbing hills. I.e. around 190 degrees F is optimal. Quote Link to comment Share on other sites More sharing options...
Maineah Posted August 5, 2015 Share Posted August 5, 2015 Inside the pan is the best place for a temp sensor it is what the trans is using to do it's job. Quote Link to comment Share on other sites More sharing options...
Donnie Posted August 5, 2015 Share Posted August 5, 2015 Why not install a temp sender in the pan too & leave the one in the cooler line---- connect it to a double throw toggle switch, then you can read the working temp that the trans is using>>> flip the switch to read the cooler return flow.. Then you can also see how well your cooler is doing??? donnie Quote Link to comment Share on other sites More sharing options...
jjrbus Posted August 5, 2015 Author Share Posted August 5, 2015 Curious is there any non invasive or surface mount temperature senders available? Jim Quote Link to comment Share on other sites More sharing options...
Maineah Posted August 6, 2015 Share Posted August 6, 2015 The cooler line dumps the oil back in the pan it is not under pressure it just returns to the pan at a pretty fair rate. Yes there is pressure on the line do not block it or you will blow the rubber hoses off but it's only working pressure is friction in the cooler lines so the oil in the pan is oil that came from the cooler it is representive of trans temp in use. If you feel a need to find out how hot the oil is leaving the trans then you need a sensor in the discharge line from the trans before the cooler. It would kind of be a moot point because that is where all the heat is after the fact it is waste heat uncooled. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted August 6, 2015 Share Posted August 6, 2015 I believe there are sensors that wrap around the output line to cooler. you want to know how hot the fluid is. if the cooling is working well it will not be too hot coming out . With the wrap around or other not intrusive method, the atf lines do not have to be messed with. The sender unit gets the heat from the line Quote Link to comment Share on other sites More sharing options...
shibs Posted August 6, 2015 Share Posted August 6, 2015 Anyone use a drain plug sensor for the tranny? Quote Link to comment Share on other sites More sharing options...
Bob C Posted August 7, 2015 Share Posted August 7, 2015 I was wondering if anyone made a drain plug sensor. Does anyone have a part number and a gauge to go with it. Quote Link to comment Share on other sites More sharing options...
shibs Posted August 21, 2015 Share Posted August 21, 2015 http://forum.ih8mud.com/threads/transmission-temp-gauge-install-w-pics.214661/ Quote Link to comment Share on other sites More sharing options...
Vanman Posted August 21, 2015 Share Posted August 21, 2015 Great, now drain plug sensor for the oil??? we already know how to add a tach. Quote Link to comment Share on other sites More sharing options...
