Scott iv Posted February 28, 2022 Share Posted February 28, 2022 I've had my 1987 Escaper for five years now and have just come to realize I may have 4.88 gearing. By comparing my tach to the numbers posted here from online charts it would seem I do have 4.88. Is there any other way to know what differential gear ratio you have other than tachometer readings? Quote Link to comment Share on other sites More sharing options...
WME Posted February 28, 2022 Share Posted February 28, 2022 (edited) Here ya go. Easy peasy of you have a jack and jack stands...https://www.moderndriveline.com/how-to-determine-your-rear-axle-ratio/ Edited February 28, 2022 by WME Quote Link to comment Share on other sites More sharing options...
thewanderlustking Posted February 28, 2022 Share Posted February 28, 2022 I could be wrong, but pretty sure none of ours came with posi. So a single rear wheel up and the two tire rotations method will do fine. Also, I never went back and corrected those charts…. There is room for error for sure. And I don’t know about your Yota, but mine doesn’t have a tach. Point being trying to guess based on just those charts and perceived rpm, is just that a guess. Your best bet is the tire and driveshaft rotate test to determine it. Quote Link to comment Share on other sites More sharing options...
Scott iv Posted February 28, 2022 Author Share Posted February 28, 2022 Thanks for this. Yea, I installed a tach a few years back. I have to replace my rear 4 this year (8 years old though still look great; nexens). Will have it up and check it then. Quote Link to comment Share on other sites More sharing options...
