86Dolphino Posted June 5, 2020 Share Posted June 5, 2020 Hi all. I'm doing this post for my buddy sammy. He has a 87 seabreeze. His furnace was working great. Put a new blower motor in it and it was working great all winter. He went out last weekend and his heater wouldn't work. The blower will kick on and after 15 sec or so he will hear a click and the flame will light after about 3 sec the flame goes out it will then relight the flame for about 3 sec and go out it will do that 3 time then stop. If he turns the thermostat off and hack on it will run through the same process. Any ideas? We were maybe thinking bad solenoids maybe or bad lp regulator? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
WME Posted June 5, 2020 Share Posted June 5, 2020 Bad flame sensor /thermocoupler Quote Link to comment Share on other sites More sharing options...
86Dolphino Posted June 5, 2020 Author Share Posted June 5, 2020 We thought that too. And sammy ordered one and it was the wrong one. Ymanyone happen to have a link for the correct thermocoupler? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 5, 2020 Share Posted June 5, 2020 47 minutes ago, 86Dolphino said: .... a link for the correct thermocoupler? We don't even know the make and model of the furnace. Quote Link to comment Share on other sites More sharing options...
86Dolphino Posted June 5, 2020 Author Share Posted June 5, 2020 Oh I thought they were all the same. There is 5 of us in the reno area and we all have the same furnace. But I'll get a model Quote Link to comment Share on other sites More sharing options...
Rogue Runner Posted June 5, 2020 Share Posted June 5, 2020 (edited) We had a similar problem a year or so back. The first thing we did was come right here and get help from the many great folks here on these forums. Two suggestions stood out: 1) Make sure your coach battery is fully charged. I didn't know that the electronics in the furnace were sensitive to low voltage. 2) The thermocouple over time can develope scale on the tip. Take some sandpaper and try to sand the tip and then retry the start process. I did this a few times and like magic the furnace came to life. Edited June 5, 2020 by Rogue Runner Quote Link to comment Share on other sites More sharing options...
86Dolphino Posted June 5, 2020 Author Share Posted June 5, 2020 Sammy has pulled the thermocoupler out and used some sandpaper on it once already with no luck. I'm thinking he should replace it. I have tried to find the part but not having much luck. I did get this photo of the furnace Quote Link to comment Share on other sites More sharing options...
86Dolphino Posted June 5, 2020 Author Share Posted June 5, 2020 It's hard to see but the model is 8012 Quote Link to comment Share on other sites More sharing options...
86Dolphino Posted June 5, 2020 Author Share Posted June 5, 2020 We found it this is it for future reference https://pantherrvproducts.com/dometic-atwood-36998-hydroflame-rv-furnace-igniter-electrode/?gclid=EAIaIQobChMI66Xi0KXr6QIVLR-tBh2bEgblEAQYASABEgIWQfD_BwE Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 5, 2020 Share Posted June 5, 2020 http://bryantrv.com/docs2/docs/hflameservice.pdf Quote Link to comment Share on other sites More sharing options...
Maineah Posted June 5, 2020 Share Posted June 5, 2020 Low battery? Try plugging it in and see what happens Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 5, 2020 Share Posted June 5, 2020 2 minutes ago, Maineah said: Low battery? Try plugging it in and see what happens Or, as a test, start the engine, which should bring the house battery up to 13.5 -14v. Quote Link to comment Share on other sites More sharing options...
86Dolphino Posted June 5, 2020 Author Share Posted June 5, 2020 That's what I thought at first. My brother 1993 550 dolphin was doing that until he replaced the batteries. He currently has it plugged into his home. Quote Link to comment Share on other sites More sharing options...
86Dolphino Posted June 11, 2020 Author Share Posted June 11, 2020 Well thermocoupler has been replaced with same result. Lights up for 2 seconds and then shuts off. So its safe to say it's not the thermocoupler. Any other ideas? I'm starting to wonder about the board and the solenoids. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 11, 2020 Share Posted June 11, 2020 Yes the board is the problem lots of times. I don't now much about replacing them but they seem to be readily available. Is there any place in the Bryant Docs where it tells you how to test the board? I would certainly check every circuit I could before throwing more parts at it https://www.google.com/search?sxsrf=ALeKk0144ognacjnEf5lJ_P89mAdmQ1Q_g%3A1591914834925&source=hp&ei=UrHiXuaTNZLatAWs852YDw&q=hydro+flame+8012+board&oq=hydro+flame+8012+board&gs_lcp=CgZwc3ktYWIQAzIFCCEQoAE6BAgjECc6BQgAEJECOgUIABCxAzoCCAA6BQgAEIMBOgQIABBDOgcIABCxAxBDOgcIABCDARBDOgcIABAUEIcCOgQIABAKOgYIABAWEB46BQghEKsCULQKWMuIAWDmkQFoAHAAeACAAbQBiAHsFpIBBDAuMjKYAQCgAQGqAQdnd3Mtd2l6&sclient=psy-ab&ved=0ahUKEwjmhPvx6PrpAhUSLa0KHax5B_MQ4dUDCAg&uact=5 Linda S Quote Link to comment Share on other sites More sharing options...
WME Posted June 12, 2020 Share Posted June 12, 2020 Replacement boards...https://www.dinosaurelectronics.com/index.htm Quote Link to comment Share on other sites More sharing options...
86Dolphino Posted June 16, 2020 Author Share Posted June 16, 2020 Well problem is fixed. So he brought the furnace over and we tested the solenoids they would open and close fine ohms were in range. We did notice with solenoids open you could blow through them for about 3 sec then it would clog up. I put some compressed air through the gas line and it took air for about 3 sec and clogged up. Did that a few times and then we heard something shoot through, and air could flow. Even blew out a lot of dust at that point. Hooked it back up and it works great. Something got clogged in the gas line. Quote Link to comment Share on other sites More sharing options...
