sdboltdude Posted March 14, 2014 Share Posted March 14, 2014 When I 1st installed the flush floor base for table I drilled through the 1/8 floor & foam bottom I stopped when I got to second 1/8 plywood under foam the base didn't sit flush I used the carpet so it fit better just was not stable enough. so I drilled through bottom 1/8 floor board and yup drilled all the way through couch Im glad the gas tank was not flush with couch frame could of been real bad.. going to seal with 3M5200.. is this a normal install when using a flush mount base? Quote Link to comment Share on other sites More sharing options...
WME Posted March 14, 2014 Share Posted March 14, 2014 Yep possibly normal. It depends on the floor. My Escaper had the same thing from the factory Quote Link to comment Share on other sites More sharing options...
5Toyota Posted March 14, 2014 Share Posted March 14, 2014 normal in my dolphon 1987 Quote Link to comment Share on other sites More sharing options...
sdboltdude Posted March 15, 2014 Author Share Posted March 15, 2014 Yep possibly normal. It depends on the floor. My Escaper had the same thing from the factory normal in my dolphon 1987 my 1987 mini cruiser now has a "stock" table mount Steve Quote Link to comment Share on other sites More sharing options...
