Debbit Posted April 28, 2014 Share Posted April 28, 2014 The water heater in my sun rader is a suburban 610 ac3. I'd like to ask if anyone can advise me on the water heater. It looks newer, like a replacement, and the manual I have is for a different model, so no help there. The pilot lights, and stays lit, but the main burner doesn't come on. Could be some part, like a thermo type switch, but I'm wondering if there is something else it could be. Any tricks or suggestions? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 28, 2014 Share Posted April 28, 2014 Is '610 ac3' not the Gas Control Valve? http://www.sitgroup.it/content/view/220/lang,en/ There are a couple of Suburban manuals here:- http://bryantrv.com/docs.html#water_heater What manual have you got? Quote Link to comment Share on other sites More sharing options...
Debbit Posted April 28, 2014 Author Share Posted April 28, 2014 Here is a picture of the control part. I probably don't know what model it is. I did see sure urban on the side of it. The manual in the stack it came with is mor-flo and looks nothing like what is in the camper. Thanks so much for the video and links to manuals. I was having no luck finding any! A pic of the water hearer controls Quote Link to comment Share on other sites More sharing options...
Maineah Posted April 28, 2014 Share Posted April 28, 2014 Sounds like the thermo couple it's a little thin tube that connects to the control valve and the other end is right at the pilot light make sure the pilot light end is right in the flame, they do go bad. The ideal is to turn off the gas if the pilot light goes out. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 28, 2014 Share Posted April 28, 2014 Can you try and post better pictures of all the labels? I can see (but not read) a couple in the picture you posted above. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted April 29, 2014 Share Posted April 29, 2014 does the switch have a "Run" position? IF you r leaving it n the pilot position it should not light off the big burner. Quote Link to comment Share on other sites More sharing options...
Debbit Posted April 29, 2014 Author Share Posted April 29, 2014 We are on our way east on a trip. Just now checking internet. I'll post pictures soon! It does have 3 settings on knob, off, pilot and on. The pilot stays on when I turn knob to run, but the main flame never comes on. We will take a closer look when we get to tulsa. Thanks again for all the input! Quote Link to comment Share on other sites More sharing options...
Vanman Posted April 29, 2014 Share Posted April 29, 2014 Before replacing anything check the electrical connections on the gas valve from the thermocouple, it's a low voltage and low current output device so connections are cruical. john Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted April 29, 2014 Share Posted April 29, 2014 sounds like the controller is not sending gas to the big flame. Some vehicles have coolant lines from the engine that heat the water while underway. By chance do you see any radiator / automotive style hoses going to / from the water heater? When you turn on a hot water faucet is hot water present? I have also heard that if the pilot is on long enough it will heat the water to the point that the big flame is not activated unless someone opens a hot water faucet and cold water enters the water tank. I am not inclined to think that you have a thermocouple issue. If the thermocouple was not detecting heat at the pilot light &/or was not providing a signal to the controller the controller should cut off all gas extinguishing the pilot light Quote Link to comment Share on other sites More sharing options...
Boots Posted May 4, 2014 Share Posted May 4, 2014 Hi, Guessing about this, but I would look for a circuit board, that has a built in safety circuit, so if the boards flame sensor is malfunctioning, then it will prohibit it from starting up. Another thought is that the thermostat or controller is faulty or perhaps has a bad ground or control switch (off/on) Boots Quote Link to comment Share on other sites More sharing options...
linda s Posted May 4, 2014 Share Posted May 4, 2014 The picture of the on off switch match a Suburban SW series water heater Look here. Upside down but looks the same. I don't remember is yours a rear bath or dinette. If it's the rear bath the 6 gallon, rear dinette 4 gallon Linda S Quote Link to comment Share on other sites More sharing options...
Debbit Posted May 6, 2014 Author Share Posted May 6, 2014 Yes, that matches! Mine is rear dinette. We are still on the road (and having fun) I've just been boiling water as needed. I do want to get it lit though, and will work on it when we get home. Thanks! Quote Link to comment Share on other sites More sharing options...
linda s Posted May 6, 2014 Share Posted May 6, 2014 Here's a link for the service manual https://docs.google.com/viewer?url=http://direct.bryantrv.com/docs2/docs/subsw.pdf Linda S Quote Link to comment Share on other sites More sharing options...
Debbit Posted May 6, 2014 Author Share Posted May 6, 2014 Thank you so much!! Quote Link to comment Share on other sites More sharing options...
Debbit Posted May 9, 2014 Author Share Posted May 9, 2014 So reading the service manual Linda so helpfully provided, I saw that once the pilot was lit you turn it to "on" then depress knob and turn to the line on the dial. BINGO! Big flame and hot water! Quote Link to comment Share on other sites More sharing options...
