IdahoDoug Posted June 12, 2023 Share Posted June 12, 2023 Are they lubed from the diff gear oil, or packed with grease and separated from the gear oil with a seal? Quote Link to comment Share on other sites More sharing options...
fred heath Posted June 12, 2023 Share Posted June 12, 2023 Packed with grease. No dif oil involved. Quote Link to comment Share on other sites More sharing options...
fred heath Posted June 12, 2023 Share Posted June 12, 2023 (edited) If your GAW on the rear axle is under 4K you can run with single tires. Edited June 12, 2023 by fred heath Quote Link to comment Share on other sites More sharing options...
linda s Posted June 12, 2023 Share Posted June 12, 2023 Running single tires in the back also gives you the opportunity to upgrade to 15 inch wheels and run bigger tires. More weight load and more stability Thunderer Ranger R402 215/70R15 109/107R D (8 Ply) AS A/S All Season Tire (prioritytire.com) Linda S Adding a sway bar is also a good idea Quote Link to comment Share on other sites More sharing options...
