zero Posted October 11, 2015 Share Posted October 11, 2015 Sherrie - If you opt for that radiator Linda cited - get some specs and post them. I'd like to see just how much bigger it is. I suspect you'd have to call them and speak to a real person to get a real answer. Some companies just cite core-depth as the total dimension instead of the total width of the tubes only. That can be very misleading. Like I said earlier, multiple tubes, in itself means nothing. Now if they have tubes equal to OEM size and add even more - then you've got something. One radiator cited as 2" deep might only have three 3/8" tubes ( 1 1/8" total), whereas another cited as " 2" might have two 3/4" tubes (1 1/2" total). Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 11, 2015 Author Share Posted October 11, 2015 Okay, So I sent the email below to the manufacture CSF 3 row radiator. I will call them tomorrow. I am hearing from what people are writing that at this time I should be looking at solutions to cooling the engine with-out regard to why it is so hot. That the engine is hot because I am going up hill hauling a big heavy camper. Is this correct? Hi! My name is Sherrie Myers I have a 1990 Toyota 6 cylinder 3.0 3VZE-E Automatic Transmission, Dully Winnebago Motorhome with 51 K miles. vin # JT5VN94T3L0015561 I currently have this radiator installed. Spectra Premium CU1190 Complete Radiator for Toyota Pickup · Construction: Plastic Tank/Aluminum Core · Core Width (In): 19 Inch · Core Height (In): 17-13/16 Inch · Core Depth (In): 1-1/4 Inch · Number Of Rows: 1 · Inlet Hose Diameter (In): 1-3/8 Inch · Outlet Hose Diameter (In): 1-3/8 Inch · Inlet Hose Diameter (mm): 34.93mm · Engine Oil Cooler Included: No · Transmission Oil Cooler Included: Yes Amazon says this CSF would fit 2306 http://smile.amazon.com/gp/product/B000CFTIE2?redirect=true&ref_=ask_ql_qh_dp_hza Would this fit with-out modifications? I live in Las Vegas NV and have purchased this Motor home just a couple of months ago and have been fighting an overheating problem ever since. I have replaced Head Gasket, Valve Seals, Water pump, timing belt, installed elec radiator fan 3000 cfm, radiator, radiator hoses, radiator cap, thermostat. It overheats going up hill. Runs around town just fine. Please let me know if you have a 3 row radiator that will fit. Thanks Sherrie Myers Quote Link to comment Share on other sites More sharing options...
zero Posted October 11, 2015 Share Posted October 11, 2015 what is this vacuum gauge and how do i verify? I did pass a state required smog test in late June. Vacuum gauge reads negative pressure. i.e. "vacuum." Back in the 60s-70s, most big trucks came with vacuum gauges in the dash as standard equipment. Any repair shop ought to have one and you can buy one for less then $20. Turbo boost gauges also usually read vacuum (as well as boost pressure). All gas engines make vacuum. Most diesel do not and need added vacuum pumps. Gas engines make the most when the engine is idling and least when the gas pedal is first pushed to the floor (wide open throttle). Most brake booster systems work on engine vacuum (your Toyota does). Older cars used to have windshield wipers that worked on vacuum too. My dad's new 59 Ford had them and when you stomped on the gas - the windshield wipers would stop dead. Anyway - there are write-ups ad nauseum on how to use a vacuum gauge to check exhaust on this new thing called the "Internet." Here's one simple write-up (not by me). Your engine has many vacuum lines that are easy to get to. It would take someone 5-10 minutes to do a check. Here's a simple do it yourself (DIY) test that can be performed to see if your CAT convertor is clogged or if you have excessive exhaust system backpressure or restriction: Tools needed: vacuum gauge, tee connector Connect a standard engine vacuum gage into a vacuum port off the intake system. You can tee off the fuel pressure regulator or purge valve lines located on the engine. Start engine and maintain rpms at 2000 - 2500 rpm. Watch vacuum gauge and reading should stabilize and stay steady. If vacuum reading starts dropping or decreasing, it indicates either a clogged CAT convertor or restriction/backpressure in the exhaust system. This simple procedure could save you a lot of money and headaches trying to figure out why the performance of your Grand Prix has degraded. Many times