Water Line Drain Plugs
I am draining the water lines in my Warrior using the 4 drain plugs. I pulled the metal rings and got 3 open but on the 4th one the metal ring opened and now I don't have anything to pull on. I may be able to put my vise grips on the plunger and pull but am afraid of damaging it. I don't know what to use to try threading through the hole where the metal ring was. Any ideas how to finish draining my lines?
Why not go to a fishing store and get another wire ring to put in where the other ring was? You can pick them up in any fishing tackle shop for about $1 per pack. They are called split rings.
  • 6 months later...
What ever you do be very CAREFUL not to damage the fitting. I have a '90 Warrior that developed leaks at the top seal around the plunger. After removing the fitting I discovered the problem. The O ring seals just gave up after 25 years. I was never able to find replace O rings of the right size. Winnebago was no help. I am in the midst of making new drain valves from CVC pipe. It looks sort of Rube Goldberg, but seems to be working. I now have two old Warrior fittings if anyone would like to have them. The two under the sofa are a little easier to get to but haven't failed yet. Something to look forward to.....
When I rehabbed mine I looked at those valves with some curiosity as I first tried to figure them out. Once I got the idea of what they were for and found they were pretty finicky if not seated just right, I looked to replace them with Pex valves and fittings. At the time I found a company that sold online and ordered up enough to redo all of them and then some. Still have a bag of fittings. Got left over T's, elbows and couplers. This is what I replaced those with. Can find the same sort of thing on Amazon. Search for pex 3 way valve.
those fittings are used in manufactured housing my 96 double wide is full of them. work very well and I am on city water. never had a problem with them.
