mini-wini-dan Posted July 2, 2012 Share Posted July 2, 2012 Just want to thank all of you who have been answering my questions and I am almost ready for our first road trip with everything working. Now one more question that was not answered in the manual I received with the vehicle. Just changed oil and at first put in 5 qts.and noticed level was way too high - then drained out one qt and dipstick is still reading a little high. Is it really just 3.7 qis? I read that fact somewhere on line. Quote Link to comment Share on other sites More sharing options...
linda s Posted July 2, 2012 Share Posted July 2, 2012 Just want to thank all of you who have been answering my questions and I am almost ready for our first road trip with everything working. Now one more question that was not answered in the manual I received with the vehicle. Just changed oil and at first put in 5 qts.and noticed level was way too high - then drained out one qt and dipstick is still reading a little high. Is it really just 3.7 qis? I read that fact somewhere on line. 4 quarts without filter, 4.5 with. If you haven't started the engine yet and you did change the filter, start it let some cycle through the filter LS Quote Link to comment Share on other sites More sharing options...
Bob C Posted July 2, 2012 Share Posted July 2, 2012 Just to avoid future confusion, try what I do. I have always written the oil capacity under the hood with a Sharpie. Our family has 5 vehicles (kids) and I forget what they all hold. It just makes it easier. I also write the belt sizes and filter number under the hood. Quote Link to comment Share on other sites More sharing options...
ILIA Posted July 3, 2012 Share Posted July 3, 2012 Mine takes 3.7. Linda, are you confusing his 22re with your 6 cylinder? Just add 3.5 and then use your dipstick to check the level as you slowly add more. Quote Link to comment Share on other sites More sharing options...
90toydolphin Posted July 3, 2012 Share Posted July 3, 2012 i just changed my 89 6, oil and filter, took 5 quarts and measures right at full after running it. Quote Link to comment Share on other sites More sharing options...
linda s Posted July 3, 2012 Share Posted July 3, 2012 Mine takes 3.7. Linda, are you confusing his 22re with your 6 cylinder? Just add 3.5 and then use your dipstick to check the level as you slowly add more. No I am reading the manual. I have a 22re LS Quote Link to comment Share on other sites More sharing options...
linda s Posted July 3, 2012 Share Posted July 3, 2012 No I am reading the manual. I have a 22re LS One other thing. If you have never pulled the pan and cleaned out the slug that accumilates there that could be the difference. I have and it can be substantial LS Quote Link to comment Share on other sites More sharing options...
mini-wini-dan Posted July 3, 2012 Author Share Posted July 3, 2012 Thanks again for your replies-Next oil change I may drop the oil pan to clean it out. I am guessing that I will need a new gasket to put the pan back on-right? Quote Link to comment Share on other sites More sharing options...
linda s Posted July 3, 2012 Share Posted July 3, 2012 Thanks again for your replies-Next oil change I may drop the oil pan to clean it out. I am guessing that I will need a new gasket to put the pan back on-right? Reseal it with this stuff. Not hard to use but only buy the toyota stuff http://www.suprastore.com/tofigase.html LS Quote Link to comment Share on other sites More sharing options...
WME Posted July 3, 2012 Share Posted July 3, 2012 With modern high dertegent oils, droping the pan is a waste of time. It will be clean 86 factory book says 4.9 qts with filter Quote Link to comment Share on other sites More sharing options...
ILIA Posted July 4, 2012 Share Posted July 4, 2012 No offense taken, but I'm confident mine is sludge free. I've ran it for 400 miles on fresh oil and afterwards it still looked very clean. Quote Link to comment Share on other sites More sharing options...
90toydolphin Posted July 4, 2012 Share Posted July 4, 2012 maybe there's a rock dent in the pan??? could happen. Quote Link to comment Share on other sites More sharing options...