a clogged CAT convertor will not set off a odb-ii DTC error code or SES/MIL light. Its also a good way to determine whether a stock exhaust system is sufficient or whether you should mod. Vacuum gauges are available at most nationwide auto parts stores. Cost is approximately $15 - $30 Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 11, 2015 Author Share Posted October 11, 2015 Sherrie - If you opt for that radiator Linda cited - get some specs and post them. I'd like to see just how much bigger it is. I suspect you'd have to call them and speak to a real person to get a real answer. Some companies just cite core-depth as the total dimension instead of the total width of the tubes only. That can be very misleading. Like I said earlier, multiple tubes, in itself means nothing. Now if they have tubes equal to OEM size and add even more - then you've got something. One radiator cited as 2" deep might only have three 3/8" tubes ( 1 1/8" total), whereas another cited as " 2" might have two 3/4" tubes (1 1/2" total). Here are a couple of screen shots of the specs. Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 11, 2015 Author Share Posted October 11, 2015 Vacuum gauge reads negative pressure. i.e. "vacuum." Back in the 60s-70s, most big trucks came with vacuum gauges in the dash as standard equipment. Any repair shop ought to have one and you can buy one for less then $20. Turbo boost gauges also usually read vacuum (as well as boost pressure). All gas engines make vacuum. Most diesel do not and need added vacuum pumps. Gas engines make the most when the engine is idling and least when the gas pedal is first pushed to the floor (wide open throttle). Most brake booster systems work on engine vacuum (your Toyota does). Older cars used to have windshield wipers that worked on vacuum too. My dad's new 59 Ford had them and when you stomped on the gas - the windshield wipers would stop dead. Anyway - there are write-ups ad nauseum on how to use a vacuum gauge to check exhaust on this new thing called the "Internet." Here's one simple write-up (not by me). Your engine has many vacuum lines that are easy to get to. It would take someone 5-10 minutes to do a check. Here's a simple do it yourself (DIY) test that can be performed to see if your CAT convertor is clogged or if you have excessive exhaust system backpressure or restriction: Tools needed: vacuum gauge, tee connector Connect a standard engine vacuum gage into a vacuum port off the intake system. You can tee off the fuel pressure regulator or purge valve lines located on the engine. Start engine and maintain rpms at 2000 - 2500 rpm. Watch vacuum gauge and reading should stabilize and stay steady. If vacuum reading starts dropping or decreasing, it indicates either a clogged CAT convertor or restriction/backpressure in the exhaust system. This simple procedure could save you a lot of money and headaches trying to figure out why the performance of your Grand Prix has degraded. Many times a clogged CAT convertor will not set off a odb-ii DTC error code or SES/MIL light. Its also a good way to determine whether a stock exhaust system is sufficient or whether you should mod. Vacuum gauges are available at most nationwide auto parts stores. Cost is approximately $15 - $30 OK- Thanks I will do this or get it done as another check. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted October 11, 2015 Share Posted October 11, 2015 At this point, I would be asking if it was practical to unhook the exhaust system and do a test drive. I would take no offense if that is a realllly dumb idea. Jim Quote Link to comment Share on other sites More sharing options...
zero Posted October 11, 2015 Share Posted October 11, 2015 Here are a couple of screen shots of the specs. That is not any bigger then a stock OEM radiator when it comes to frontal surface area. Hopefully it has more depth but I don't see it mentioned. Like I said before - just saying it has "three tubes" does not mean anything useful. Hopefully if the place selling the radiator actually makes it - they can give you more detailed info. Now if their tubes are the same size as OEM Toyota and they have three instead of one, then it would be a big improvement. If it has three tubes that are 1/3 or 1/4 the size of OEM - then it is not an upgrade. Quote Link to comment Share on other sites More sharing options...
