jetalkington Posted September 20, 2019 Share Posted September 20, 2019 My Sunrader had bench seats on one side of the house, across from the sofa. I have wanted the lounge chairs as I am not a fan of bench seats. I thought due to the fuel fill tube being in the way it was not possible. However, a couple days ago I found a picture of a Sunrader with the lounge chairs and I noticed they were raised on a platform. I am hoping this would raise the chair up enough to clear the fuel fill tube. Does anyone that has the lounge chairs have the dimensions for this platform? I have been trying to find them but no success. I would appreciate it if someone could get me the measurements so I could see if it is possible to put lounge chairs in my Sunrader when I put back the seating. It would also have an impact on how I fix the hole in my floor. I am not sure if it is even possible. I am pushing hard on my Sunrader as I can only work on it in September and October until I get it insulated. I work to many hours in the summer to be able to do any work on it. Thanks Quote Link to comment Share on other sites More sharing options...
Derek up North Posted September 20, 2019 Share Posted September 20, 2019 Like this? Sorry, no dimensions, but like the models with the dinette on the passenger side, the 'platform' is high enough to clear the rear wheels. Quote Link to comment Share on other sites More sharing options...
jetalkington Posted September 20, 2019 Author Share Posted September 20, 2019 Yes, except the one I have a picture of had a table about the same size as my current one. I should have asked where the fuel fill tube is on the models with the chairs. Mine is on the passenger side, just behind the passenger door, but I have a rear door and rear bath. I don't see my floor plan in the image. It looks like the CG in your image has a rear door and lounge chars but I can't be sure. I looked at a few pictures of Sunraders with lounge chairs but, I don't see the fill tube. Maybe they move it to the drivers side. I didn't expect that. I can work off the wheel wells, if need be. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted September 20, 2019 Share Posted September 20, 2019 Quote Link to comment Share on other sites More sharing options...
jetalkington Posted September 20, 2019 Author Share Posted September 20, 2019 Mine is closest to the RSA. In fact there is a little plastic embossed tape on the outside of mine that has 21-RSA on it. Looks like a dealer label. However, mine is flipped. Refrig by rear door and kitchen next to bath. I can't imagine they would put the fuel fill tube in the same box as refrigerator & furnace. Meaning it probably is in a different location. I din't realize they would move it around. Sounds like a lot of trouble. Quote Link to comment Share on other sites More sharing options...
linda s Posted September 20, 2019 Share Posted September 20, 2019 I've never seen a Sunrader with a fuel filler tube moved. Do you have pictures of the inside of yours? Would be nice to see Linda S Quote Link to comment Share on other sites More sharing options...
jetalkington Posted September 20, 2019 Author Share Posted September 20, 2019 Here they are. I guess I thought this was the way they were always. Is this not the case? While we are looking at gas tubes do you know where I could find a new cover for the fuel. This one looks terrible and I have not seen it on any other Sunrader. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted September 20, 2019 Share Posted September 20, 2019 6 minutes ago, jetalkington said: This one looks terrible ... Nothing a lick of paint wouldn't improve. Quote Link to comment Share on other sites More sharing options...
WME Posted September 20, 2019 Share Posted September 20, 2019 Make old plastic new...😎...https://www.youtube.com/watch?v=Cz-HSjGj0ek Quote Link to comment Share on other sites More sharing options...
AmyDC Posted September 20, 2019 Share Posted September 20, 2019 I have the same model as you, @jetalkington -- where there is the rear bath, the kitchen on the driver's side, and the fridge on the passenger's side right slightly forward of the entry door - then slightly forward of that is the dinette area. My gas tank fill is almost exactly where yours is - directly behind the passenger door. When I get home today, I'll take a few pics and show you where everything is located on mine. 🙂 Quote Link to comment Share on other sites More sharing options...
jetalkington Posted September 20, 2019 Author Share Posted September 20, 2019 Thanks for the tip on Salon Care. I am going to try that. I am not saying my fuel fill was moved. Sorry if I wasn't clear. I am thinking that they may have moved the gas tank fill to other locations on models other than mine to allow for the door or appliances to be installed up front where my dinette is. I didn't think they would do that. I got to look at mine and the gas tank fill might interfere with me wanting to put lounge chairs in, instead of putting back my bench seats. The top of the fill tube is above the wheel well. Which I am guessing is the bottom line for the platform. So I am still trying to get an idea on dimensions of the platform and chairs to see if might clear the top of the fill that would be showing.. Quote Link to comment Share on other sites More sharing options...
jetalkington Posted September 20, 2019 Author Share Posted September 20, 2019 Amydc, does yours look like mine on the outside, or does it have a door over it? Quote Link to comment Share on other sites More sharing options...
