Ashevillian Posted October 8, 2013 Share Posted October 8, 2013 I apologize if this is the wrong spot for this add, but I saw this add on Craigslist here in Asheville. I also saw it driving around the other day. Seems like the price might be a bit high. http://asheville.craigslist.org/cto/4100530187.html Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 8, 2013 Share Posted October 8, 2013 This person is DREAMING. Maybe 1K tops. More like $500-700. I wouldn't mind buying the grill sections. Quote Link to comment Share on other sites More sharing options...
Ashevillian Posted October 8, 2013 Author Share Posted October 8, 2013 This person is DREAMING. Maybe 1K tops. More like $500-700. Yes, I was thinking the same. I thought $1,000 would be high...notice no inside pictures too...that can't be good Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted October 8, 2013 Share Posted October 8, 2013 The rust is the biggest issue. I haven't seen a Chinook in decent shape go for much less than $2,500, and depending on how rare they are in that part of the country...I don't know. Rust bucket 79-83 4x4s go for $4k+ in the northeast and Midwest. But I don't know how much rust NC gets. I guess my point is that depending on how rare a 70s toyota is in this area, his price is actually pretty reasonable, IF the inside is together. Big if. Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 8, 2013 Share Posted October 8, 2013 If the body is showing that much rust chances are the frame is in bad shape. Don't think its originally from NC. Or it was parked next to the ocean most of its life. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted October 8, 2013 Share Posted October 8, 2013 Yeah... When they mentioned the floors being rusty, that's a bad sign. I'm guessing there are a couple holes in the cab you can see the road through. Quote Link to comment Share on other sites More sharing options...
TheWhovian Posted October 11, 2013 Share Posted October 11, 2013 It mentions a 5 lug rear axle, is that not a problem with Chinooks? Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 11, 2013 Share Posted October 11, 2013 It mentions a 5 lug rear axle, is that not a problem with Chinooks? Normally it would be. But it's got the "heavy duty" 5 lug. LOL (no such animal). Quote Link to comment Share on other sites More sharing options...
Derek up North Posted October 11, 2013 Share Posted October 11, 2013 5 lug rear axles have never been considered a problem with the Chinooks. They're much lighter than a typical Toyota MH. Heavy duty 5 lug axle? Well, there's the 1-Ton single rear wheel pickup axle which, I believe, is different from the 1/2 Ton axle. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted October 11, 2013 Share Posted October 11, 2013 Yeah it's generally considered that Chinooks are ok with the regular 5 lug. Obviously a one ton would be nice...but Chinooks weren't part of the not-quite-a-recall recall. Best to keep the weight down and the bearings in good shape, though... Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 12, 2013 Share Posted October 12, 2013 My 1979 Galavan has the 5 lug "death axles" with "foolies". My mh is 16' with an extra 2' added for the rear deck which holds the generator. The total weight loaded, with me, comes in at 4200 lbs. I changed the rear bearings and seals during overhaul 2 years ago. I have since put on over 25K with no axle problems. I understand most of the rigs owned are much heavier than mine. I see no problem using it on a Chinook. Just my opinion. Quote Link to comment Share on other sites More sharing options...
linda s Posted October 12, 2013 Share Posted October 12, 2013 5 lug rear axles have never been considered a problem with the Chinooks. They're much lighter than a typical Toyota MH. Heavy duty 5 lug axle? Well, there's the 1-Ton single rear wheel pickup axle which, I believe, is different from the 1/2 Ton axle. Derek the only changes they made to the 1 ton single wheel truck was improving the suspension. Axle is exactly the same. They added the offset shocks and the 5 leaf springs. Brakes might be larger too but not sure about that. This is described in the small print on the toyota brochures Linda S Quote Link to comment Share on other sites More sharing options...
Derek up North Posted October 13, 2013 Share Posted October 13, 2013 I won't argue any of that, but with SRW Toyota also rated the 1-Ton as 6000lb GVWR as I recall Sounds 'Heavy Duty' enough for a 4000lb Chinook.. The 'Death Axle' only becomes the 'Death Axle' when you bolt on a set of foolies (and I've seen no record of anyone ever becoming DEAD with a 'Death Axle'). Quote Link to comment Share on other sites More sharing options...
