Ron 'n Sue Posted May 3, 2012 Share Posted May 3, 2012 Hi all! First day out since shut down for the winter an our water heater has decided not to heat. It runs okay for a minute or so then shuts itself off. We'll do a little cleaning today and try it again. But if anyone has any ideas that might work, please let us know. Don't want to have to take Toy Rig to the repair shop to wait in line for a repair if don't need to. Thanks. Ron Toy-Rig Quote Link to comment Share on other sites More sharing options...
Bob C Posted May 3, 2012 Share Posted May 3, 2012 I once had a Scamp camper that had a heater that did that. I found that my LP tank was just about empty and it would cycle off after running for a short time. Have you checked your LP supply? Quote Link to comment Share on other sites More sharing options...
Ron 'n Sue Posted May 3, 2012 Author Share Posted May 3, 2012 I once had a Scamp camper that had a heater that did that. I found that my LP tank was just about empty and it would cycle off after running for a short time. Have you checked your LP supply? Thanks for answering Bob. We seem to have loads of propane. Furnace works, frig works, stove works. Just the problem water heater. We're going out to clean it with a soft toothbrush (used - lol) to see if that might help. And make sure it has water in it. Hopefully the cleaning will work. Suzanne Toy-Rig Quote Link to comment Share on other sites More sharing options...
Ron 'n Sue Posted May 3, 2012 Author Share Posted May 3, 2012 It seems the by-pass to the hot water tank was in the off position. Nobody noticed. Oh, well. Getting old is hard to do. Sue & Ron Toy Rig Thanks for answering Bob. We seem to have loads of propane. Furnace works, frig works, stove works. Just the problem water heater. We're going out to clean it with a soft toothbrush (used - lol) to see if that might help. And make sure it has water in it. Hopefully the cleaning will work. Suzanne Toy-Rig Quote Link to comment Share on other sites More sharing options...
Maineah Posted May 3, 2012 Share Posted May 3, 2012 Bet the water was plenty warm! Quote Link to comment Share on other sites More sharing options...
mountainman2020 Posted April 26, 2013 Share Posted April 26, 2013 Mine's doing same thing... Runs for 30 to 45 seconds and shuts off. Changed thermocouple, no difference. What's this about a by pass? I believe thank is full, getting no air from spigots. Propane is about 1/3 full. Flame looks good when running, Tried cleaning back in as far as I could reach with a brush before starting. Could regulator be bad? Any help appreciated. By the way, it's a '92 Itasca, with an Atwood heater unit. Quote Link to comment Share on other sites More sharing options...
mountainman2020 Posted April 26, 2013 Share Posted April 26, 2013 Also, just a thought. How high should the pilot be? Mine seems to a very small flame, maybe less than quarter of an inch. Maybe it's not high enough to keep thermocouple warm? Quote Link to comment Share on other sites More sharing options...
Jahoxsey Posted May 26, 2013 Share Posted May 26, 2013 Just purchased a 1986 Toyota New Horizon (or I should say my Grandmother did) to travel with her friend. Well she is clueless as to how to use the hot water system and how to get it lit as the directions on the flip down door don't make much sense. Can anyone please explain in very non technical terms how to get it lit up? Will the hot water work on electric or just of the propane? Quote Link to comment Share on other sites More sharing options...
Maineah Posted May 26, 2013 Share Posted May 26, 2013 Just about all of the Toy homes are hand lit it also most likely does not have an electric heater unless it was added. The heater has to be in the pilot setting and the pilot button pushed down before the pilot can be lit you need to hold down the button for 30 seconds or so after it’s lit then release it and the flame should stay lit (if not just do it again) then you can turn it to "on" and the system will take care of the rest. Quote Link to comment Share on other sites More sharing options...
sdboltdude Posted May 27, 2013 Share Posted May 27, 2013 http://www.youtube.com/watch?v=bgeKMlckLSY hope this vid helps... shows how to light a pilot light heater... Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted May 28, 2013 Share Posted May 28, 2013 I have a 93 winnie - had similar problem. The quick cutoff mountain man is describing sounds like the thermocouple is not getting enough heat. One way to test for that is to get a bbq lighter & hold the flame on the thermocouple - if the pilot stays on you have an idea (check #1 below) Possibilities: 1) little line to pilot light needs to be blown out (easy to do) (case with my 1st camper - pilot light flame was small) 2) main jet is clogged - caution, resist temptation to stick something in the orifice, you do not want to damage it. I think the proper procedure is to clean itby soaking it in wood alcohol 3) crap in tube between main jet & where you see the flame (happened to me) cleaned it out by removing it & cleaning it with a rag 4) Thermocouple is acting up If you just keep relighting it you may find after a while it works better just by letting it flush itself. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted May 29, 2013 Share Posted May 29, 2013 ifit is propane it should be obvious - Quote Link to comment Share on other sites More sharing options...
