flyboyaviator Posted March 25, 2013 Share Posted March 25, 2013 Where is the plug for the OBD-II, I have a 1993 Itasca-Spirit. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 25, 2013 Share Posted March 25, 2013 Sorry fella, you're SOL. OBDII didn't arrive until '96. Here's a link to the 1993 FSM. http://personal.utulsa.edu/~nathan-buchanan/93fsm/ Quote Link to comment Share on other sites More sharing options...
Dolphinite no longer here Posted March 25, 2013 Share Posted March 25, 2013 So, what's an OBD? John Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 25, 2013 Share Posted March 25, 2013 OnBoard Diagnostics. Basically, a standardized way to hook up an scanner to read the trouble codes when your 'Check Engine Light' (CEL) comes on. OBDII came out in '96 and standardized on all cars sold in North America. http://en.wikipedia.org/wiki/On-board_diagnostics Quote Link to comment Share on other sites More sharing options...
rvman Posted March 25, 2013 Share Posted March 25, 2013 there is a OBDl though. it cant tell you much. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 25, 2013 Share Posted March 25, 2013 Before the OBDII protocol, there were different ones used by different manufacturers. Toyota had their own. http://www.autoshop101.com/forms/h46.pdf Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 25, 2013 Share Posted March 25, 2013 Yeah the older systems just invoked a code generating system to read stored codes better then nothing but not very informative. Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 25, 2013 Share Posted March 25, 2013 Where is the plug for the OBD-II, I have a 1993 Itasca-Spirit. You have a code reading arrangement, there is a diagnostic connector under the hood with two terminals(E1 and TE1) that need to be jumperd doing so will cause the check engine light to blink a series of flashes when you turn the key on then you will need to have a look at a chart to decipher the code data. There is a space between the flashes the first set are ten’s and the second one’s so two flashes then three would be a code 23 If you don’t get the first time it will cycle until you turn off the key. Quote Link to comment Share on other sites More sharing options...
stamar Posted March 29, 2013 Share Posted March 29, 2013 I had a 94 previa with obd 2. some models are before 96 but all models are obd 2 after. also a 95 geo metro. however no toyhome is obd2. its good and its bad. obd 1 had to include a way to read the codes without a reader. in toyotas case you put a fuse in a box and then it flashes the codes. Quote Link to comment Share on other sites More sharing options...
zero Posted March 31, 2013 Share Posted March 31, 2013 Where is the plug for the OBD-II, I have a 1993 Itasca-Spirit. OBD has been around since the late 1960s. OBDII has only been around since 1994. In your case, if you have trouble, you need to count the light-flashes to read codes. I wish all my cars and trucks lacked OBDII but in my area, anything withou it is rusted out. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted May 6, 2013 Share Posted May 6, 2013 no obdII in 93. you can read codes though under the hood on pax side there is access to a plug that has about 18 pins - you have to jumper 2 pins then count flashes on your check engine light. find one of the manuals online - detailed instructions are in there. Quote Link to comment Share on other sites More sharing options...
