dondiego Posted December 9, 2023 Share Posted December 9, 2023 I can't find replacement for 14mm 1.5 thread 44mm length bolt. Quote Link to comment Share on other sites More sharing options...
extech Posted December 9, 2023 Share Posted December 9, 2023 - Dorman 610-338 - https://amzn.to/2DYYavU Quote Link to comment Share on other sites More sharing options...
dondiego Posted December 9, 2023 Author Share Posted December 9, 2023 Thanks but mine is 1 3/4 inch long. I modified some that were to long, but they turned in the hole. Not thick enough to hold in hub. Quote Link to comment Share on other sites More sharing options...
linda s Posted December 9, 2023 Share Posted December 9, 2023 This is the correct lug bolt for your rear axle https://www.toyotapartsdeal.com/oem/toyota~bolt~hub~for~rear~axle~90942-02066.html Linda S Quote Link to comment Share on other sites More sharing options...
linda s Posted December 9, 2023 Share Posted December 9, 2023 Sorry you needed front ones and they have been discontinued Linda S Quote Link to comment Share on other sites More sharing options...
dondiego Posted December 9, 2023 Author Share Posted December 9, 2023 Yes. I called local Toyota dealer. Discontinued. Thanks Quote Link to comment Share on other sites More sharing options...
linda s Posted December 9, 2023 Share Posted December 9, 2023 This is supposed to be a match to the original https://www.autozone.com/suspension-steering-tire-and-wheel/wheel-stud/p/dorman-wheel-stud-610-338-1/70672_0_0 Linda S Quote Link to comment Share on other sites More sharing options...
dondiego Posted December 10, 2023 Author Share Posted December 10, 2023 it has no description. are you sure it's not for a pickup? They are 12mm, and easy to find . My local store can't look up rvs. Quote Link to comment Share on other sites More sharing options...
dondiego Posted December 10, 2023 Author Share Posted December 10, 2023 I have a 6 cylinder with 6 bolts. Quote Link to comment Share on other sites More sharing options...
linda s Posted December 10, 2023 Share Posted December 10, 2023 Description. https://www.dormanproducts.com/p-29977-610-3381.aspx Linda S Look at what it fits. 87 to 94 2wd with 6 bolt wheels. That's us. Oh and your local store are morons. It's a dam Toyota truck. Quote Link to comment Share on other sites More sharing options...
dondiego Posted December 10, 2023 Author Share Posted December 10, 2023 Thank you so much, Linda. It is 1/4 inch shorter than what is on it now, but maybe that's good. Btw. your right about most retail outlet's now. They might as well BE robots. Quote Link to comment Share on other sites More sharing options...
dondiego Posted December 10, 2023 Author Share Posted December 10, 2023 Actually, I have 2 bolts the right size from the local hardware, but the Knurls slip. Not thick enough to hold. Any suggestions om how to modify? Quote Link to comment Share on other sites More sharing options...
Bob the Builder Posted December 10, 2023 Share Posted December 10, 2023 dondiego, I have peened the knurled part around studs with a center punch in several positions along the length of the knurl, effectively creating an exaggerated "knurl" which worked successfully for me in several instances. Not too scientific but effective. Quote Link to comment Share on other sites More sharing options...
IdahoDoug Posted December 10, 2023 Share Posted December 10, 2023 (edited) Peening is a great option, as is using an epoxy. Look for a product designed to hold bearing shells in place, as it is released by heat (torch, etc). I would not be concerned at all in using JB Weld here. All the splines do is prevent the stud from rotating - they have nothing to do with the carrying the load from proper torqueing. I'd apply it, then put perhaps 30 ft-lbs on it to ensure it's pulled all the way seated. Cure for 24 hours and you're set for full torque. EDIT: Also, "right size bolts" "from the local hardware" and "the knurls slip". Are you saying you found automotive grade knurled lugs at the hardware store? Or are you saying you simply found some ordinary hardware store bolts that fit, but are not knurled or actual automotive lugs? Edited December 10, 2023 by IdahoDoug Quote Link to comment Share on other sites More sharing options...
dondiego Posted December 10, 2023 Author Share Posted December 10, 2023 Thanks guys. Good question. They were in a small "auto section", so I hope they are hard enough. They looked like my old ones, except the Knurl didn't hold them . I thought Peening or J b weld might be an option. Glad I found this site again. Not many 6 cyl. Toys out there. Quote Link to comment Share on other sites More sharing options...