WME Posted October 11, 2015 Share Posted October 11, 2015 http://www.harborfreight.com/catalogsearch/result?q=vacuum+ Easy find , cheap Quote Link to comment Share on other sites More sharing options...
zero Posted October 11, 2015 Share Posted October 11, 2015 Okay, So I sent the email below to the manufacture CSF 3 row radiator. I will call them tomorrow. I am hearing from what people are writing that at this time I should be looking at solutions to cooling the engine with-out regard to why it is so hot. That the engine is hot because I am going up hill hauling a big heavy camper. Is this correct? Hi! My name is Sherrie Myers 702-xxx-xxxx I have a Geez - I used to date a girl named Sherrie Myers. But that was in central New York state in the early 80s. Not you, I suppose. The girl I dated might be in a wheel chair or nursing home by now (or worse). Back to radiators. I'm not trying to nick-pick here but buying an upgrade is not always easy unless the seller can give you full info. If this was something like a GM product - you could not even see your cooling tubes when the radiator filler cap is off. That is because they often run sideways (cross-flow design). On your Toyota - they are easy to see since they are vertical. For example - my 1988 Toyota RV has a two-tube core and each tube is 1/2" ID. Easy to see them with the cap off. If you look at the photos I posted - of mine - you can see that mine are partially plugged. That's why mine gets hot if I drive fast, or up a hill with the AC on when it is hot out. The reality is - I rarely ever use AC unless it's cold out. I use it to defog that little Toyota windshield because my dog is like a damn steam engine. In the "old days" of auto repair, desoldering the tanks off of radiators and "rodding out the core" was a standard maintenance practice. Pretty much not done anymore. Labor costs are too high, new radiators are cheap, and there's also a modern issue of "solder bloom" that makes rodding near impossible. Back to my main point. Call the seller of that new radiator and ask him to just look down the filler hole and tell you how many tubes there are an how wide each on is. Then you'll know if you are really getting an upgrade or not. One thing I don't think was mentioned (I have not re-read all the posts). How fast are you going when it gets hot? Are you pushing it hard or keeping it at 50-60 MPH on the flats and I assume slowing on hills. Big rigs often have exhaust temp gauges and tell a drive when to back off the gas pedal on steep hills when things get too hot. Your rig does not have one but is certainly working hard in a near 6000 lb. RV. Quote Link to comment Share on other sites More sharing options...
shibs Posted October 11, 2015 Share Posted October 11, 2015 hey Sherrie and JDE, pls edit out the phone #s, the robot callers will pick up your number and you will get spam calls/text/faxes Quote Link to comment Share on other sites More sharing options...
zero Posted October 11, 2015 Share Posted October 11, 2015 hey Sherrie and JDE, pls edit out the phone #s, the robot callers will pick up your number and you will get spam calls/text/faxes I don't know about Sherrie - but I sure don't have the power to edit out anything on this forum. That being said - I can't see how it is any more dangerous then having your phone number in a public phone directory? Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 11, 2015 Author Share Posted October 11, 2015 Geez - I used to date a girl named Sherrie Myers. But that was in central New York state in the early 80s. Not you, I suppose. The girl I dated might be in a wheel chair or nursing home by now (or worse). Back to radiators. I'm not trying to nick-pick here but buying an upgrade is not always easy unless the seller can give you full info. If this was something like a GM product - you could not even see your cooling tubes when the radiator filler cap is off. That is because they often run sideways (cross-flow design). On your Toyota - they are easy to see since they are vertical. For example - my 1988 Toyota RV has a two-tube core and each tube is 1/2" ID. Easy to see them with the cap off. If you look at the photos I posted - of mine - you can see that mine are partially plugged. That's why mine gets hot if I drive fast, or up a hill with the AC on when it is hot out. The reality is - I rarely ever use AC unless it's cold out. I use it to defog that little Toyota windshield because my dog is like a damn steam engine. In the "old days" of auto repair, desoldering the tanks off of radiators and "rodding out the core" was a standard maintenance practice. Pretty much not done anymore. Labor costs are too high, new radiators are cheap, and there's also a modern issue of "solder