Homer Posted October 2, 2016 Share Posted October 2, 2016 (edited) I am thinking that I may have to remove the fresh water tank. There is a smell coming from under the cabinet, do I need to remove the oven and range in order to take it out? The tank is under the sink in the rear of my 1986 Sunland Express over to right . I haven't looked lately but think part of it is under the oven. The drain valve is really hard to open and close (30 years old at least). Will see about replacing valve after I get the tank out. May have to patch a leak ! Have looked on ebay for tanks and some of them says "not pressurized " Are our tanks pressurized or is it just from the pump into the lines? I know I am asking a lot but I thought some of you have done this before and know how this is accomplished. I haven't measured it but former owner put some specs. on back page and said that the fresh water tank holds 13 gallon. What is holding the oven in place ? Any suggestions will be appreciated. HOMER Edited October 2, 2016 by Homer Quote Link to comment Share on other sites More sharing options...
RVdaytrader Posted October 2, 2016 Share Posted October 2, 2016 First make sure your air admittance valve is good...if that is not sealing good you will get a smell. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted October 3, 2016 Share Posted October 3, 2016 now I am in the dark what is an air admittance valve Quote Link to comment Share on other sites More sharing options...
linda s Posted October 3, 2016 Share Posted October 3, 2016 1 hour ago, 5Toyota said: now I am in the dark what is an air admittance valve Holding tank vent. Ya know the ones that run up to the roof. At least that's what I think he means Linda S Quote Link to comment Share on other sites More sharing options...
RVdaytrader Posted October 3, 2016 Share Posted October 3, 2016 the air admittance valve is under your sink, installed in the drain line after the P-trap...it lets air into the line so your trap does not get siphoned out when you drain your sink...if it wears out it does not seal good and lets fumes from your tank escape. http://www.homedepot.com/p/Oatey-1-1-2-in-ABS-PTC-In-Line-Cheater-Vent-39012/100204205 Quote Link to comment Share on other sites More sharing options...
linda s Posted October 3, 2016 Share Posted October 3, 2016 Come again? We have real plumbing vents in our RV's just like a house. No cheater vents anywhere on my rig Linda S Quote Link to comment Share on other sites More sharing options...
RVdaytrader Posted October 3, 2016 Share Posted October 3, 2016 51 minutes ago, linda s said: Come again? We have real plumbing vents in our RV's just like a house. No cheater vents anywhere on my rig Linda S Linda....my black and gray tanks have vents that go up through the roof...under my kitchen sink, after the P-trap there is a air admittance valve...its purpose is to prevent draining water from siphoning the water from the traps. Quote Link to comment Share on other sites More sharing options...
linda s Posted October 3, 2016 Share Posted October 3, 2016 Not on mine and never had a problem. I have 3 motorhomes. Not on any of them Linda S Quote Link to comment Share on other sites More sharing options...
RVdaytrader Posted October 3, 2016 Share Posted October 3, 2016 Here is a pic of my under kitchen sink plumbing....u can see the AAV installed. Quote Link to comment Share on other sites More sharing options...
linda s Posted October 3, 2016 Share Posted October 3, 2016 Very clean new looking pipes. bet it didn't come that way. All the references I see online about that extra vent are referring to newer motorhomes and most of them big ones. Linda S Quote Link to comment Share on other sites More sharing options...
Homer Posted October 3, 2016 Author Share Posted October 3, 2016 RVdaytrader: Thanks for the suggestion of the Admittance Valve. On Sunday I looked up what it was and then went to under my sink and unscrewed the valve and looked in the bottom of it at the rubber disc, it had some kind of bugs on it. I sprayed kitchen 'all purpose cleaner with bleach' in there and let it set for awhile then ran hot water on it and cleaned it out real good then replaced it on the stand pipe. I will have to wait and see if in fact this was the culprit. Thank You for the suggestion , I really didn't know there was one under the sink. Maybe someone else can read this and clean theirs before things take place. homer Quote Link to comment Share on other sites More sharing options...
5Toyota Posted October 9, 2016 Share Posted October 9, 2016 (edited) now I recognize it the term threw me I new they were an auto vent. have some in my 1996 double wide . don't recall any in my dolphin will have too look. and yes I still have some real vents on my house also Edited October 9, 2016 by 5Toyota add text Quote Link to comment Share on other sites More sharing options...
