kayakthecoast Posted July 7, 2016 Share Posted July 7, 2016 I just noticed at 102k miles, I'm hearing a slight knocking sound from engine. I have not had anything done on my engine or tuneup in 2 years. I'm due for a 5000 mile oil change. Any advice before I take it in. These engines need a timing belt done? I have not been using much this summer since winter. Quote Link to comment Share on other sites More sharing options...
fred heath Posted July 7, 2016 Share Posted July 7, 2016 Does it do it all the time or just under acceleration? Quote Link to comment Share on other sites More sharing options...
zero Posted July 7, 2016 Share Posted July 7, 2016 8 hours ago, kayakthecoast said: t These engines need a timing belt done? No, there is no belt and a loose chain would not "knock." Is it worse at first start up? Turbo Isuzu 2.2 diesels were known for having rod bearings and piston pins wear early and knock. I don't know if Toyotas with turbos suffer the same fate. No real "knock" is good if it increases with RPMs. Might want to pull the drive-belts off the engine and spin everything to make sure it's not something external (I doubt it) - like an alternator bearing, AC pump bearing, water-pump bearing,etc. Quote Link to comment Share on other sites More sharing options...
Maineah Posted July 7, 2016 Share Posted July 7, 2016 If it rattles at or slightly off idle then chances are pretty high it's chain rattle usually the chain and guides start to go some where around 100 to 150K on the RE engines it would be noticeable sitting still. If that is what you are hearing don't ignore it the chain will eventually beat a hole in the timing chain cover and flood the sump with antifreeze. Quote Link to comment Share on other sites More sharing options...
kayakthecoast Posted July 7, 2016 Author Share Posted July 7, 2016 Yes it's noticeable at idle just very slight knocking. Thanks for the info all. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted July 7, 2016 Share Posted July 7, 2016 Most times timing chain noise is described as a 'rattle'. Noises are hard to describe. Thank goodness for YouTube. Quote Link to comment Share on other sites More sharing options...
kayakthecoast Posted July 8, 2016 Author Share Posted July 8, 2016 Perfect thanks! Quote Link to comment Share on other sites More sharing options...
kayakthecoast Posted July 27, 2016 Author Share Posted July 27, 2016 (edited) Today I noticed my engine manifold had cracked and was the main culprit of the rattle! But now that I fixed that I still think my timing might be a little off and probably should pull my valve cover, replace the chain guide and check valve gaps. Can I use a timing gun on this engine? And adjust? Edited July 27, 2016 by kayakthecoast Quote Link to comment Share on other sites More sharing options...
WME Posted July 27, 2016 Share Posted July 27, 2016 (edited) I think the drill should be set timing (easy peasy), adjust the valves, THEN replace the timing chain. IF the problem persists. Edited July 27, 2016 by WME Quote Link to comment Share on other sites More sharing options...
