extech Posted June 2, 2021 Share Posted June 2, 2021 so i removed my dometic 461 and turned it over several times in 48 hours. still no cooling so.... anyone here needing parts im willing to send them for shipping costs only. the door, seal ,shelves, and freezer are very nice. you can contact me at zaveson@gmail.com. randy Quote Link to comment Share on other sites More sharing options...
Maineah Posted June 3, 2021 Share Posted June 3, 2021 They do make replacement cooling units other wise it looks to be in nice shape. Might be worth fixing. Quote Link to comment Share on other sites More sharing options...
extech Posted June 3, 2021 Author Share Posted June 3, 2021 from what i've seen the replacements cost as much as a new fridg. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 3, 2021 Share Posted June 3, 2021 No where near as much as a new fridge. New fridge will be at least a thousand. This cooling unit is $400. I have had 2 cooling units replaced on different rigs and both are still working fine after 10 and 15 years later Dometic Cooling Unit RM460,RM461 $400 | eBay Linda S Quote Link to comment Share on other sites More sharing options...
extech Posted June 3, 2021 Author Share Posted June 3, 2021 thanks Linda. maybe i will reconsider Quote Link to comment Share on other sites More sharing options...
linda s Posted June 3, 2021 Share Posted June 3, 2021 I more thing to try. I never quite understood why people think turning it over would get it working again. If the coils had never leaked and you don't know if they did. If it happened many years ago there would be no residual smell. OK but if the stuff is still in there it's not working because the ammonia has crystalized and no longer flows. While it's upside down gently heat the coils. Space heater, blow dryer, maybe a heat gun but on low and move it around constantly. If you can slip something behind the coils to protect the insulation that would help. It's possible the heat could help dissolve the crystals. Do this several times upright, upside down turning frequently. Might take an afternoon but even if it can save you $400 it would be good. When your done plug it in to 110 and see if anything happens overnight. Oh and make sure the dial is turned to AC and the temp dial is in the middle Linda S Quote Link to comment Share on other sites More sharing options...
extech Posted June 3, 2021 Author Share Posted June 3, 2021 thank you so much linda. you really look out for us. as for turning it over, the manual for it says to. so for now im going to renig on my offer of parts i will try the heating thing. ive got plenty of time randy Quote Link to comment Share on other sites More sharing options...
linda s Posted June 3, 2021 Share Posted June 3, 2021 Manual's don't consider really old ones. May work for few years old but ours are close to 40. Linda S Quote Link to comment Share on other sites More sharing options...
extech Posted June 11, 2021 Author Share Posted June 11, 2021 so i ordered a new cooling unit. arriving today. realized now would be the time to add a 12v heater in case i want it down the line, but i cant find a part no. for it, or an interchange. anyone? Quote Link to comment Share on other sites More sharing options...
extech Posted June 11, 2021 Author Share Posted June 11, 2021 just to share. tore my old cooling unit apart. this is why you can't tell if it's good or not. once the smell is gone, the evidence is encased in foam Quote Link to comment Share on other sites More sharing options...
linda s Posted June 11, 2021 Share Posted June 11, 2021 Is that a complete break where the yellow is on the pipe? Linda S Quote Link to comment Share on other sites More sharing options...
extech Posted June 12, 2021 Author Share Posted June 12, 2021 sure is. catostophic failure Quote Link to comment Share on other sites More sharing options...
linda s Posted June 12, 2021 Share Posted June 12, 2021 At least now you know the cooling unit is the problem and replacing it is the fix. Linda S Quote Link to comment Share on other sites More sharing options...
lansisco Posted June 13, 2021 Share Posted June 13, 2021 On 6/11/2021 at 9:15 PM, linda s said: At least now you know the cooling unit is the problem and replacing it is the fix. Linda S Linda, I have the same RM461 and my electrical heating element has failed. Do you know what part number I need? Gas works fine, electric slowly got weaker and then failed entirely recently. Thanks! Quote Link to comment Share on other sites More sharing options...
linda s Posted June 13, 2021 Share Posted June 13, 2021 3 hours ago, lansisco said: Linda, I have the same RM461 and my electrical heating element has failed. Do you know what part number I need? Gas works fine, electric slowly got weaker and then failed entirely recently. Thanks! This is for the 3 way model Dometic 0173735010 Heater 125Watt 12Volt And this is the 2 way DOMETIC 0173756016 RV REFRIGERATOR HEAT HEATING ELEMENT 160 WATT Both available online Download the manual so you have all the information you need in the future Mandiag.pdf (bryantrv.com) Linda S Quote Link to comment Share on other sites More sharing options...
extech Posted June 13, 2021 Author Share Posted June 13, 2021 thanks so much. i looked for that manual. where was it hiding? Quote Link to comment Share on other sites More sharing options...
