JoeyDeezNutzz Posted November 6, 2013 Share Posted November 6, 2013 Hey guys I have a 15' or so Nema tt-30 extension cord that was behind a standard GFI edison outlet box but the cord doesn't fit through the small hole. Is there something someone could recomend that can be flush mounted to the side of my fiberglass motorhome with easy access? It's pretty crappy to take the flip top edison gfi flush box off every time I want to charge my batteries! Thanks, Joe Quote Link to comment Share on other sites More sharing options...
linda s Posted November 6, 2013 Share Posted November 6, 2013 Here's a surface mount outlet http://www.ebay.com/itm/RV-Camper-Trailer-Receptacle-Outlet-30-Amp-125-Volt-Power-Electrical-30A-125V-/300994882500?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item4614b16bc4&vxp=mtr#ht_63wt_917 And here's a nice looking waterproof cover for it http://www.ebay.com/itm/Hubbell-Marine-RV-Aluminum-Weatherproof-Electric-Outlet-Cover-/231086599250?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item35cdd5ac52&vxp=mtr#ht_38wt_917 They have larger ones with doors but this looks more Chinook size Linda S Quote Link to comment Share on other sites More sharing options...
Maineah Posted November 6, 2013 Share Posted November 6, 2013 Isn't your cord fastened to your panel box? Guess I'm a little confused by the description. It should not go through a GFI they are only rated 20 amps max. If the cord is male on both ends that is a good way to get electrocuted a TT30 (travel trailer 30 amp) is a male plug. The cord is a #10 SJ with a TT30 on one end only. If you want to make a cord to plug into your MH it needs a L5-30 twist lock and a flush mount some thing like a HBL3334C fastened to the MH. Quote Link to comment Share on other sites More sharing options...
JoeyDeezNutzz Posted December 4, 2013 Author Share Posted December 4, 2013 yeah i have the male end tt30 looking for power. There is no face plate waterproof flip top. Linda that second link is all I need! I was looking at them by Leviton 50a rated (largest hole) and they are like 80 - 120 bucks!! Thanks for the response guys I need to be more active on this forum, great networking! Quote Link to comment Share on other sites More sharing options...
