85 Dolphin front facing bubble window gasket
JIMER
do not use silicon to seal it. it will leak. just dealt with it myself. i don't remember where to get the outer gap filler bead, but someone here will chime in
   you need to use butyl rubber sealant.  same as used to install windshields
I'll be doing this one day, and making new windows, but what's the "outer gap filler bead"?  Are you referring to the bead of butyl?  Thanks.
referring to the rubber locking bead that holds the window against the frame
google pelland (i think) enterprises the have a sample set they can send you to be sure you get the right one
don't know how to put it here, but in the search bar type replace front window. search everywhere