bloom" that makes rodding near impossible. Back to my main point. Call the seller of that new radiator and ask him to just look down the filler hole and tell you how many tubes there are an how wide each on is. Then you'll know if you are really getting an upgrade or not. One thing I don't think was mentioned (I have not re-read all the posts). How fast are you going when it gets hot? Are you pushing it hard or keeping it at 50-60 MPH on the flats and I assume slowing on hills. Big rigs often have exhaust temp gauges and tell a drive when to back off the gas pedal on steep hills when things get too hot. Your rig does not have one but is certainly working hard in a near 6000 lb. RV. Ok took my phone number out of my post, not sure how to remove it from the reply? Never lived in NY. I can easily go 60 MPH on the highway, and between 45 and 50 MPH on the Mt. Charleston Hill. I have decided to take the Winnie to a Toyota Mechanic (not the dealer) and have a talk with them regarding the problem and all the suggestions. I will let everyone know what they say. They get a High Yelp rating and are a family run business. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted October 12, 2015 Share Posted October 12, 2015 Ha Ha! Living in Las Vegas I have a portable misting system, I tried to rig it on to the front of the Radiator, but it did not work long enough. I also remember the canvas radiator bag that my dad used to hang in front of our car when I was a little girl. I would do something like this in a minute, I just wonder if my engine getting hot is not a symptom of something other than the cooling system not handling the heat. I don't want to hurt my engine. You have replaced everything in the cooling system twice. If it were my vehicle I would be looking for something outside the system. Only an opinion. Hopefully this Toyota mechanic has some suggestions. You are not getting much response on the yoda tech forum, moving your post from the newbe tech section to the 86 to 95 truck section, might get more exposure? Jim http://www.yotatech.com/f116/ Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 12, 2015 Author Share Posted October 12, 2015 You have replaced everything in the cooling system twice. If it were my vehicle I would be looking for something outside the system. Only an opinion. Hopefully this Toyota mechanic has some suggestions. You are not getting much response on the yoda tech forum, moving your post from the newbe tech section to the 86 to 95 truck section, might get more exposure? Jim http://www.yotatech.com/f116/ I tried to post in that forum and it would not let me. I received a note saying I needed 15 posts. Quote Link to comment Share on other sites More sharing options...
linda s Posted October 12, 2015 Share Posted October 12, 2015 Okay, So I sent the email below to the manufacture CSF 3 row radiator. I will call them tomorrow. I am hearing from what people are writing that at this time I should be looking at solutions to cooling the engine with-out regard to why it is so hot. That the engine is hot because I am going up hill hauling a big heavy camper. Is this correct? Hi! My name is Sherrie Myers I have a 1990 Toyota 6 cylinder 3.0 3VZE-E Automatic Transmission, Dully Winnebago Motorhome with 51 K miles. vin # JT5VN94T3L0015561 I currently have this radiator installed. Spectra Premium CU1190 Complete Radiator for Toyota Pickup · Construction: Plastic Tank/Aluminum Core · Core Width (In): 19 Inch · Core Height (In): 17-13/16 Inch · Core Depth (In): 1-1/4 Inch · Number Of Rows: 1 · Inlet Hose Diameter (In): 1-3/8 Inch · Outlet Hose Diameter (In): 1-3/8 Inch · Inlet Hose Diameter (mm): 34.93mm · Engine Oil Cooler Included: No · Transmission Oil Cooler Included: Yes Amazon says this CSF would fit 2306 http://smile.amazon.com/gp/product/B000CFTIE2?redirect=true&ref_=ask_ql_qh_dp_hza Would this fit with-out modifications? I live in Las Vegas NV and have purchased this Motor home just a couple of months ago and have been fighting an overheating problem ever since. I have replaced Head Gasket, Valve Seals, Water pump, timing belt, installed elec radiator fan 3000 cfm, radiator, radiator hoses, radiator cap, thermostat. It overheats going up hill. Runs around town just fine. Please let me know if you have a 3 row radiator that will fit. Thanks Sherrie Myers The 2306 is for a 22re 4x4. Not your motorhome. I sent the link with the correct model number and that ebay price is super low. I do kind of know what I'm doing here JD here's some more info on the construction and comparison to a Masiv radiator http://www.motoiq.com/MagazineArticles/ID/3750/The-CSF-Radiator-Challenge-CSF-vs-Masiv.aspx Linda S Quote Link to comment Share on other sites More sharing options...
