Donnie Posted May 9, 2015 Share Posted May 9, 2015 Hello all, probably a long shot, but I'm goin' for it. . My '78 Chinook has a Basler PCM15CK power converter that is original to the truck.... I probably will never use it but I would like to keep the original one in it. I am searching for an original manual or a COPY of the original manual just to try to complete the literature on the truck & the appliances.... Operators book, schematic on the internals.......... anything at all... relating to this converter...... thanks, Donnie Quote Link to comment Share on other sites More sharing options...
linda s Posted May 9, 2015 Share Posted May 9, 2015 Here hope this comes through _78chinookpowerpack.pdf Linda S Quote Link to comment Share on other sites More sharing options...
zero Posted May 9, 2015 Share Posted May 9, 2015 Here hope this comes through _78chinookpowerpack.pdf Linda S That is for the Basler ES-15. Wrong model. Basler PCM-15CK is quite different. One big difference is it uses the modular rectifier trio that the later ES-1 does not. Quote Link to comment Share on other sites More sharing options...
zero Posted May 9, 2015 Share Posted May 9, 2015 Here's some info on the Basler PCM15 with the CK battery-charger option. I've repaired many of them. If you search the archives in this forum, I posted a write-up on them awhile ago with repair info. Quote Link to comment Share on other sites More sharing options...
Donnie Posted May 10, 2015 Author Share Posted May 10, 2015 Thank you Linda & JD for your effort in fulfilling my request pertaining to the old Basler converter..... Donnie Quote Link to comment Share on other sites More sharing options...