AmyDC Posted September 20, 2019 Share Posted September 20, 2019 Looks like yours. No door on mine - though mine does look a bit newer. I’m thinking a previous owner replaced it at one time.... perhaps did a repair or modification because I noticed there is a leak when I filled up at gas stations bringing it home. I had to fill up real slowly and I saw some fuel drip while filling up - perhaps a hose or elbow or something isn’t angled right? I don’t know. Haven’t really looked into it yet. On my list of things to do. Quote Link to comment Share on other sites More sharing options...
jetalkington Posted September 20, 2019 Author Share Posted September 20, 2019 Thanks. I called a local beauty salon and they have the Salon Care 40 in stock. $4 Guess I will try that next. Quote Link to comment Share on other sites More sharing options...
AmyDC Posted September 20, 2019 Share Posted September 20, 2019 @jetalkington make sure to wear gloves when applying the 40 volume developer... it can burn ya if exposed to skin too long Quote Link to comment Share on other sites More sharing options...
jetalkington Posted September 20, 2019 Author Share Posted September 20, 2019 Thanks I will. My gas fill looks to be colonial white. Wonder what it will look like when done. BTW: I am guessing you have bench seats in your dinette. Right? I am still stuck on seeing if I can get the lounge seat to fit. I think I hijacked my own thread. Quote Link to comment Share on other sites More sharing options...
AmyDC Posted September 20, 2019 Share Posted September 20, 2019 (edited) hahah I think you did I think my dinette area did have bench seats - but the previous owner had already removed them, so I can't be 100% positive. But I will say that I did have a rather large dinette table that I removed 2 weeks ago. So that makes me think it had the bench seats. That table was big and heavy. Currently, though I have a captains chair (what I think you're calling a lounge chair?) in the nook to the right of the kitchen. My Sunrader didn't come with a sofa on the driver's side. Instead, it had an additional large closet - then the kitchen - then a captains chair - then the bunk. I could move the captains chair in the location where one of the old bench seats was and take a pic for you, if you want? But I don't have the table anymore to give you a full idea of the space unfortunately. Edited September 20, 2019 by AmyDC Quote Link to comment Share on other sites More sharing options...
jetalkington Posted September 20, 2019 Author Share Posted September 20, 2019 My curiosity is whether the chair will swivel with out hitting the gas fill pipe. I planned to do a mock up when I got that far. It would be the location closest to the cab passenger. Where the fuel fill neck is of course. If you have the time I would appreciate it. Quote Link to comment Share on other sites More sharing options...
AmyDC Posted September 21, 2019 Share Posted September 21, 2019 Here’s some pics I grabbed this morning. Pardon the mess, I’m smack dab in the middle of demo. As you can see, I also have the fuel hose in the same spot - totally bizarre. I’m not sure why it’s like this, but if possible, I want to get it out of the camper and put under the camper. I didn’t try moving the captains chair over yet, but I’ll give it a go later. Has anyone ever come across something like this before? Any ideas on what to do about it? Quote Link to comment Share on other sites More sharing options...
jetalkington Posted September 21, 2019 Author Share Posted September 21, 2019 AmyDC, thanks for posting this. I don't have a lot of background with Sunraders. Which why I joined this forum. I have looked at a lot of pictures of Sunraders and so far it seems the 21 footers with a rear door that this is the normal location for the fuel fill. I am just going to work around it. I finished scrapping insulation off my ceiling yesterday so I am ready to start prepping for building. You don't have to go through trouble of moving the chair. I have a clean slate now and will build what fits. I do like your fuel trim better than mine. Thanks again. Quote Link to comment Share on other sites More sharing options...
Freddy Posted May 30, 2021 Share Posted May 30, 2021 Hi! I randomly saw this old post and tho I'd imagine u r past this point, I have the dimensions of my box that the "captain's" chairs sit on- stock for my rear entry rear kitchen/bath- I measured 'cause I took chairs out for remodel/insulation. 14"high, 22.5" deep, 88" long with my fridge next to one chair. Chairs on swivels, set at very edge of box (see pic) 18" from outside edges, 17" from table hole ( I have the funny octagonal number.) I'm quite interested to see more photos of your project! Quote Link to comment Share on other sites More sharing options...
Freddy Posted May 30, 2021 Share Posted May 30, 2021 Oh- also note the mounting tab on the left has been snipped to fit closer to edge- Quote Link to comment Share on other sites More sharing options...
