Chg Light On Need Help Diagnosing
mobilehippo
I have 1978 Odyssey. I was driving back from a short camping trip and went to stop for some gasoline. Turned down my a/c and brought her into station. Filled her up. Started her up and noticed something wrong. The CHG light started glowing when I started her. Then I noticed that even though my emergency brake was engaged, the light was off. Also my gas gauge wouldn't go up correctly. I was still able to start her and drove her back 30 miles but the CHG light was on the entire time.
I have no idea what's going on. The alternator is a year old so I don't think that's it. Most of the electronics is working, like the radio, turn signals and such when I drive with her. The A/C though is definitely not working though but it was also changed replaced last year. Could it be the belts are lose?
Was wondering if anyone could help me diagnosis!
Thanks!
Fuel gauge in the older trucks like your's rely on full system voltage of 12-14.5 volts to read correctly. So does the engine temp gauge. From what you describe - sounds like low voltage caused by the alternator not working. That can be caused by a defective alternator or a bad external regulator. The ignition system can work with voltage down as low as 8 volts so it would keep on running for quite a while.
I think yours is old enough to have an external regulator so if it is not charging it could be either. The newer ones had the regulator inside of the alt. so this makes the testing a little more complex. You might check the 15 amp engine fuse but I doubt it is the cause because a lot of other things would not work.
Well mine did that on our first trip. Why does the brake light come on with the charge light? Apparently just to drive you crazy and make you think it's something else beside the alternator. At least that's what it did to me. But it was the alternator. Now you might have to figure out why the alternator failed so soon. I hear some of those older alternators are real easy to fix. Just new brushes. If you know someone who does that.
Is there anyway to decipher if it's the alternator or regulator not working?
Yes. The regulator sends field current to "excite" the magnets inside the alternator. Just takes a simple volt-check at the alternator field connection. If it's getting field-current but not charging - the alternator is bad. If it is NOT getting field current - the regulator is bad.
My 1978 has an internal regulator. Sounds like your alternator is bad.
Just replace the whole thing.
Hello!
I just did a basic multimeter check with my battery and when I turn the engine on, the battery will spike up to 15 volts. So I believe the alternator is working and perhaps the regulator otherwise the battery charge wouldn't have gone up.
I don't know what this means exactly cause my CHG light is still on but maybe there is some faulty wiring going on. My A/C won't turn on and when I turn the knobs the CHG light glows very bright. I might have to take her into the shop I guess.
Yeah it sounds like you have got some battery connection or grounding issues some where.
I don't know what you have but the Toyota factory wire-diagram book for model year 1978 trucks in USA and Canada are only shown with external regulators and 45 amp alternators.
no 1978 was originally fitted with an internal regulator alternator. I have had three of that vintage
Question what color was you plug in the back of the alt.? and was it round? I'm trying to get my head around this can't remember but I believe the external regulator had a round plug in and it was green.
green yes I am thinking two wires or 3 not round the regulater plug is round I think and should be on the fender well a black box the org is mecincal viberater point type and you could buy a solid state type smaller and flatter . but I had better results with oem type used to use a bosch back then. the reg plug was green also but bigger. I think the regulater plug had as many as 6 wires
There were two types of external regulators one was electronic the other was a mechanical (internal relays) the solid state ones needed B+, ign, and field to do there thing pretty cut and dry if you had ign+ and B+ the field should also have power. The relay types needed stator voltage a long with the rest to work properly. They were a lot more of a pain to deal with. The field voltage is what controls the alt. output the greater the field voltage the higher the alternator output so if you have field voltage and no output the alternator is toes up. You can supply B+ to the field wire at the alternator (remove plug first) and it should charge full tilt like lots so turn stuff off like radio and lights and don't do it for long.
you could burn out stuff head lights I had a solid state go bad on a datson xternal type melted the fuse box I had to rework that . didn't lose anything else. am I right been a while there was a wire on the B termanl besides the three termanl plug. just rembered some of the reman alternaters had a little different plug bosch supllyed a adapter plug with short wires .
I have heard about 16-20 VDC with shorted diodes in the alternator. I have only had diodes go open in mine so reduced voltage.
I miss the alternator/generator shop off market street, he had everything in stock and was so cheap I quit messing with 'em, just let him fix it. He had a dyno with a scope and could see diodes that were weak replacing them before they failed.
john
Many years ago we had a Jag E type in the shop that had a regulator go bad it finally came to a stop after all the water was boiled out of the battery. We replaced the regulator and battery and thought all was well. Well it wasn't he was driving at night there was not a single bulb that was not burned out, the radio was toast and a couple of gauges so yes an unregulated alternator is capable of a lot of voltage.The battery can absorb a lot of voltage for awhile so checking the output is definitely a short term test only. GM's older internal regulated alt. had a small pin that you could short to ground through the case to do the same thing it allowed you to see if the regulator was bad or the alternator before you took it apart.
Yes stator voltage of 200+ volts AC is certainly obtainable and even something close to 40 volts DC before the diodes explode is possible also.
Just to update what was going on, apparently there was a bad wire that was causing the electricity to arch and overcharging the alternator. It blew a bunch of fuses and the regulator and I had to get the whole system replaced. Eugh, was very costly, but she is driving a lot better now...
pull into just about any auto parts store & have your alternator checked. Yes you can do it yourself with basic understanding of a multi-tester.
most auto part places will do the test for free - the symptoms you describe all can be explained by a bad alternator.
or you can keep driving - your battery will die soon.
