Jasonyaj Posted April 17 Posted April 17 I’ve looked online and found multiple but want to order the right ones, need to find some leaf spring bushing for my 1990 Toyota pickup project that im doing a rear end swap to a dually from a motor home. Also need the bushing for the sway bar and end links but I’m having trouble trying to find the bushings for the end links. Just wanting to make one order that’s correct so I don’t have any delays. Quote
linda s Posted April 17 Posted April 17 This page should have all the bushings but it also has some stuff you don't need. You can sort through them https://www.toyotapartsdeal.com/parts-list/1990-toyota-pickup-2_wheel_drive/power_train_chassis/rear_spring_shock_absorber.html?filter=(d=USA;1=3VZE;4=STD;5=ATM;6=4HC;7=RCB;8=WT;9=HLF;11=EFI;13=IV6;14=T1;0=VZN95L-TWSREA6) You can also search this site to see what other types people have bought. The poly bushings are supposed to be better, like Energy Suspension. I just don't know the part numbers for those Linda S Quote
Jasonyaj Posted April 18 Author Posted April 18 4 hours ago, linda s said: This page should have all the bushings but it also has some stuff you don't need. You can sort through them https://www.toyotapartsdeal.com/parts-list/1990-toyota-pickup-2_wheel_drive/power_train_chassis/rear_spring_shock_absorber.html?filter=(d=USA;1=3VZE;4=STD;5=ATM;6=4HC;7=RCB;8=WT;9=HLF;11=EFI;13=IV6;14=T1;0=VZN95L-TWSREA6) You can also search this site to see what other types people have bought. The poly bushings are supposed to be better, like Energy Suspension. I just don't know the part numbers for those Linda S Thank you! I did check this parts website and it does have the leaf spring bushing but the sway bar or stabilizer bar end links are apparently discontinued. Just need bushing and maybe the washers and nut but it show the links in an exploded diagram, all the parts I need too but discontinued. Don’t know where else to find, looked online with no lead. Quote
Jasonyaj Posted April 18 Author Posted April 18 these are the main bushings on the end links I’m having trouble finding. Discontinued and can’t find online. Quote
linda s Posted April 18 Posted April 18 They are there. The part discontinued is the whole metal end link. Here are the bushings 4881730010 4881514160 Linda S Ignore that it might say front. Same bushings for rear Quote
linda s Posted April 18 Posted April 18 Here is a better diagram with all the necessary bushings and parts for the end links with part numbers. Googling part numbers brings up lots of places to buy. Stabilizer Cushion #48817-30020 | Autoparts.toyota.com Linda S Quote
Jasonyaj Posted April 18 Author Posted April 18 17 hours ago, extech said: the links werent on the donor ? The links are there just need bushings. Quote
IdahoDoug Posted April 19 Posted April 19 Jason, would love to see your source/order when it pans out. I am renewing rear bushings as well and would just duplicate your order for convenience if you dont mind posting. Thanks in advance. Quote
