mini-wini-dan Posted April 19, 2013 Share Posted April 19, 2013 Greetings, I just changed the fluid in my 4 speed automatic transmission in my 22rec fi in an 86 toyota mini-wini. What I have heard is to check while the engine is running with the shift in park. I have also heard that refill takes 3-5 quarts. Anyone had experience with this? Quote Link to comment Share on other sites More sharing options...
5Toyota Posted April 19, 2013 Share Posted April 19, 2013 YES CHECK WITH ENG RUNNING IN PARK WARMED UP IS BEST . DONT KNOW ON THE OTHER Quote Link to comment Share on other sites More sharing options...
mini-wini-dan Posted April 19, 2013 Author Share Posted April 19, 2013 Thanks-I put in about 3 qts. and got a good reading Quote Link to comment Share on other sites More sharing options...
linda s Posted April 19, 2013 Share Posted April 19, 2013 Thanks-I put in about 3 qts. and got a good reading Not good until you have put it in drive. Back up then forward and check again while running. 3 sounds low. Linda S Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 20, 2013 Share Posted April 20, 2013 Agree with moving it a bit before a final check. Then again after you've driven it far enough to get it warmed up to full operating temperature. As for how much to put in, my 1992 Owners Manual says "22R-E, Drain and Refill: 2.5 quarts". Quote Link to comment Share on other sites More sharing options...
WME Posted April 20, 2013 Share Posted April 20, 2013 As Derek says drain and fill is 2.5 qts and a dry fill (new transmission) is 7 qts. So 3qts is a bit off. Drive it a bit and recheck. To much fluid can be bad, so check carefully. Quote Link to comment Share on other sites More sharing options...
