darrel Posted April 20, 2014 Share Posted April 20, 2014 My wife and I got tired of the small capacity of the FRESH WATER & POOP tanks. So I'm in the process of installing larger tanks. Have ordered a 22 gallon water tank and a 24 gallon poop tank. They should arrive in 1-2 weeks. Mean while I have torn out these two tanks. Planning for the install has been a challenge. Just researching for something that would fit was, well it was. Mite as well rebuild the toilet, why not a new water pump, new water drain valves, new dump valves, new tank hold down or up strapping, fill old holes, drill new holes, remount the spare wheel, new water gravity fill hatch, boy there must be more and I haven't even got the tanks yet. Will post more when I complete a step. Oh yah a new cork floor for the bathroom. Quote Link to comment Share on other sites More sharing options...
Roy in Jax Posted April 20, 2014 Share Posted April 20, 2014 Who sells the tank strapping? Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted April 20, 2014 Share Posted April 20, 2014 Nice job, always nice to be able to be self contained for as long as possible. Quote Link to comment Share on other sites More sharing options...
darrel Posted April 20, 2014 Author Share Posted April 20, 2014 Bought the strapping from a rv store in Eugene,or. It is mobile home tie down. It's 1" wide and what came off the tanks is 1 1/4" wide. Quote Link to comment Share on other sites More sharing options...
darrel Posted May 6, 2014 Author Share Posted May 6, 2014 Here are a few photos of the completed water tank install. Went from 12 gallons to 22 gallons. A new water pump 4chamber and mounted it on some carpet with foam back. Don't know if it is quieter mounted this way but defiantly quieter than old one. Also put foam water pipe wrap on the out side of the pump. Was told it would help with noise. The cork floor in the bathroom is nice. Had to install a new gravity water fill door, if you look close you can see the aluminum wall structure in the photo. This is our front yard frog. Quote Link to comment Share on other sites More sharing options...
darrel Posted May 7, 2014 Author Share Posted May 7, 2014 The poop tank is mounted and holds water that means it should hold poop. New valves, they work slick. I don't know if I would ever do this mod ever again. Every thing had to be remounted and custom fit. Still have to remount the spare wheel. Ran out of time, going fishing. Quote Link to comment Share on other sites More sharing options...
WME Posted May 7, 2014 Share Posted May 7, 2014 I can't tell if its an optical illusion or if the gray drain runs up hill a bit. If it goes up hill then you are not draining all of the tank and that means you have less capacity. Quote Link to comment Share on other sites More sharing options...
darrel Posted May 7, 2014 Author Share Posted May 7, 2014 You have a good eye. Yes the drain is running up hill. It is temporarily supported with a plastic tie. When I drain the tanks I always try to have the rear wheels low. Quote Link to comment Share on other sites More sharing options...
Ron 'n Sue Posted May 26, 2014 Share Posted May 26, 2014 Can't wait to see and hear all about this upgrade when you're here this summer, Darrel Quote Link to comment Share on other sites More sharing options...
darrel Posted May 27, 2014 Author Share Posted May 27, 2014 WE, re at the KInetic races in Arcata, Ca. SO far tanks are working out great. WAter tank is readin empty but still have over 3 gallons. Poop tank has lots of voluhm left. THis is our 4th day. HOpe to make it to Vancouver Isl. This year. Quote Link to comment Share on other sites More sharing options...
