snail powered Posted August 6, 2013 Share Posted August 6, 2013 My rig did not come with a sewer hose and connection fittings for it. There are quite a few different ones at the store so I have no clue which one is going to be a good one. Anyone have a preference as to make and style? It is such as nasty job to think about that I don't want to be fighting it and have a mess on my hands. Affordable product choice is always much appreciated. No point in washing money down that tube too. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 6, 2013 Share Posted August 6, 2013 I use the push on fittings from blueline. Started out with the standard ones but will never go back. These are much easier and they fit nicely. never have had an accident. This is the large kit. I bought the small one with one 10 ft hose and then bought a separate end cap that's better than the one in this kit. Camping world has them. Not cheap but I've had mine a very long time. http://www.campingworld.com/shopping/item/blueline-ultimate-sewer-kit/31212 here's the better end cap http://www.ebay.com/itm/Prest-o-Fit-1-0005-BlueLine-RV-Sewer-Hose-Pushover-Termination-Cap-/121025021120?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item1c2da744c0&vxp=mtr Linda S Quote Link to comment Share on other sites More sharing options...
snail powered Posted August 6, 2013 Author Share Posted August 6, 2013 I use the push on fittings from blueline. Started out with the standard ones but will never go back. These are much easier and they fit nicely. never have had an accident. This is the large kit. I bought the small one with one 10 ft hose and then bought a separate end cap that's better than the one in this kit. Camping world has them. Not cheap but I've had mine a very long time. http://www.campingworld.com/shopping/item/blueline-ultimate-sewer-kit/31212 here's the better end cap http://www.ebay.com/itm/Prest-o-Fit-1-0005-BlueLine-RV-Sewer-Hose-Pushover-Termination-Cap-/121025021120?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item1c2da744c0&vxp=mtr Linda S Thanks Linda, I appreciate your recommendation. There is a camping world south of Seattle. Good reason to drop in and see what they have in stock. Quote Link to comment Share on other sites More sharing options...
waiter Posted August 6, 2013 Share Posted August 6, 2013 I just got the cheep Walmart one, I think its 10 ft, a slight twist locks it in place. don't loose the rubber o-ring gasket or you'll have a little drip when your draining. I dump the black tank first, then kind of walk the hose, lifting it as I go to empty the hose. Then do the same with the gray to rinse the hose. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
sdboltdude Posted August 6, 2013 Share Posted August 6, 2013 maybe one of the clear plastic connection fittings so you can see the waist water (helps see when its clean) Quote Link to comment Share on other sites More sharing options...
5Toyota Posted August 7, 2013 Share Posted August 7, 2013 if you look at the different grades of hose the more expensive is made way better . and is well worth the little more money. Quote Link to comment Share on other sites More sharing options...
Skydancer2992 Posted August 7, 2013 Share Posted August 7, 2013 My first hose went missing after one of the end caps popped off my bumper and the RV rounded a sharp turn on a previous trip. Of course, I only discovered the loss after arriving at home. I wonder if someone jumped at the "free" hose sitting by the side of the road. The current hose is a Walmart. I recently saw a photo of a bumper end with a bolt holding the end cap. Looks like a hole was drilled through the top of the bumper and through the top edge of the end cap. I plan to do the same. Quote Link to comment Share on other sites More sharing options...
snail powered Posted August 7, 2013 Author Share Posted August 7, 2013 My first hose went missing after one of the end caps popped off my bumper and the RV rounded a sharp turn on a previous trip. Of course, I only discovered the loss after arriving at home. I wonder if someone jumped at the "free" hose sitting by the side of the road. The current hose is a Walmart. I recently saw a photo of a bumper end with a bolt holding the end cap. Looks like a hole was drilled through the top of the bumper and through the top edge of the end cap. I plan to do the same. My bumper cap just has a long nail through a hole in the bumper. Seems to work fine at holding the cap on. Quote Link to comment Share on other sites More sharing options...