jjrbus Posted October 12, 2015 Share Posted October 12, 2015 I tried to post in that forum and it would not let me. I received a note saying I needed 15 posts. Sometimes website rules make no sense. I could copy and paste it to the 86 to 95 area if you like? Jim Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 12, 2015 Author Share Posted October 12, 2015 Sometimes website rules make no sense. I could copy and paste it to the 86 to 95 area if you like? Jim Wouldn't hurt! Might as well keep getting as many ideas as possible. I was able to get under the Winnie last evening and look at the exhaust system. It does look like original and there is at least one hole in the muffler. I think there might be a small crack in the pipe closest to the engine. I will see if the mechanic can check it out. At this point I might just do the exhaust system as it does seem to need attention. Quote Link to comment Share on other sites More sharing options...
WME Posted October 12, 2015 Share Posted October 12, 2015 Sherrie.... Correct CSF radiator....http://csfimports.com/csf_catalog/detail_radiator.asp?CSF_NO=2057 Linda... Interesting radiator shootout, a couple of things. Some of us have been saying that a proper 1 tube radiator will out cool a 3 tube radiator, the test validated this. The CSF is a single tube design. CSF does not make this single tube design to fit a 89-94 Toyota pickup. They make a 3 row brass radiator that fits (2057). Its ultimate cooling capacity compared to the 1190 Sherrie has now is unknown. With out access to tools like the test used, trying to fix this over the internet is a guessing game at best or a goat rope at worst. PS... I use a CSF aluminum 2 row radiator in my 64 Chevelle and love it, no shroud, a clutch fan and the temp never goes up even cruising in 100 deg heat Quote Link to comment Share on other sites More sharing options...
jjrbus Posted October 12, 2015 Share Posted October 12, 2015 Copy and pasted to 86 to 95 forum and took the liberty of putting it on Toyota nation also. You will not get notified of responses so will let you know if anything shows up. Jim http://www.toyotanation.com/forum/80-89-95-toyota-pickup-hilux/1220905-verheating-help.html#post10136745 http://www.yotatech.com/f116/overheating-help-291410/#post52292865 Quote Link to comment Share on other sites More sharing options...
zero Posted October 12, 2015 Share Posted October 12, 2015 With out access to tools like the test used, trying to fix this over the internet is a guessing game at best or a goat rope at worst. PS... I use a CSF aluminum 2 row radiator in my 64 Chevelle and love it, no shroud, a clutch fan and the temp never goes up even cruising in 100 deg heat I don't know what engine your 64 Chevelle has. My 64 SS Chevelle never had any overheating problems in hot summer weather. Great car. 283 with 10.5 to 1 pistons, Crane "3/4 race" cam, Holley 600, Muncie M21 four-speed, etc. Radiator was factory stock and has the shroud was missing. Didn't need a key to start it which was a nice bonus. Only trouble I had with it was goats! Quote Link to comment Share on other sites More sharing options...
