tlava Posted June 16, 2013 Share Posted June 16, 2013 any ideas about least expensive way to get a new AC system into an '84 (22re)? it will have to be a new system--no current one installed. Quote Link to comment Share on other sites More sharing options...
zero Posted June 16, 2013 Share Posted June 16, 2013 any ideas about least expensive way to get a new AC system into an '84 (22re)? it will have to be a new system--no current one installed. Level of "cheapness" depends on what somebody is selling parts for. My choice would be to find a junked 84 truck with factory AC and swap everything over. I just did that with a 1995 Geo-Chevy Tracker. Originally had manual steering and no AC. I bought a wrecked one for $175 with PS and AC and swapped it over. Note that installing a factory setup is a lot of work. An aftermarket kit is simpler. There are lots of older Toyota trucks around in junkyards with aftermarket add-on AC systems in them that go cheap. I have several here (1978 vintages). Quote Link to comment Share on other sites More sharing options...
zero Posted June 16, 2013 Share Posted June 16, 2013 You ,might want to look around this place for ideas and prices if you want an add-on kit. http://www.nostalgicairparts.com/air-conditioning/universal-ac-system-select-an-evaporator-451.php http://www.nostalgicairparts.com/air-conditioning/1989-1995-toyota-pickup-truck-ac-system-299.php Quote Link to comment Share on other sites More sharing options...
5Toyota Posted June 16, 2013 Share Posted June 16, 2013 thank you that is neat that you can still buy what was in the old days commenly known as hang on air . was a commen thing in the 1960s 1970s. dealer installed payed 400 dollors in 1974. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted June 16, 2013 Share Posted June 16, 2013 neat idea - but as underpowered these things are, you may find yourself having to cycle off everytime you pull away from a light or going up a hill. You may also have heat issues - when you put the condenser in front of the radiator on an underpowered truck, .... you could use the 2-60 method - open 2 windows & go 60 mph - sorry bad joke. In my mind it is not a practical mod - but good luck if you decide to do it anyway. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted June 17, 2013 Share Posted June 17, 2013 my dolphon has the factory air but does not work a maybe sometime repair. tore same off my 4wd ten years ago . car has good air.house has good air. Quote Link to comment Share on other sites More sharing options...
