vtchris Posted January 19, 2011 Share Posted January 19, 2011 Burnt valve on #6, mechanic says $2500 for valve job. $6000 for new re-manufactured Jasper engine which comes with 3yr/100k mile warrantee. What would you do? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted January 19, 2011 Share Posted January 19, 2011 Make sure you check the fine print with Jasper. I'm not sure, but it might exclude motorhomes. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted January 19, 2011 Share Posted January 19, 2011 There's nothing on here, but a Search in the Yahoo Group will give you some reading about the Jasper Rebuild. Just Search for 'Jasper' and ignore the posts about Alberta and Ghosts. Quote Link to comment Share on other sites More sharing options...
vtchris Posted January 19, 2011 Author Share Posted January 19, 2011 Make sure you check the fine print with Jasper. I'm not sure, but it might exclude motorhomes. I checked on the warrantee, thanks for the heads up, it hadn't occurred to me, but all is well, warranty covers as long as gvw doesn't exceed 17K. It is a done deal, bought and charged for.....I go on Monday for the work. Thanks for all the advice. Quote Link to comment Share on other sites More sharing options...
johnboy88 Posted January 19, 2011 Share Posted January 19, 2011 Burnt valve on #6, mechanic says $2500 for valve job. $6000 for new re-manufactured Jasper engine which comes with 3yr/100k mile warrantee. What would you do? i just had a remanufactured 22re put in my escaper 88. i got it from nappa autoparts and they have a 3 year no limit on mileage warantee. cost 2000 dollars. 1000 labor at nappa in Tucumcari nm. Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 20, 2011 Share Posted January 20, 2011 Chris have the head gaskets been done? Toyota in many cases has been covering head gasket replacements that may save you a LOT of labor if you have the valves done at the same time worth a try. Quote Link to comment Share on other sites More sharing options...
wistoy Posted January 20, 2011 Share Posted January 20, 2011 I am in central WI Rebuild engine Aprox 2200, labor and misc. parts (plugs, wires filter, Maybe water pump ect) 2000 or about 4200 as a rough est. HOWEVER PRICES will very by area, as overheads very greatly. This is not a solictation for work, only a comparison Dale 89 Sea Breeze Quote Link to comment Share on other sites More sharing options...
elderthewelder Posted January 25, 2011 Share Posted January 25, 2011 I am going to buy a rebuilt 22re in the near future, either going with Oregon Engine Rebuilders, or SunWest Automotive Sunwest has them on sale now for $1385 for a long block with new head and RV cam http://spokane.craigslist.org/pts/2142909000.html http://www.sunwestautomotiveengines.com/lb-toyota.html Oregon sells them on ebay with a lifetime warranty http://oregonengines.net/ Quote Link to comment Share on other sites More sharing options...
Sunnynshare Posted January 26, 2011 Share Posted January 26, 2011 I am going to buy a rebuilt 22re in the near future, either going with Oregon Engine Rebuilders, or SunWest Automotive Sunwest has them on sale now for $1385 for a long block with new head and RV cam http://spokane.craig...2142909000.html http://www.sunwestau.../lb-toyota.html Oregon sells them on ebay with a lifetime warranty http://oregonengines.net/ I have about a thousand miles on my sunwest and all is good. I also bought the napa kit from them that had radiator hoses, belts,and all that. I rebuilt my starter and alternator while I had them out. It's easy to take out and put in. Here I am sticking it in and here is the mostly done engine and me rambling . Kim Quote Link to comment Share on other sites More sharing options...
deprivation Posted January 31, 2011 Share Posted January 31, 2011 (edited) $2500 for a valve job? Find a new mechanic. You can ger an excellent, new OEM head for four or five-hundred bucks or you can get the head machined, with new valves for the same price. You can get a head cheaper than that, but you get what you pay for. A decent shop can get the old head out and the new head in six to eight hours tops. And six grand for an engine swap is super-insane. Get some more estimates. EDIT - I didn't see that you had a V6. Different animal than a 22re. Never mind me! Edited January 31, 2011 by deprivation Quote Link to comment Share on other sites More sharing options...
Derek up North Posted January 31, 2011 Share Posted January 31, 2011 Yes, there was no mention of the engine being a V6 in the thread. Sorry, I knew from other Threads and should have mentioned it. Quote Link to comment Share on other sites More sharing options...
WME Posted January 31, 2011 Share Posted January 31, 2011 Well the first post says bad valve on #6, HINT HINT Quote Link to comment Share on other sites More sharing options...
Tom W Posted February 2, 2011 Share Posted February 2, 2011 I done them on the v6 I thought it was a pita getting the crossover tube between the exhaust manifolds is a matter of some luck and skinned knuckles if you can't get it off in the veh the eng would have to be slid forward or removed and their is a bunch of stuff to come off the top, unless it would be possible to remove both Hds at the same time, anyone that says this is a piece of cake let them do it. Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted February 6, 2011 Share Posted February 6, 2011 Seems like the result of a burnt valve can be a couple of things, a bad injector running a cylinder lean or a valve seat that wore prematurely and eventually leaked or 3 a sticking valve. Depending on mileage I think I would have opted for the valve job. Curious, is the shop going to put in new injectors? Is it known why the valve burnt? Quote Link to comment Share on other sites More sharing options...