zero Posted October 12, 2015 Share Posted October 12, 2015 Sherrie - I seems to me you've approached this problem in a logical way. Especially when posing the question of fixing the excess heat problem versus enhancing the cooling system to deal with it as sort of a "Band-Aid." A few (more) comments. Things we as spectators do not how that COULD be a factor. Like driving it excessively hard, maybe having more-then-normal transmission heat that goes right into the engine cooling system, etc. It seems you've gotten beyond the obvious fixes so now I guess you need to dig deeper. Does the vehicle seem to drive ok with no abnormal drag? Is gas mileage about where it should be (13-15 MPG)? Do you drive most of the time in overdrive or not? Note that OD is likely to make it work harder and create an abnormal amount of heat. I'm not trying to insult your intelligence. I also don't know if this is your first Toyota RV and no others to compare with? I met a woman . . OK let me stop. I met a man AND a woman but the woman did all the talking and the driving. They, as a couple has just bought a Toyota RV with an auto trans. They had NO prior experience with anything close. They had only had it a few weeks when I met them. She had mentioned that they liked its size but said it was slow, not very good on gas mileage (11 MPG), and ran hot much of the time. After talking with her -I realized she had it in OD all the time and drove near everywhere with the gas pedal nearly down to the floor - in an effort to maintain highway speeds of 65-70 MPH. It was amazing to me that the poor thing wasn't burnt up yet. This is an extreme case but not unexpected for someone who have drove an underpowered, overloaded vehicle before. I'm not accusing you of driving like this, but I'd like to know if you've been driving in OD or not. It can make a huge difference in hot weather since OEM, your rig does not have the proper gearing to use OD. Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 12, 2015 Author Share Posted October 12, 2015 UPDATE 10-12-15. Visited with Jeff Korhonen of Precision Performance the reputed Toyota Guru of Las Vegas this morning. I laid everything out to him. All the work, all the thoughts - all the possibilities suggested. He listened and then he said he wanted to wait for the vehicle to cool and he would drain some of the radiator fluid out ( to inspect the fluid and inspect the radiator) and think about this problem. After considering everything his recommendation is - - drum roll - - - put in the CSF Radiator # 2057 in. He checked out the exhaust system and checked for vacuum leaks - It needs a new muffler and has no exhaust leaks. He said it is running very good and although he can not guarantee this will resolve my problem - he does believe the radiator that is in the vehicle is two small for the hard driving of hauling 6000 lb up hill. He is ordering the radiator and we should have it in a couple of days. So I stopped at a couple of Muffler shops on the way home and they want $500.00 to replace everything from the engine to the tail pipe. I might wait on this until I know that the overheating issue is resolved. Thank you - everyone for continuing to consider my problem and give me suggestions. By the way outside temp today is 87% F and I drove the Winnie all around town for the last 3 hours. In traffic, doing errands, with the AC on and the temp never even reached 1/2 way mark. I sure hope this new radiator solves my problem. Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 12, 2015 Author Share Posted October 12, 2015 Sherrie - I seems to me you've approached this problem in a logical way. Especially when posing the question of fixing the excess heat problem versus enhancing the cooling system to deal with it as sort of a "Band-Aid." A few (more) comments. Things we as spectators do not how that COULD be a factor. Like driving it excessively hard, maybe having more-then-normal transmission heat that goes right into the engine cooling system, etc. It seems you've gotten beyond the obvious fixes so now I guess you need to dig deeper. Does the vehicle seem to drive ok with no abnormal drag? Is gas mileage about where it should be (13-15 MPG)? No abnormal drag, breaks and tires never seem to be excessively hot. I get 13 mpg last time I checked. Do you drive most of the time in overdrive or not? Note that OD is likely to make it work harder and create an abnormal amount of heat. I take it out of OD when going up-hill. I'm not trying to insult your intelligence. I also don't know if this is your first Toyota RV and no others to compare with? First Toyota RV. No insult taken I met a woman . . OK let me stop. I met a man AND a woman but the woman did all the talking and the driving. They, as a couple has just bought a Toyota RV with an auto trans. They had NO prior experience with anything close. They had only had it a few weeks when I met them. She had mentioned that they liked its size but said it was slow, not very good on gas mileage (11 MPG), and ran hot much of the time. After talking with her -I realized she had it in OD all the time and drove near everywhere with the gas pedal nearly down to the floor - in an effort to maintain highway speeds of 65-70 MPH. It was amazing to me that the poor thing wasn't burnt up yet. This is an extreme case but not unexpected for someone who have drove an underpowered, overloaded vehicle before. My Husband and I both drive the Winnie and we both enjoy the slow ride. We usually cruise on the Highway at around 50 mph. The Winnie is running so well now with all the work done - it drives easily at 50 mph. It can go up to 65 mph but you can tell it does better at a lower speed. As stated before it only runs hot now if we go up hill. I'm not accusing you of driving like this, but I'd like to know if you've been driving in OD or not. It can make a huge difference in hot weather since OEM, your rig does not have the proper gearing to use OD. We usually leave it OD all the time unless going up hill, Is this not correct? And what about the ECT? Seems to give a power boost but really sucks up the fuel. Quote Link to comment Share on other sites More sharing options...
