Marco1503 Posted March 12, 2012 Share Posted March 12, 2012 i want to buy an entry door but everyone im calling about quotes seems to charge from $550-900 dollars for a door. does anybody know a place where it is cheaper.im in califonia so thats prefeberyble but i can travel if i need to. Quote Link to comment Share on other sites More sharing options...
linda s Posted March 12, 2012 Share Posted March 12, 2012 Don't know where you are in California but here are a couple near San fran http://sfbay.craigslist.org/nby/rvs/2872677326.html http://sfbay.craigslist.org/eby/rvs/2895113350.html LS i want to buy an entry door but everyone im calling about quotes seems to charge from $550-900 dollars for a door. does anybody know a place where it is cheaper.im in califonia so thats prefeberyble but i can travel if i need to. Quote Link to comment Share on other sites More sharing options...
Totem Posted March 12, 2012 Share Posted March 12, 2012 yikes, salvage yards know a victim when they see it. Have you tried finding a yard where they will let you pick a part? Quote Link to comment Share on other sites More sharing options...
Vanman Posted March 13, 2012 Share Posted March 13, 2012 Marco1503 i want to buy an entry door but everyone im calling about quotes seems to charge from $550-900 dollars for a door.<br />does anybody know a place where it is cheaper.im in califonia so thats prefeberyble but i can travel if i need to. Try these guys, http://www.rvdoctorgeorge.com/ .. vanman Quote Link to comment Share on other sites More sharing options...
Galvanized Knight Posted March 22, 2012 Share Posted March 22, 2012 Ebay does have quite a few from time to time. Quote Link to comment Share on other sites More sharing options...
Greg du Vermont Posted April 20, 2012 Share Posted April 20, 2012 Our 85 Dolphin had a bad door. We took it off, carfully disaassembled it. The aluminum framing, window, latch ect were all good. We replaced rotted cross members as needed and added styrofoam to the areas possible. We went to Home depot and puchased tectured fiberglass wall board, like you would use in a bathroom. Used the old skins as a template, jig saw cut out new panels. Riveted new panels to the inside and outside of aluminum perimeter frame, reinstalled window and hardware. Good as new, maybe better. Looks completly factory and has held up for 10 years. Also used the same material to reconstruct an outside storage door. Less than $100. Quote Link to comment Share on other sites More sharing options...
linda s Posted April 21, 2012 Share Posted April 21, 2012 Don't know where in Ca but here are a few http://sandiego.craigslist.org/csd/rvs/2961587519.html http://sfbay.craigslist.org/nby/rvs/2946485335.html http://sacramento.craigslist.org/rvs/2917877288.html DR George is also a great place for used stuff LS i want to buy an entry door but everyone im calling about quotes seems to charge from $550-900 dollars for a door. does anybody know a place where it is cheaper.im in califonia so thats prefeberyble but i can travel if i need to. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted April 21, 2012 Share Posted April 21, 2012 five hundred to 1000 dollors must be brand new the wrecking yards where i live often have moter homes and slid in campers you can buy parts off . rv dealer here says same prices for new. but a GOOD SHAPE used one would be ok i think. Quote Link to comment Share on other sites More sharing options...
jemezdave Posted June 26, 2012 Share Posted June 26, 2012 Our 85 Dolphin had a bad door. We took it off, carfully disaassembled it. The aluminum framing, window, latch ect were all good. We replaced rotted cross members as needed and added styrofoam to the areas possible. We went to Home depot and puchased tectured fiberglass wall board, like you would use in a bathroom. Used the old skins as a template, jig saw cut out new panels. Riveted new panels to the inside and outside of aluminum perimeter frame, reinstalled window and hardware. Good as new, maybe better. Looks completly factory and has held up for 10 years. Also used the same material to reconstruct an outside storage door. Less than $100. I rebuilt our's as well although I used pvc sheet for the exterior. Styrofoam was still in pretty good shape so I was lucky there. Rotted cross members were the big culprit for mine so they were replaced. Quote Link to comment Share on other sites More sharing options...
90toydolphin Posted June 26, 2012 Share Posted June 26, 2012 there's a very large RV parts, new and used, store in sacramento area. http://www.rvdoctorgeorge.com/ good luck if you haven't found a solution yet. Quote Link to comment Share on other sites More sharing options...
old goat Posted June 28, 2012 Share Posted June 28, 2012 My wife wanted to replace the door window frame. Removed the windoe and the indide of the door was bad, dry rot and TERMITES, how do termites get in the door? Rebuilt the door and looks like new. Need table saw to rip wood to size. Dont know why they could not use standered lumber in these things. Now I need to remove the siding to check for termites. Quote Link to comment Share on other sites More sharing options...
