MikeW Posted April 24, 2012 Share Posted April 24, 2012 I have a 92 Toyota Winnebago and the black holding tank has been damaged near the exit. I have tried to repair it on the outside by using different glues but it still leaks abit. Does anyone know of anything I can pour into the bottom of the tank that would setup and plug the cracks? I have tried ABS glue but it flakes off the bottom of the tank. Any suggestions would be appreciated. Mike Quote Link to comment Share on other sites More sharing options...
linda s Posted April 24, 2012 Share Posted April 24, 2012 Look here http://toyotamotorhome.org/forums/index.php?showtopic=3877&st=0&p=21580&hl=+fix%20+holding%20+tank&fromsearch=1entry21580 Post number 7 by me. Process works very well. Still no leaks on mine 2 years later LS I have a 92 Toyota Winnebago and the black holding tank has been damaged near the exit. I have tried to repair it on the outside by using different glues but it still leaks abit. Does anyone know of anything I can pour into the bottom of the tank that would setup and plug the cracks? I have tried ABS glue but it flakes off the bottom of the tank. Any suggestions would be appreciated. Mike Quote Link to comment Share on other sites More sharing options...
MikeW Posted April 24, 2012 Author Share Posted April 24, 2012 Thanks, Great Idea. I will have to figure out a way of painting inside of the tank. Maybe a long brush thing. Mike Quote Link to comment Share on other sites More sharing options...
linda s Posted April 24, 2012 Share Posted April 24, 2012 No you can't paint the inside. All has to be done from the outside. Repaired properly by being built up from outside will last for years. From inside you will just clog it forever Linda S Thanks, Great Idea. I will have to figure out a way of painting inside of the tank. Maybe a long brush thing. Mike Quote Link to comment Share on other sites More sharing options...
WME Posted April 24, 2012 Share Posted April 24, 2012 Go to PPL motor homes and look for holding tank repair kits. I've use VersaChem one and it was still good when I sold the unit. Quote Link to comment Share on other sites More sharing options...