WME Posted October 13, 2015 Share Posted October 13, 2015 Well, yes fix the overtemp. Next fix the exhaust. UBI, The v-6 has a funky exhaust setup on the engine, the crossover runs across the rear of the engine. It gets the rear cylinder HOT, causing valve wear. Check to see if duals can be done or at least get the crossover out of the engine bay. Several folks with the v-6 have changed the rear axle ratio. They all very happy with results. Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 15, 2015 Author Share Posted October 15, 2015 10-14-15 UPDATE, Had the CSF #2057 Radiator Installed today. It is still Overheating. I actually think it is a little worse. The mechanic says he wants me to bring the Winnie in on Monday night and leave it with him. The first thing he is going to do is an overnight pressure test. He says he will fill it with high pressure and then check it in the morning. If any coolant is leaking into the cylinders he will be able to tell with this test. I thought maybe a air bubble, so I tried to burp it but got no bubbles. He said he lifts the front and uses an overfill funnel to put the coolant in. I am so disappointed. Oh and no gunk from the head sealers- (liquid additive), either in the coolant that was drained nor in the radiator that was removed. Clean - no Gunk. So Frustrated! Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 15, 2015 Author Share Posted October 15, 2015 On 10/12/2015 at 10:23 PM, WME said: Well, yes fix the overtemp. Next fix the exhaust. UBI, The V-6 has a funky exhaust setup on the engine, the crossover runs across the rear of the engine. It gets the rear cylinder HOT, causing valve wear. Check to see if duals can be done or at least get the crossover out of the engine bay. Several folks with the V-6 have changed the rear axle ratio. They all very happy with results. "Several folks with the V-6 have changed the rear axle ratio. They all very happy with results."Â Would this effect the overheating? Quote Link to comment Share on other sites More sharing options...
jjrbus Posted October 15, 2015 Share Posted October 15, 2015 Sorry to hear, was hoping for a fix. Not seeing anything interesting on the other forums either. Jim Quote Link to comment Share on other sites More sharing options...
WME Posted October 15, 2015 Share Posted October 15, 2015 Wow, at this point it has got to be something stupid simple. No more ideas at this time. The rear axle ratio change shouldn't make any difference. It does help with performance and lets the engine run at lighter load for better performance with about the same mpg. Remember there are hundreds of Toys just like yours that pass through LV in the extreme heat with no problems. Quote Link to comment Share on other sites More sharing options...
zero Posted October 15, 2015 Share Posted October 15, 2015 Wow, at this point it has got to be something stupid simple. No more ideas at this time. The rear axle ratio change shouldn't make any difference. It does help with performance and lets the engine run at lighter load for better performance with about the same mpg. Remember there are hundreds of Toys just like yours that pass through LV in the extreme heat with no problems. Rear-axle ratio change could make a big difference in engine temp. That assuming the A340E trans has a locking torque-converter. If the RV labors and does not lock-up, due the OEM too-numerically-low rear-axle gear-ratio - it will make a LOT more heat and pump it into the radiator from excess torque-converter slippage. The poster already stated that 4th OD is used a lot. If a set of gears was installed that allowed cruising and moderate hill-climbing in lock-up mode with no heat-creating slippage - it could make a substantial difference. What I don't know without researching it -is if the A340E can cruise in 3rd and be in lock-up. If so - then an easy test would be to NOT use OD at all and just drive in 3rd and see if it runs cooler. Some lock-up 4 speed transmissions can even lock in 2nd , while some others will only do it in 4th/OD. I don't own a Toyota with a 340E, nor have I ever worked on one. So just guessing here. I have no idea how many other 3 liter Toyota RVs drive through Vegas in OD and have no "too warm an engine" issues. How would we know? Not everyone is going to leap onto a forum and discuss it. Quote Link to comment Share on other sites More sharing options...
