Jasonyaj Posted April 17 Share Posted April 17 I’ve looked online and found multiple but want to order the right ones, need to find some leaf spring bushing for my 1990 Toyota pickup project that im doing a rear end swap to a dually from a motor home. Also need the bushing for the sway bar and end links but I’m having trouble trying to find the bushings for the end links. Just wanting to make one order that’s correct so I don’t have any delays. Quote Link to comment Share on other sites More sharing options...
linda s Posted April 17 Share Posted April 17 This page should have all the bushings but it also has some stuff you don't need. You can sort through them https://www.toyotapartsdeal.com/parts-list/1990-toyota-pickup-2_wheel_drive/power_train_chassis/rear_spring_shock_absorber.html?filter=(d=USA;1=3VZE;4=STD;5=ATM;6=4HC;7=RCB;8=WT;9=HLF;11=EFI;13=IV6;14=T1;0=VZN95L-TWSREA6) You can also search this site to see what other types people have bought. The poly bushings are supposed to be better, like Energy Suspension. I just don't know the part numbers for those Linda S Quote Link to comment Share on other sites More sharing options...
Jasonyaj Posted April 18 Author Share Posted April 18 4 hours ago, linda s said: This page should have all the bushings but it also has some stuff you don't need. You can sort through them https://www.toyotapartsdeal.com/parts-list/1990-toyota-pickup-2_wheel_drive/power_train_chassis/rear_spring_shock_absorber.html?filter=(d=USA;1=3VZE;4=STD;5=ATM;6=4HC;7=RCB;8=WT;9=HLF;11=EFI;13=IV6;14=T1;0=VZN95L-TWSREA6) You can also search this site to see what other types people have bought. The poly bushings are supposed to be better, like Energy Suspension. I just don't know the part numbers for those Linda S Thank you! I did check this parts website and it does have the leaf spring bushing but the sway bar or stabilizer bar end links are apparently discontinued. Just need bushing and maybe the washers and nut but it show the links in an exploded diagram, all the parts I need too but discontinued. Don’t know where else to find, looked online with no lead. Quote Link to comment Share on other sites More sharing options...
Jasonyaj Posted April 18 Author Share Posted April 18 these are the main bushings on the end links I’m having trouble finding. Discontinued and can’t find online. Quote Link to comment Share on other sites More sharing options...
extech Posted April 18 Share Posted April 18 the links werent on the donor ? Quote Link to comment Share on other sites More sharing options...
linda s Posted April 18 Share Posted April 18 They are there. The part discontinued is the whole metal end link. Here are the bushings 4881730010 4881514160 Linda S Ignore that it might say front. Same bushings for rear Quote Link to comment Share on other sites More sharing options...
linda s Posted April 18 Share Posted April 18 Here is a better diagram with all the necessary bushings and parts for the end links with part numbers. Googling part numbers brings up lots of places to buy. Stabilizer Cushion #48817-30020 | Autoparts.toyota.com Linda S Quote Link to comment Share on other sites More sharing options...
Jasonyaj Posted April 18 Author Share Posted April 18 17 hours ago, extech said: the links werent on the donor ? The links are there just need bushings. Quote Link to comment Share on other sites More sharing options...
Jasonyaj Posted April 18 Author Share Posted April 18 Thank you Linda s Quote Link to comment Share on other sites More sharing options...
IdahoDoug Posted April 19 Share Posted April 19 Jason, would love to see your source/order when it pans out. I am renewing rear bushings as well and would just duplicate your order for convenience if you dont mind posting. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
