A simple matched system. Get the 30A controller . It will let you grow your system with out getting a new controller. It will work with 2 more panels and another battery.
Remember reducing power consumption is as important as extra power panels. LED lights and if you "need" a TV get a flat screen. Those are the 2 biggest power drains
Won't hurt. Mount the fuse close to the solar panel.
FWIW my roof is fiberglass and the cable run is in wood panels so Ive never fused the panels. The battery YES fuses
With the solar panel itself a fuse is not necessary but anything else connected to it yes. The normal test for current is to deadhead the panel yes a dead short with a current meter. Multiple panels series wired yes it would be a god ideal.
  • 4 years later...
