needsunenergy Posted January 20, 2014 Share Posted January 20, 2014 I removed my stove top hood to paint it and then connected it back together. The wiring seems right because i was able to turn on one of the lights that was connected to the circuit but as soon as i turned it off and on, the fuse blew. Can it be something metallic touching one of the wires? Idk what to do. I keep blowing fuses! hah Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 20, 2014 Share Posted January 20, 2014 Guess at this point the only thing to do is take it back out and see what happened. The little fan is also powered from the same circuit so check that too. Quote Link to comment Share on other sites More sharing options...
fred heath Posted January 20, 2014 Share Posted January 20, 2014 Check the condition of the wire jacket where it passes into the hood. Somewhere you got your 12v hot going to ground. As 12v is considered (low voltage) electricians tape should work fine to cover a bare area on the wire. The fact it was working fine before removal gives you a good starting point. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted January 21, 2014 Share Posted January 21, 2014 plus or negtive on the light may not matter . but the fan moter most likly has to have the correct polarity Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted February 6, 2014 Share Posted February 6, 2014 if polarity is backwards on the fan it should run in reverse. something is grounding out. on mine, the switches are pretty cheap - they work intermittent now but no fuses are blowing Quote Link to comment Share on other sites More sharing options...
