Fuel door replacement
83 Ranger
I'm looking to replace my cracked fuel door on my 83 Gran Sport Ranger I looked through the forum and didn't see anything on this subject I believe the opening is 6.5" x 6.5" and overall is around 11" square I searched the internet and can't find anything to match Do other Toyota motorhomes use this style and if so would anyone have a link to where I can purchase one
Thanks in advance!
83 Ranger
Okay I was able to find a couple none that seem to be the exact size so I may have to open up the hole a little bit
Thanks for the replies
83 Ranger
Edited by 83 Ranger
If you open up the hole larger the plastic that goes around your fuel filler will no longer be attached. Better to go with a flush mount slightly smaller. I saw some that were a little more than 8 inches. Attach to the inside frame on your where you see the screws and grind off the old frame. Might need some Bondo to smooth it out but I'm sure you could get it to look OK.
This one is 11x10 so should fit pretty close. Absolutely do not damage the inside of your hatch. There is no replacement for that
Amazon.com: Thetford|B&B Molders RV Replacement Parts and Accessories RV Camper Extra Large Flush Mount Fuel Hatch Polar White PN 94313 : Automotive