shibs Posted October 15, 2015 Share Posted October 15, 2015 I don't like to throw things at a problem without knowing the root cause. Sherrie, you have a tiny tranny cooler in front of the a/c condenser. Pls buy a laser temp thing and gun the atf cooler, radiator (from the engine side) and tell us what the temps are when the truck overheats. What gear are you climbing uphill? I do mine in d3, I have turned my OD off and it drives fine and I can up to 62 mph without the engine being too noisy on my 22re 4 cylinder. Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 15, 2015 Author Share Posted October 15, 2015 After being so disappointing with the new Radiator I decided to try the mister thing - figuring if I am going to need a new engine I might as well drive this one for as long as I can. I needed something I could rig up - but return if it did not work. I found this tank with a 12 volt pump and a sprayer at Harbor Freight. Rigged it up and did my Mount Charleston test drive. IT WORKED! I don't know what that means for the Winnie - but at least I have a way to keep the temperature down and might get a few miles out of it before it burns up. I will rework the system to be a more stable fix and let you know what happens. For those who are interested here is my latest youtube. https://youtu.be/iBtAz57KyOc Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 16, 2015 Author Share Posted October 16, 2015 I don't like to throw things at a problem without knowing the root cause. I know, but at this time, with out tearing the engine apart I don't know what to do. Sherrie, you have a tiny tranny cooler in front of the a/c condenser. Pls buy a laser temp thing and gun the atf cooler, radiator (from the engine side) and tell us what the temps are when the truck overheats. What gear are you climbing uphill? With the OD off, at 40 to 45 mph I think it is in 3rd. If I take it out of OD and leave the lever on "D" is that 3rd? I do mine in d3, I have turned my OD off and it drives fine and I can up to 62 mph without the engine being too noisy on my 22re 4 cylinder. I will buy the Laser temp gun tomorrow when I return the sprayer tank to Harbor Freight, I am going to do a test run with a soaked swap cooler pad so I can take temp reading again at that time. Quote Link to comment Share on other sites More sharing options...
WME Posted October 17, 2015 Share Posted October 17, 2015 Well the results with the sprayer say your radiator isnt big enough, duh! I check and the heavest duty one I can find ic a Champion CC50 3 row all aluminum. Go to he Champion wep site and check it out. After you wade through the hype, find the tube spacing and fin count. Get a tape measure and measure the radiator you have. Compare the two and see if any of the hype is real. Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 17, 2015 Author Share Posted October 17, 2015 10-16-15 Friday. So today I did a few more things to the Winnie and So Far So Good. I did my Mount Charleston test run and DID NOT OVERHEAT! First thing I did was take off the Trim piece below the bumper ( it was all bent up anyway). Then I took off the plastic grill cover over the Radiator. I went out and bought the Infra Red laser Temp gun, and then 5 gallons of distilled water and a bottle of Red Line Water Wetter. I then drained all of the coolant from the system, Flushed with the water hose, flushed with distilled water - filled with distilled water and the Red Line Water Wetter. Burped the system and went for my standard drive up Mount Charleston - Surprise, Surprise - I did not overheat! Not sure what all of this means except I will feel better about the Winnie when I go to sleep tonight. Here is a Youtube video. https://youtu.be/5EvVlB4YJtA Quote Link to comment Share on other sites More sharing options...
sherrie Posted October 17, 2015 Author Share Posted October 17, 2015 Well, yes fix the overtemp. Next fix the exhaust. UBI, The v-6 has a funky exhaust setup on the engine, the crossover runs across the rear of the engine. It gets the rear cylinder HOT, causing valve wear. Check to see if duals can be done or at least get the crossover out of the engine bay. Several folks with the v-6 have changed the rear axle ratio. They all very happy with results. Hi WME, Can you please give me some more info on what I should say when I go for a estimate on the exhaust system. How do I explain what I want changed? Will the exhaust manifold need to changed? Looked at this in the manual and I could not figure it out. Will I need 2 catalytic converters if they install duals? Quote Link to comment Share on other sites More sharing options...
