Sunny Girl Sal 91 Posted June 4, 2023 Share Posted June 4, 2023 Hi, I am a new Sunraider owner and wondering where I can locate the marine battery. I’m looking to test it make sure its life is good or replace it. I looked in all the outside, compartments aHi, I am a new Sunraider owner and wondering where I can locate the marine battery I’m looking to test it make sure it’s life is good or replace it. I looked in all the outside, compartments and under both of the seats but can’t seem to find where it’s located would appreciate help. Thank you! Quote Link to comment Share on other sites More sharing options...
fred heath Posted June 4, 2023 Share Posted June 4, 2023 Did you check under the hood? Many times the coach battery is located there. Quote Link to comment Share on other sites More sharing options...
Sunny Girl Sal 91 Posted June 6, 2023 Author Share Posted June 6, 2023 My boyfriend said he did but I’m going to double check. Thank you! Quote Link to comment Share on other sites More sharing options...
fred heath Posted June 6, 2023 Share Posted June 6, 2023 If you don’t find a second battery under the hood check the floor for a trapdoor setup. Sometimes they recess the battery compartment there. Good Luck Quote Link to comment Share on other sites More sharing options...
linda s Posted June 6, 2023 Share Posted June 6, 2023 Do you have a storage container on the back. Battery is behind it. If no container there should be a door on the back. Linda S Quote Link to comment Share on other sites More sharing options...
scottfromchi Posted June 28, 2023 Share Posted June 28, 2023 On 6/4/2023 at 7:47 PM, Sunny Girl Sal 91 said: Hi, I am a new Sunraider owner and wondering where I can locate the marine battery. I’m looking to test it make sure its life is good or replace it. I looked in all the outside, compartments aHi, I am a new Sunraider owner https://epicvin.com/license-plate-lookup/georgia and wondering where I can locate the marine battery I’m looking to test it make sure it’s life is good or replace it. I looked in all the outside, compartments and under both of the seats but can’t seem to find where it’s located would appreciate help. Thank you! typically located in one of the exterior storage compartments, often in a specific battery compartment with a vented door Quote Link to comment Share on other sites More sharing options...
extech Posted June 28, 2023 Share Posted June 28, 2023 usually under the hood on the drivers side Quote Link to comment Share on other sites More sharing options...
