douglitas Posted August 9, 2013 Share Posted August 9, 2013 little by little addressing the issues on our 87 Seabreeze we bought 6 mo ago. Now we notice that when you try to take a shower, the water leaks out of the faucet assembly where it connects to the shower tube. Our local MH repair place (generally very competent and reasonable) says we have to cut a hole in the wall between the shower and the stove in order to access and replace the fitting. Any comments or suggestions? I guess I could just tape the piece back after repair is made. Quote Link to comment Share on other sites More sharing options...
sdboltdude Posted August 9, 2013 Share Posted August 9, 2013 double check to see if their already is a hole/sub panel my rv already had a factory cut out to replace shower fixture ... if not cut square hole 5 or 6 inches from top & bottom of center faucet (enough room to work) you could prob do with a good sharp razor knife faucet are cheap on ebay/amazon Quote Link to comment Share on other sites More sharing options...
linda s Posted August 9, 2013 Share Posted August 9, 2013 If it's the assembly itself that is leaking I don't believe a hole needs to be cut. Post a picture of the faucet and the area where you would have to get behind it. Pretty sure the shower and faucet assmebly dismantles from the front. I will take a look at mine later today and see for sure. Linda Well if it's just a washer you might be able to replace it with the faucet in place but if it needs replacement looks like you do need to cut a hole behind it to access. Mine is accessable from the closet. here are some instructions http://www.rvtravel.com/blog/rvnow/2008/05/free-yourself-from-dribbling-rv-shower.html Quote Link to comment Share on other sites More sharing options...
douglitas Posted August 9, 2013 Author Share Posted August 9, 2013 thanks everybody...I've got some work cut out for me! Quote Link to comment Share on other sites More sharing options...
waiter Posted August 10, 2013 Share Posted August 10, 2013 Heres how I did mine. I had to replace my entire fixture, as the port that the anti-siphon valve screws into was cracked and thats where the leak was. Look carefully, as a faulty anti siphon valve will leak water all over the place. It screws into the faucet, and the shower hose screws into it.http://toyotamotorhome.org/forums/index.php?showtopic=3837 John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
douglitas Posted August 12, 2013 Author Share Posted August 12, 2013 thank you all for great help! will be moving on this soon and will keep you posted. Quote Link to comment Share on other sites More sharing options...
douglitas Posted September 24, 2013 Author Share Posted September 24, 2013 RV shop cut hole in wall above stove and replaced shower faucet. going to the mountains this weekend...Oh for a hot shower! They did a nice job of replacing the cut out part. Quote Link to comment Share on other sites More sharing options...
