Muldoon Posted August 25, 2014 Share Posted August 25, 2014 I've recently purchased a 1992 Toyota Seabreeze motorhome. No manual came with the unit and the previous owner, an elderly woman, had no knowledge of the operations of the MH. I seem to have one sewer hose and one draining outlet with one release valve. Do both gray and black water tanks drain through the same outlet and at the same time, or am I simply missing something here? Would appreciate any advice as I'm stumbling in the wilderness here. Thanks. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 25, 2014 Share Posted August 25, 2014 Need pictures. Where the tank valves are depends on floor plan Linda S Quote Link to comment Share on other sites More sharing options...
5Toyota Posted August 25, 2014 Share Posted August 25, 2014 if anything like the rear bath dolphin there should be a smaller valve pulls straight out the large black tank one is maybe under on the left against the rear tire is a little harder to see. and yes they should dump through the one outlet. black tank do first flush hose with grey tank Quote Link to comment Share on other sites More sharing options...
Muldoon Posted August 25, 2014 Author Share Posted August 25, 2014 Yes, toilet and shower are in the rear. MH is in storage now, but I'll check around the rear tire this weekend when I go get it. Thanks much. Quote Link to comment Share on other sites More sharing options...
