Bigdog Posted December 23, 2019 Share Posted December 23, 2019 I've been getting water on the floor of the passenger side cab rained last night and today i heard a hissing sound in the dash and my windshield forged up after driving can't see any obvious leaks any one have this leaking problem? Quote Link to comment Share on other sites More sharing options...
fred heath Posted December 23, 2019 Share Posted December 23, 2019 Very common problem with the old Toyota’s. If you look under the dash in the upper right hand corner (passenger side) upper left (drivers side) you’ll notice a rusted area in the sheet metal where the firewall meets the side wall. This is usually caused by the drain channels that funnel off the water from the external wiper grill to the ground via an inside channel ( behind the fender(s)becomes plugged. That or a bad windshield gasket. You can try to clean out the channels with something like a “snake” or rigid wire. You’ll have to seal the sheet metal inside to prevent further leaks. It’s a PITA, but only solution I’ve found. Quote Link to comment Share on other sites More sharing options...
linda s Posted December 24, 2019 Share Posted December 24, 2019 I went nuts trying to stop a passenger side leak. Cleaned all those drains and sealed everywhere around the windshield that I could see. Didn't help. Then I noticed a cable that comes in through the side panel in front of the computer. Sealed that cable inlet and it never leaked again. Think it's the heater cable but not sure. Linda S Quote Link to comment Share on other sites More sharing options...
Maineah Posted December 24, 2019 Share Posted December 24, 2019 Yep old Toyota issue Linda is spot on they did get quite rusty. Quote Link to comment Share on other sites More sharing options...
