Bryanmay10 Posted September 3, 2023 Posted September 3, 2023 I swapped my 4:10to 4:88 today. Anyone have ideas on the correct torque numbers? I put everything back together around 20lbs, but I couldn’t really find anything to tell Quote
Bryanmay10 Posted September 3, 2023 Author Posted September 3, 2023 Bolt head are either 12mm or 14mm. Guessing bolt size is 8-10mm as that usually matches up Quote
IdahoDoug Posted September 3, 2023 Posted September 3, 2023 Try an online service manual to find your exact torque settings. Thats a pretty critical component and deserves careful attention. Diff internals also often spec a thread locker as they are subject to component-flexing forces that loosen fasteners. Quote
fred heath Posted September 3, 2023 Posted September 3, 2023 Marlin Crawler has a great data base to work from. I’m sure you will find the torque settings you need. Quote
thewanderlustking Posted September 3, 2023 Posted September 3, 2023 i simply zipped mine down with a small 3/8" impact and then probably hand tightened/checked them. 20-30 ft lbs is about right. It isn't a super critical number. Now you didn't specify, but I believe you are referring to the outer pumpkin nuts? The internal specs are VERY critical, don't guess on those. If you need internal specs and can't find them, hit us back up with year, model etc and I will see if I can log into Allldata or Identafix from home. If you just swapped the whole pumpkin assembly, then you shouldn't have messed with anything critical for torque specs. Quote
IdahoDoug Posted September 3, 2023 Posted September 3, 2023 Wont he also need a super critical pinion crush sleeve number if that was disturbed? Maybe clarify what you did as there are some absolutes with diffs needing tending to. Quote
