passman Posted June 10, 2014 Share Posted June 10, 2014 What a pain.... Quote Link to comment Share on other sites More sharing options...
linda s Posted June 10, 2014 Share Posted June 10, 2014 Both original parts from 1986. If this were your home would you even think of using a refrigerator and water heater from 1986. I actually think they look pretty good for their age Linda S Quote Link to comment Share on other sites More sharing options...
passman Posted June 10, 2014 Author Share Posted June 10, 2014 Refrigerator runs fine on electricity, haven't even touched the propane system on this rig yet. List of things to do just gets longer and longer, lucky for me that I'm hooked Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted June 10, 2014 Share Posted June 10, 2014 They do look pretty solid, mostly just surface rust. Quote Link to comment Share on other sites More sharing options...
Vanman Posted June 10, 2014 Share Posted June 10, 2014 I'v had good results with this, http://www.amazon.com/Rust-Oleum-7830730-8-Ounce-Rust-Reformer/dp/B000BZZ56S I just used that link because of the picture, typical amazon mark'em'up and then mark'em'down. That's about what I paid at my local ACE hardware store. john Quote Link to comment Share on other sites More sharing options...
zero Posted June 10, 2014 Share Posted June 10, 2014 What a pain.... They look better then any of mine. Just surface rust. Best either leave it along - or brush it good, put some rust converter on it, and then paint. The worst thing you can do is clean it and not coat it. Rust can be somewhat inert. Looks bad but doesn't progress much unless you clean it off and leave it exposed. That's what destroys many engine cylinders (cavitation). Harmonics keeps knocking rust off and it starts over again and again. By the way - Linda mentioned not using old appliances in a house? Our chest freezer is an International Harvester made in 1948. Hot-air oil "furnace" in my barn is a Firestone made in 1947. I put "furnace" in quotes because the in 1947 - Firestone called it an "Air Conditioner." I also have a GE "Monitor Top" refrigerator out in my barn. Still works well and made in 1929. Steelyard near me also has a 1929 monitor-top running all the time. Employees keep their drinks in it. Quote Link to comment Share on other sites More sharing options...
whyverne14 Posted June 10, 2014 Share Posted June 10, 2014 I tried Rust Bullet on the surface rust of my old conversion van. After a couple years about 15% of the spots bled through. Not too bad. Kind of expensive but you don't have to top coat it. Quote Link to comment Share on other sites More sharing options...
passman Posted June 10, 2014 Author Share Posted June 10, 2014 I guess it’s good to hear that it isn’t that bad…. This is my first 30 year old vehicle and there has been a ton of surface rust. I’ve just been sanding/wire brush, coating with reformer, primer and painting, and that’s just the cab. I’ve just started looking into the coach more and finding more projects, never a dull moment that’s for sure Quote Link to comment Share on other sites More sharing options...
snail powered Posted June 14, 2014 Share Posted June 14, 2014 They look better then any of mine. Just surface rust. Best either leave it along - or brush it good, put some rust converter on it, and then paint. The worst thing you can do is clean it and not coat it. Rust can be somewhat inert. Looks bad but doesn't progress much unless you clean it off and leave it exposed. That's what destroys many engine cylinders (cavitation). Harmonics keeps knocking rust off and it starts over again and again. By the way - Linda mentioned not using old appliances in a house? Our chest freezer is an International Harvester made in 1948. Hot-air oil "furnace" in my barn is a Firestone made in 1947. I put "furnace" in quotes because the in 1947 - Firestone called it an "Air Conditioner." I also have a GE "Monitor Top" refrigerator out in my barn. Still works well and made in 1929. Steelyard near me also has a 1929 monitor-top running all the time. Employees keep their drinks in it. I had a monitor top fridge in the house I sold about 8 years ago. New owners kept it and it still running. Did put new gasket on the door and a new cord too as that rubber stuff was all cracked. Had a 5 burner, side oven, gas stove with the curvy legs to go with it. The fifth burner was just a tiny ring in the center and it was meant to keep the coffee pot warm. Quote Link to comment Share on other sites More sharing options...
